Installation & Licensing
Active Member
CADCIV
Message 1 of 4 (682 Views)
Installation failure AutoCAD 2011/2012. Urgent help needed!
682 Views, 3 Replies
09-20-2011 05:41 PM
Any help will be greatly appreciated as I need this program quite urgently.
I have tried to install AutoCAD 2011 and 2012 both but am unable to install either of them.
For AutoCAD 2012, as soon as I start the install, I get an error message. The error goes along the lines of:
"/SecondRun/ lang en-us / FirstRunThreadID 3996"
**Each time I install, the FirstRunThreadID gives a different 4 digit number.
As for AutoCAD 2011, it fails installation at installing Micorosoft Visual C++ 2008 (x86) and installation aborts. (It also USED to fail at installing C++ 2005 but now apparently it passes that and reaches C++ 2008 where it fails)
From Log file for AutoCAD 2011:
InstallMicrosoft Visual C++ 2008 Redistributable (x86)FailedInstallation aborted, Result=193
I am trying to install 64 bit versions of both of them, but both dont work. I'm running a 64 bit WIndows 7 Professional with 4GB RAM.
**I have also manually installed the Visual C++ 2005 and 2008 (x86) and (x64) manually as well as used windows clean up utility to clean up AutoCAD after a failed install.
Product Support
david.lau
Message 2 of 4 (656 Views)
Re: Installation failure AutoCAD 2011/2012. Urgent help needed!
09-21-2011 10:34 AM in reply to: CADCIV
Can you check out this post:
http://upandready.typepad.com/up_and_ready/2011/09/autodesk-suites-product-design-suite-will-not-ins...
I am curious if a higher version of the Microsoft Visual C++ 2010 Redistributable Package on your computer
David Lau
Active Member
CADCIV
Message 3 of 4 (637 Views)
09-21-2011 04:59 PM in reply to: david.lau
I checked the "uninstall a program" and it says I have visual C++ 2005 and 2008 installed but not 2010.
Active Member
CADCIV
Message 4 of 4 (620 Views)
09-22-2011 07:30 AM in reply to: CADCIV
Help needed, can't intall autoCAD. Very urgently needed!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
