• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Accepted Solution
    Installation of AutoCAD Electrical 2013 - Failed to install numerous times
    1742 Views, 11 Replies
    05-29-2012 04:21 AM
    I am trying to install a standalone ACE 2013 on a win 7 pro, sp1, 64 bit, core i7-2760qm 2.4 ghz, 4gb ram.
    During the first install, it halted at the language pack. Had to use task manager to end the process.
    Tried a "reinstall" via control panel/programs and features.
    ACE 2013 would not start.
    Did a complete unistall of all AC programs
    2nd install, had much the same issues but also came up with error window "cdb system resourse exceded"
    Tried a "repair" via control panel/programs and features.
    Said program install was successfull.
    When trying to start ACE get the following error window:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: acad.exe
    Application Version: 25.0.55.0
    Application Timestamp: 4f309abd
    Fault Module Name: accore.dll
    Fault Module Version: 19.0.55.0
    Fault Module Timestamp: 4f309bcf
    Exception Code: c0000005
    Exception Offset: 00000000000bddf0
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 1033
    Additional Information 1: d357
    Additional Information 2: d3571c485c0fb56bb09815278810e62e
    Additional Information 3: 7f49
    Additional Information 4: 7f4939330ead794509f64ae160c1f509
    Did complete uninstall.
    3rd Install.
    had much the same issues but also came up with error window "cdb system resourse exceded" again.
    This time I ok'ed through the errors, which took about 12hrs.
    Program said it was a successfull install.
    got same error as above when trying to start the program.
    Did repair and still no start.
    Uninstall all AC components again.
    Tried 4th time.
    All the same issues.
    Program will still not start.
    I think I have attached the latest log.
    Please use plain text.
    Active Member
    Re: Installation of AutoCAD Electrical 2013
    05-28-2012 07:32 PM in reply to: lmcdonald
    I am also having the same issue with ACE 2013 install.
    Much the same issues as was described in the beginning of the thread.
    I am on 5th time trying to install.
    See attached log.
    Tks,
    Lyndon.
    Product Support
    05-29-2012 07:02 AM in reply to: lmcdonald
    Hi lmcdonald;
       The log files do not show error messages, actually shows that Electrical was successfully installed? If this installation is taking too long have you tried to simply install the core application, say Electrical and then install the remaining applications? This should break up the installation and speed things up
    dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    05-29-2012 07:07 AM in reply to: Dwayne.Poot
    Thanks Dwayne. See screen shot of when I try to open ACE Yes, I tried what you suggested. This is what I end up after an install, whether it's the complete package or just ACE core. Lyndon McDonald xxx.xxx.xxxx (cell) Description: cid:image004.jpg@01CCF24C.2AEEC870 Carmichael Engineering Ltd. 10 Morris Drive, Dartmouth, Nova Scotia, Canada, B3B 1K8 T
    Edited by
    Discussion_Admin
    Product Support
    05-29-2012 07:14 AM in reply to: lmcdonald
    Hi lmcdonald;
       Can you re-send the screen shot, it didn't come through
    dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    05-29-2012 07:17 AM in reply to: Dwayne.Poot
    It took 3 shots to get the complete message. Lyndon McDonald xxx.xxx.xxxx (cell) Description: cid:image004.jpg@01CCF24C.2AEEC870 Carmichael Engineering Ltd. 10 Morris Drive, Dartmouth, Nova Scotia, Canada, B3B 1K8
    Edited by
    Discussion_Admin
    Product Support
    05-29-2012 12:25 PM in reply to: lmcdonald
    Sorry but they are not coming through.
    Dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    05-29-2012 04:02 PM in reply to: Dwayne.Poot
    The detials in the error are as follows:
    Problem signature:
    Locale ID: 1033
    Active Member
    05-30-2012 05:39 AM in reply to: lmcdonald
    After my 5th time uninstalling everything (including MS Visual stuff), cleaning the registry, etc.
    The sixth install with the core ACE 2013 only with no bells or whistles or extras chosen, it worked.
    This issue has shown up in many other threads, with no solution provided yet.
    Can you provide an answer as to why this happens, and what the fix is. I have lost about 12hrs of my life installing this....which seems a bit excessive.
    Thanks for your assistance, but I really would like to know the cause and the fix.
    Lyndon.
    Active Member
    06-06-2012 09:36 AM in reply to: lmcdonald
    Issues was resoled without help from tech support.
