Installation & Licensing
Installation fail on Windows 7 x64
4 REPLIES 4
blackcutwitch
649 Views, 4 Replies
Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619   Getting this when it is half way through dowload and installation.  It gets to about 1.9G then says autodesk 3ds Max failed.
4 REPLIES 4
TravisNave
in reply to: blackcutwitch
That's not the culprit.  Your failure will be above the rollback.
Autodesk Forums:
blackcutwitch
in reply to: TravisNave
You're right, about here I think
Download    Aborted    MAX    http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2012/10/4:20:33:35    CJP    CJP-THINK    Install    Autodesk® 3ds Max 2013    Failed    Download Failed, Installation aborted, Result=1603
Poor internet connection maybe?
TravisNave
Yep, the download failed.  You might check your connection and try again.  The download is large (approaching 400mb.)
Autodesk Forums:
Thank you.  I gave up and used the browser download.  Hopefully it is all there, it installed fine so now to use it  - to the Max of course 🙂
Administrator Productivity
