Installation & Licensing
wengkeat
1265 Views, 2 Replies
Installation failure
My laptop is currently running on Windows 8 pro 64 bit. I was trying to install but there was a message "Installation complete. Some products failed to install." The attach log is as follows:
2013/6/24:01:05:03 Weng Keat TANK === Setup started on TANK by Weng Keat ===
2013/6/24:01:05:03 Weng Keat TANK Path_Length: 152
2013/6/24:01:05:03 Weng Keat TANK Current Directory C:\Users\WENGKE~1\AppData\Local\Temp\_AIFC96.tmp
2013/6/24:01:05:03 Weng Keat TANK Launch
2013/6/24:01:05:03 Weng Keat TANK Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\WENGKE~1\AppData\Local\Temp\_AIFC96.tmp\Setup\AcSetup.dll
2013/6/24:01:05:03 Weng Keat TANK Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/6/24:01:05:06 Weng Keat TANK PageOpen LaunchDialog
2013/6/24:01:05:32 Weng Keat TANK PageOpen LicenseDialog
2013/6/24:01:05:37 Weng Keat TANK PageOpen ProductSelectionDialog2
2013/6/24:01:05:38 Weng Keat TANK PageOpen FullProgressDialog
2013/6/24:01:05:38 Weng Keat TANK Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2013/6/24:01:05:45 Weng Keat TANK Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2 REPLIES 2
jpatterson133
in reply to: wengkeat
I am running the exact same operating system and have experienced the same thing while trying to load Inventor 2012. Have you been able to resolve anything? I have yet to.
TravisNave
Welcome to the forums!
Your problem can likely be solved by checking out my KB post here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Autodesk Forums:
Administrator Productivity
