since i installed windows 7 on my new ssd( i deleted of course the old) i can't install maya 2013! Everytime i try to install it appears a message " Communication failure" no of the three download methods worked!
here is the log:
2013/1/14:20:46:49 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/14:20:46:49 Manuel ARTICMASTER Launch
2013/1/14:20:46:51 Manuel ARTICMASTER === Setup ended ===
2013/1/14:20:46:51 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/14:20:46:53 Manuel ARTICMASTER PageOpen LicenseDialog
2013/1/14:20:46:56 Manuel ARTICMASTER PageOpen ProductInfoDialog
2013/1/14:20:48:45 Manuel ARTICMASTER PageOpen ProductSelectionDialog2
2013/1/14:20:49:34 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/14:20:49:34 Manuel ARTICMASTER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/14:20:49:34 Manuel ARTICMASTER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/14:20:49:35 Manuel ARTICMASTER PageOpen InstallCompleteDialog
2013/1/14:20:49:40 Manuel ARTICMASTER === Setup ended ===
2013/1/14:20:59:31 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/14:20:59:31 Manuel ARTICMASTER Launch
2013/1/14:20:59:33 Manuel ARTICMASTER === Setup ended ===
2013/1/14:20:59:32 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/14:20:59:34 Manuel ARTICMASTER PageOpen LicenseDialog
2013/1/14:20:59:37 Manuel ARTICMASTER PageOpen ProductInfoDialog
2013/1/14:21:01:11 Manuel ARTICMASTER PageOpen ProductSelectionDialog2
2013/1/14:21:01:32 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/14:21:01:32 Manuel ARTICMASTER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/14:21:01:32 Manuel ARTICMASTER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/14:21:01:33 Manuel ARTICMASTER PageOpen InstallCompleteDialog
2013/1/14:21:01:41 Manuel ARTICMASTER === Setup ended ===
2013/1/14:21:23:21 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/14:21:23:21 Manuel ARTICMASTER Launch
2013/1/14:21:23:24 Manuel ARTICMASTER === Setup ended ===
2013/1/14:21:23:24 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/14:21:23:33 Manuel ARTICMASTER PageOpen LicenseDialog
2013/1/14:21:23:43 Manuel ARTICMASTER PageOpen ProductInfoDialog
2013/1/14:21:25:16 Manuel ARTICMASTER PageOpen ProductSelectionDialog2
2013/1/14:21:25:25 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/14:21:25:25 Manuel ARTICMASTER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/14:21:25:26 Manuel ARTICMASTER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/14:21:25:26 Manuel ARTICMASTER PageOpen InstallCompleteDialog
2013/1/14:21:25:30 Manuel ARTICMASTER === Setup ended ===
2013/1/16:16:21:41 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:21:41 Manuel ARTICMASTER Launch
2013/1/16:16:21:43 Manuel ARTICMASTER === Setup ended ===
2013/1/16:16:21:43 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/16:16:21:44 Manuel ARTICMASTER PageOpen LicenseDialog
2013/1/16:16:21:52 Manuel ARTICMASTER PageOpen ProductInfoDialog
2013/1/16:16:23:30 Manuel ARTICMASTER PageOpen ProductSelectionDialog2
2013/1/16:16:23:41 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/16:16:23:41 Manuel ARTICMASTER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:16:23:42 Manuel ARTICMASTER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/16:16:23:42 Manuel ARTICMASTER PageOpen InstallCompleteDialog
2013/1/16:16:23:46 Manuel ARTICMASTER === Setup ended ===
2013/1/16:16:34:53 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:34:53 Manuel ARTICMASTER Launch
2013/1/16:16:34:55 Manuel ARTICMASTER === Setup ended ===
2013/1/16:16:35:29 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:35:29 Manuel ARTICMASTER Launch
2013/1/16:16:35:33 Manuel ARTICMASTER === Setup ended ===
2013/1/16:16:35:30 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:35:30 Manuel ARTICMASTER Launch
2013/1/16:16:35:33 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/16:16:35:35 Manuel ARTICMASTER PageOpen LicenseDialog
2013/1/16:16:35:43 Manuel ARTICMASTER PageOpen ProductInfoDialog
2013/1/16:16:37:18 Manuel ARTICMASTER PageOpen ProductSelectionDialog2
2013/1/16:16:37:39 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/16:16:37:40 Manuel ARTICMASTER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Downloads\Autodesk Maya 2013 x64\Autodesk Maya 2013 x64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:16:37:40 Manuel ARTICMASTER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/16:16:37:41 Manuel ARTICMASTER PageOpen InstallCompleteDialog
2013/1/16:16:37:44 Manuel ARTICMASTER === Setup ended ===
2013/1/16:16:54:02 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:54:02 Manuel ARTICMASTER Launch
2013/1/16:16:54:04 Manuel ARTICMASTER === Setup ended ===
2013/1/16:16:54:03 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:16:54:03 Manuel ARTICMASTER Launch
2013/1/16:16:54:04 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/16:16:54:07 Manuel ARTICMASTER PageOpen LicenseDialog
2013/1/16:16:54:10 Manuel ARTICMASTER PageOpen ProductInfoDialog
2013/1/16:16:54:17 Manuel ARTICMASTER PageOpen ProductSelectionDialog2
2013/1/16:16:54:18 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/16:16:54:19 Manuel ARTICMASTER Installing Autodesk® MatchMover™ 2013: INSTALLDIR="H:\Program Files\Autodesk\MatchMover2013\" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\" INSTALLDIR="H:\Program Files\Autodesk\MatchMover2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/16:16:54:38 Manuel ARTICMASTER Install Autodesk® MatchMover™ 2013 Succeeded
2013/1/16:16:54:38 Manuel ARTICMASTER Installing Autodesk® Maya® Composite 2013: INSTALLDIR="H:\Program Files\Autodesk\Composite 2013\" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\" INSTALLDIR="H:\Program Files\Autodesk\Composite 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/16:16:55:14 Manuel ARTICMASTER Install Autodesk® Maya® Composite 2013 Succeeded
2013/1/16:16:55:14 Manuel ARTICMASTER Installing Autodesk® Backburner 2013: E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\x64\BackBurner\BackburnerCIF.exe
2013/1/16:16:55:21 Manuel ARTICMASTER Install Autodesk® Backburner 2013 Succeeded
2013/1/16:16:55:21 Manuel ARTICMASTER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:16:55:22 Manuel ARTICMASTER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/16:16:55:22 Manuel ARTICMASTER Rollback Autodesk® Backburner 2013 Failed Failure is ignored, Result=1619
2013/1/16:16:56:02 Manuel ARTICMASTER Rollback Autodesk® Maya® Composite 2013 Succeeded
2013/1/16:16:56:31 Manuel ARTICMASTER Rollback Autodesk® MatchMover™ 2013 Succeeded
2013/1/16:16:56:31 Manuel ARTICMASTER PageOpen InstallCompleteDialog
2013/1/16:16:56:40 Manuel ARTICMASTER === Setup ended ===
2013/1/16:17:11:49 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:17:11:49 Manuel ARTICMASTER Launch
2013/1/16:17:11:49 Manuel ARTICMASTER === Setup ended ===
2013/1/16:17:11:49 Manuel ARTICMASTER PageOpen MaintenanceDialog
2013/1/16:17:11:51 Manuel ARTICMASTER PageOpen MaintVerifyReadyDialog
2013/1/16:17:11:53 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/16:17:11:53 Manuel ARTICMASTER Installing Autodesk® Maya® 2013: REMOVE=ALL INSTALLDIR="H:\Program Files\Autodesk\Maya2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/16:17:13:55 Manuel ARTICMASTER Uninstall Autodesk® Maya® 2013 Succeeded
2013/1/16:17:13:55 Manuel ARTICMASTER PageOpen MaintCompleteDialog
2013/1/16:17:13:59 Manuel ARTICMASTER === Setup ended ===
2013/1/16:17:17:59 Manuel ARTICMASTER === Setup started on ARTICMASTER by Manuel ===
2013/1/16:17:17:59 Manuel ARTICMASTER Launch
2013/1/16:17:18:01 Manuel ARTICMASTER === Setup ended ===
2013/1/16:17:18:01 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/16:17:18:05 Manuel ARTICMASTER PageOpen BeginDeploymentDialog
2013/1/16:17:18:13 Manuel ARTICMASTER PageOpen LaunchDialog
2013/1/16:17:18:21 Manuel ARTICMASTER PageOpen LicenseDialog
2013/1/16:17:18:40 Manuel ARTICMASTER PageOpen ProductInfoDialog
2013/1/16:17:20:05 Manuel ARTICMASTER PageOpen ProductSelectionDialog2
2013/1/16:17:20:24 Manuel ARTICMASTER PageOpen FullProgressDialog
2013/1/16:17:20:24 Manuel ARTICMASTER Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk Maya 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/16:17:20:25 Manuel ARTICMASTER Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
You might consider downloading and installing this update directly from Microsoft as well.
Good Luck!
