During the install of IDSP 2105 products the install process stops at Subassembly Composer. Then have to do a work around involving going into Task Manager to End Process then select certain options to hopefully get the remaining products to install.
Can open Subassembly Composer 2015 but have not worked with it to see if working correctly.
Is their a fix out their for this problem?
