• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    a_nightrem
    Installation keeps failing
    328 Views, 2 Replies
    03-23-2011 07:47 PM
    I've been trying to install Autocad 2011 on my desktop which runs on windows 7
    then whenever i log in, and click onto the design software, it keeps prompting me to log in which i have already done
    i have tried multiple times and it's happening again and again so i wonder what's wrong?
    thanks for the help!
    Please use plain text.
    Product Support
    Re: Installation keeps failing
    03-24-2011 07:08 AM in reply to: a_nightrem
    not sure what logon screen it is , could you post the screen shot please.
    Did you install the software as administrator ?
    please try to turn off UAC
    http://windows.microsoft.com/en-US/windows-vista/Turn-User-Account-Control-on-or-off
    or try a clean install in diagnostics mode
    http://usa.autodesk.com/getdoc/id=TS75218
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    TravisNave
    03-24-2011 09:12 AM in reply to: a_nightrem
    Is your network restricted by your IT Manager via proxy server or similar?  You may not have full access to the Internet or a network resource that AutoCAD is trying to reach.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
