• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Installation failed
    197 Views, 2 Replies
    11-05-2012 07:10 AM
    i can't install Factory Design Suite Ultimate 2013, failed with unexpected error, see atachement.
    The operating system is WIN 7 64 new installation, no Autodesk Products installed.
    I don't know what to do.
    Waiting for help.
    Greets
    Please use plain text.
    Product Support
    emily.xu
    Re: Installation failed
    11-06-2012 06:15 PM in reply to: g.knaack
    Hi, g.knaack
    Welcome to autodesk discussion group. Thanks for reporting this issue.
    From the log file, I can see the installation error 1603 when install AutoCAD Mechanical 2013.This typically related to the user right, but there are some reasons can cause this type of error. So, the following is my suggestions:
    1  Please try to install with another admin user, recommend the system default user "Administrator".
    2  Please turn off any antivirus and firewall, including the related processes on the background.For such applications may affect installaion files register, and may slow down your installation.
    3  Please turn off UAC
    4  If all above not work, please try to copy all the installation files to your local and install from there.
    Hope helps.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Emily Xu
    AutodeskCare | Product Support
    Product Support
    emily.xu
    11-12-2012 06:15 PM in reply to: emily.xu
    Did you install your products by my suggestions?
    Emily Xu
