Installation & Licensing
Installation of Autodesck Revit 2013 - Windows 8.1 ( Framework 4.0)
4 REPLIES 4
vaseka93
2716 Views, 4 Replies
Hey guys,
I am trying to install Autodesck Revit 2013 on Windows 8.1
Unfortuanlly next error aries doing this: please see the attached screeshot
My questions are:
1. Is it possible to uninstall .NET Framewor 4.0 which is delivered by default with Windows 8.1 and install .NET Framework 3.5 , if this will resolve my issue ?
2. If yes - can you please support me on these steps to reinstall the Framework 4.0 if this could help me to solve the existing problem.
Thanks in advance,
Vasil
4 REPLIES 4
pendean
in reply to: vaseka93
Windows Uninstaller can remove all instances of .NET, and Windows Update should be able to put back the ones your Apps/OS need.
TravisNave
Keep in mind that Revit 2013 is not supported on Windows 8.x.
However, to install that older version of .NET, you can do so from within the Control Panel > Programs.  You need to add Windows components and it should be an option that you can check.  It is not on by default.
Good Luck!
Autodesk Forums:
david.lau
in reply to: TravisNave
We will be updating the following page when we get more info on Windows 8.1 support:
http://upandready.typepad.com/up_and_ready/2013/10/windows-81-support-please-upgrade-cautiously.html
David Lau
DeuceK916
What am I supposed to do if my professor requires Revit 2013 and I have a new PC with Windows 8?
Administrator Productivity
