I have downloaded AutoCAD 2013 from Autodesk for educational purposes. (displaced professionals) I have run the set up and entered the serial number & product key. all seemed to go well thanks to an autodesk tutorial on deployment setup. Unfortunately I do not have or can't find the exe file to open the program. It is not listed in my program files or in the download folder and not found through a search. Not sure where to go from here as I've always had an IT person install the program for me. Any help is appreciated.
If it actually installed successfully, then it should be in the AutoCAD 2013 folder under Program Files.
