Installation & Licensing
New Member
hen.sl
Message 1 of 3 (161 Views)
Installation failure
161 Views, 2 Replies
09-18-2013 04:49 PM
Hello.  I am trying to install revit and have got all the way to the end only to have it say that Revit has failed as has the medium image library.  I have attached the original error that occurred during installation and the installation logs for both failure notices.  Could someone please help me...I am getting frustrated because this has happened to me before and I gave up and didn't install it.
Product Support
dembkod
Message 2 of 3 (122 Views)
Re: Installation failure
09-19-2013 06:55 AM in reply to: hen.sl
hen.sl,
Hello. The error does not tell me what is wrong specifically, but I definitely see C++ errors in your log (thank you for this).
I would open the Control Panel and uninstall all entries for the Microsoft C++ redistributables for 2005, 2008, and 2010. While you are here, you may as well uninstall NET as well, just in case. Then install the program and hopefully everything will be installed.
Thank you for taking part in our community!
David Dembkoski
TravisNave
Message 3 of 3 (106 Views)
09-19-2013 08:26 AM in reply to: hen.sl
This error can happen for a multitude of reasons.
First, make sure you have full permissions to the C:\Windows\Installer folder.  If you do not, add your user and give full permissions.
Also, this can happen in your change your TEMP or TMP environment variable locations from default to something else.
Furthermore, this could be a problem wth your Windows Installer.  Make sure the service itself is not stopping and see if you need to upgrade it. Might check Windows Update.
And always always always make sure you are installing with local admin rights, UAC disabled, and anti-virus temporarily turned off.
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
