Hey guys,
I am trying to install Autodesck Revit 2013 on Windows 8.1
Unfortuanlly next error aries doing this: please see the attached screeshot
My questions are:
1. Is it possible to uninstall .NET Framewor 4.0 which is delivered by default with Windows 8.1 and install .NET Framework 3.5 , if this will resolve my issue ?
2. If yes - can you please support me on these steps to reinstall the Framework 4.0 if this could help me to solve the existing problem.
Thanks in advance,
Vasil
Keep in mind that Revit 2013 is not supported on Windows 8.x.
However, to install that older version of .NET, you can do so from within the Control Panel > Programs. You need to add Windows components and it should be an option that you can check. It is not on by default.
Good Luck!
We will be updating the following page when we get more info on Windows 8.1 support:
http://upandready.typepad.com/up_and_ready/2013/10/windows-81-support-please-upgrade-cautiously.html
What am I supposed to do if my professor requires Revit 2013 and I have a new PC with Windows 8?
