Installation & Licensing
Installation of maya 2013 failed! please help!
2 REPLIES 2
1736 Views, 2 Replies
since i installed windows 7 on my new ssd( i deleted of course the old) i can't install maya 2013! Everytime i try to install it appears a message " Communication failure" no of the three download methods worked!
here is the log:
2013/1/14:20:46:49    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/14:20:46:49    Manuel    ARTICMASTER    Launch
2013/1/14:20:46:51    Manuel    ARTICMASTER    === Setup ended ===
2013/1/14:20:46:51    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/14:20:46:53    Manuel    ARTICMASTER    PageOpen    LicenseDialog
2013/1/14:20:46:56    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
2013/1/14:20:48:45    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
2013/1/14:20:49:34    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/14:20:49:34    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/14:20:49:34    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2013/1/14:20:49:35    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
2013/1/14:20:49:40    Manuel    ARTICMASTER    === Setup ended ===
2013/1/14:20:59:31    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/14:20:59:31    Manuel    ARTICMASTER    Launch
2013/1/14:20:59:33    Manuel    ARTICMASTER    === Setup ended ===
2013/1/14:20:59:32    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/14:20:59:34    Manuel    ARTICMASTER    PageOpen    LicenseDialog
2013/1/14:20:59:37    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
2013/1/14:21:01:11    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
2013/1/14:21:01:32    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/14:21:01:32    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/14:21:01:32    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2013/1/14:21:01:33    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
2013/1/14:21:01:41    Manuel    ARTICMASTER    === Setup ended ===
2013/1/14:21:23:21    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/14:21:23:21    Manuel    ARTICMASTER    Launch
2013/1/14:21:23:24    Manuel    ARTICMASTER    === Setup ended ===
2013/1/14:21:23:24    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/14:21:23:33    Manuel    ARTICMASTER    PageOpen    LicenseDialog
2013/1/14:21:23:43    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
2013/1/14:21:25:16    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
2013/1/14:21:25:25    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/14:21:25:25    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/14:21:25:26    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2013/1/14:21:25:26    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
2013/1/14:21:25:30    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:16:21:41    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:21:41    Manuel    ARTICMASTER    Launch
2013/1/16:16:21:43    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:16:21:43    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/16:16:21:44    Manuel    ARTICMASTER    PageOpen    LicenseDialog
2013/1/16:16:21:52    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
2013/1/16:16:23:30    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
2013/1/16:16:23:41    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/16:16:23:41    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:16:23:42    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2013/1/16:16:23:42    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
2013/1/16:16:23:46    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:16:34:53    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:34:53    Manuel    ARTICMASTER    Launch
2013/1/16:16:34:55    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:16:35:29    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:35:29    Manuel    ARTICMASTER    Launch
2013/1/16:16:35:33    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:16:35:30    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:35:30    Manuel    ARTICMASTER    Launch
2013/1/16:16:35:33    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/16:16:35:35    Manuel    ARTICMASTER    PageOpen    LicenseDialog
2013/1/16:16:35:43    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
2013/1/16:16:37:18    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
2013/1/16:16:37:39    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/16:16:37:40    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Downloads\Autodesk Maya 2013 x64\Autodesk Maya 2013 x64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:16:37:40    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2013/1/16:16:37:41    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
2013/1/16:16:37:44    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:16:54:02    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:54:02    Manuel    ARTICMASTER    Launch
2013/1/16:16:54:04    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:16:54:03    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:54:03    Manuel    ARTICMASTER    Launch
2013/1/16:16:54:04    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/16:16:54:07    Manuel    ARTICMASTER    PageOpen    LicenseDialog
2013/1/16:16:54:10    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
2013/1/16:16:54:17    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
2013/1/16:16:54:18    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/16:16:54:19    Manuel    ARTICMASTER    Installing Autodesk® MatchMover™ 2013:   INSTALLDIR="H:\Program Files\Autodesk\MatchMover2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\" INSTALLDIR="H:\Program Files\Autodesk\MatchMover2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:16:54:38    Manuel    ARTICMASTER    Install    Autodesk® MatchMover™ 2013    Succeeded
2013/1/16:16:54:38    Manuel    ARTICMASTER    Installing Autodesk® Maya® Composite 2013:   INSTALLDIR="H:\Program Files\Autodesk\Composite 2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\" INSTALLDIR="H:\Program Files\Autodesk\Composite 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:16:55:14    Manuel    ARTICMASTER    Install    Autodesk® Maya® Composite 2013    Succeeded
2013/1/16:16:55:14    Manuel    ARTICMASTER    Installing Autodesk® Backburner 2013: E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\x64\BackBurner\BackburnerCIF.exe
2013/1/16:16:55:21    Manuel    ARTICMASTER    Install    Autodesk® Backburner 2013    Succeeded
2013/1/16:16:55:21    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:16:55:22    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2013/1/16:16:55:22    Manuel    ARTICMASTER    Rollback    Autodesk® Backburner 2013    Failed    Failure is ignored, Result=1619
2013/1/16:16:56:02    Manuel    ARTICMASTER    Rollback    Autodesk® Maya® Composite 2013    Succeeded
2013/1/16:16:56:31    Manuel    ARTICMASTER    Rollback    Autodesk® MatchMover™ 2013    Succeeded
2013/1/16:16:56:31    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
2013/1/16:16:56:40    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:17:11:49    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:17:11:49    Manuel    ARTICMASTER    Launch
2013/1/16:17:11:49    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:17:11:49    Manuel    ARTICMASTER    PageOpen    MaintenanceDialog
2013/1/16:17:11:51    Manuel    ARTICMASTER    PageOpen    MaintVerifyReadyDialog
2013/1/16:17:11:53    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/16:17:11:53    Manuel    ARTICMASTER    Installing Autodesk® Maya® 2013:  REMOVE=ALL INSTALLDIR="H:\Program Files\Autodesk\Maya2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:17:13:55    Manuel    ARTICMASTER    Uninstall    Autodesk® Maya® 2013    Succeeded
2013/1/16:17:13:55    Manuel    ARTICMASTER    PageOpen    MaintCompleteDialog
2013/1/16:17:13:59    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:17:17:59    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
2013/1/16:17:17:59    Manuel    ARTICMASTER    Launch
2013/1/16:17:18:01    Manuel    ARTICMASTER    === Setup ended ===
2013/1/16:17:18:01    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/16:17:18:05    Manuel    ARTICMASTER    PageOpen    BeginDeploymentDialog
2013/1/16:17:18:13    Manuel    ARTICMASTER    PageOpen    LaunchDialog
2013/1/16:17:18:21    Manuel    ARTICMASTER    PageOpen    LicenseDialog
2013/1/16:17:18:40    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
2013/1/16:17:20:05    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
2013/1/16:17:20:24    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
2013/1/16:17:20:24    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk Maya 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:17:20:25    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
2 REPLIES 2
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
You might consider downloading and installing this update directly from Microsoft as well.
Good Luck!
Autodesk Forums:
in reply to: TravisNave
I have the same thing and when i uninstall and maya went to reinstall it still got the same error and i have done it over and over so any suggestions on how to fix this, i was also installing the trial version
Administrator Productivity
