Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Installati on network license on same server without merge serial number
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
our customer have many department. They separate asset by department.
This customer have 2 version of P&ID
P&ID11 for Department A 2 seat
P&ID13 for Department B 2seat
but both of license need to run on same server IT Department.
I copy and paste on same license but I think LM tool look at the same Package Number.
1. How we can run 2 license on same server without merge S/N?
2. I ever heard there is "Product license" that split out of "Package license" such as P&ID13 license without P&ID12 and 11, isn't it?
**edit**
more explain :
Department A use P&ID11 2 seat
Department B use P&ID13 2 seat
but server distribute license only 2 seat
that is a problem.
Re : Installati on network license on same server without merge serial number
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Read this topic from Travis :
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you need to generate all license files on the same day and then combine them into 1 license file
Re: Installati on network license on same server without merge serial number
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you all,
So, I need to do
1. Generate new license both of them because we need license on same date.
2. Copy only INCREMENT part not include PACKAGE part, then paste on new version of license (this case is PID2013)
3. Replace this lic. and reread
4. Done.
correct?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
if they are on subscription you copy the increment and the package statement
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Right. If you have two subscription licenses, copy only the one PACKAGE portion and then append all the individual INCREMENTS under it. If they are created on the same date, it will properly combine, per my instructions in the link above.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Installati on network license on same server without merge serial number
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Our customer have only one subscription license, I need to combine them as your advise above.
anyways, thank you all
