Installation & Licensing
Installation of AutoCAD Civil 3D
7 REPLIES 7
Message 1 of 8
jsolomon99
316 Views, 7 Replies
I'm downloading this version to my laptop.  I am running Windows 7.
Can I install the 2009 version of this software to this laptop?
My video card is Intel HD Graphics with ExpressCard.  Can I run the software using this video card?
John
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: jsolomon99
Autodesk 2010 products and newer are supported on Windows 7.  Civil 3D 2009 is not supported.  Furthermore, your lack of a certified 3D card would probably hinder your experience if you were able to successfully install it.  You're better off putting this on a Windows XP or Vista machine with a certified 3D video card.
Autodesk Forums:
Message 3 of 8
jsolomon99
in reply to: TravisNave
Thank you for your reply.
I can use the 2010 version, but can you tell me how to go about getting a certified 3D video card?  Can I go to a computer store, but it and have them install it?  I have checked the Dell website and I don't see any selection for 3D video cards.  I'm not opposed to buying a new computer.
Thanks again in advance.
John
Message 4 of 8
You will find more infomration about which Autodesk Products supported by Windows 7 here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056350&linkID=9240617
Timmy De Austria
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. 😉
Message 5 of 8
You can find certified graphics cards through here:
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
You can find system requirements for Civil 3D here: Even if it is for 2012, it will definitely work for 2010.
http://usa.autodesk.com/civil-3d/system-requirements/
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15411638&linkID=9240697
Hope this helps...
Timmy De Austria
Message 6 of 8
jsolomon99
Sorry.  I just re-read my post and it had a typo...  Can I go to a computer store, BUY it and have them install it?
Message 7 of 8
Thanks Timmy!  Have a great day!
Message 8 of 8
You can just go to a computer store and buy a Video Card. Just check supported video cards here:
to make sure that you will purchase a certified card so you won't experience any problems. Consider of what type of work you will be doing.
I would recommend also recommend to bump up your RAM. I would recommend at least 4gb reserve some slots for later upgrade.
Timmy De Austria
Administrator Productivity
