Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Installati on error AutoCAD 2013 - .Net Framework
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
While installing AutoCAD 2013 i get the following error:
2012/7/19:15:14:30 DKennard SLB-6DDPJ4J === Setup started on SLB-6DDPJ4J by DKennard ===
2012/7/19:15:14:30 DKennard SLB-6DDPJ4J Launch
2012/7/19:15:14:31 DKennard SLB-6DDPJ4J Download S
2012/7/19:15:14:33 DKennard SLB-6DDPJ4J PageOpen L
2012/7/19:15:14:36 DKennard SLB-6DDPJ4J PageOpen L
2012/7/19:15:14:38 DKennard SLB-6DDPJ4J PageOpen P
2012/7/19:15:14:59 DKennard SLB-6DDPJ4J PageOpen P
2012/7/19:15:15:00 DKennard SLB-6DDPJ4J PageOpen F
2012/7/19:15:15:01 DKennard SLB-6DDPJ4J Download S
2012/7/19:15:15:01 DKennard SLB-6DDPJ4J Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD P&ID 2013 English\3rdParty\NET\4\wcu\dotNetFramework\dotNetF
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Install .N
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Download S
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\WI\AutoCAD P&ID 2013 English\3rdParty\NET\4\wcu\dotNetFramework\NDP40-K
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Rollback .
I have unistalled both .Net frameowork Extended and Client.Also i have used the .Net framework clenup tool, but i still get the same messege each time. I have had a search in the forums but cannot find a solution.
Regards
Danny
Re: Installati on error AutoCAD 2013 - .Net Framework
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you tried installing the prerequisite direct from Microsoft first? If it installs without error, then simply modify your setup.ini file to no longer check for the .NET Framework install.
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Installati on error AutoCAD 2013 - .Net Framework
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried to install direct from Microsoft but also had an error. In the end i installed 4.5 RC which has allowed the installation of AutoCAD, but now i have a new issue where AutoCAD crashes often and with no real consistency.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Random crashes could be video driver related. Are you running a certified driver?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having the same issue. I have a brand new computer with Windows 7 and I'm awaiting my Autocad software to arrive. In the mean time, I was going to put the 30 day trial on and then update the software again when mine came in. This is driving me crazy - I've never run into this before. Will try the 4.5 RC and see if the same thing happens.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The 4.5 install wouldn't take either. ![]()
I get an error code of HRESULT 0xc8000222
I have my IT guy on this too and he's stumped at the moment.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got the same error. I had to uninstall Microsoft NET Framework Client Profile and Microsoft NET Framework Extended before I could install.
Hope it works for ya!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
2013/1/16:11:49:22 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:11:49:22 Administrador WINDOWSXP Launch
2013/1/16:12:01:16 Administrador WINDOWSXP === Setup ended ===
2013/1/16:12:00:26 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:12:00:26 Administrador WINDOWSXP Launch
2013/1/16:12:01:18 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/16:12:11:08 Administrador WINDOWSXP PageOpen BeginDeploymentDialog
2013/1/16:12:11:25 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/16:12:11:54 Administrador WINDOWSXP PageOpen LicenseDialog
2013/1/16:12:11:54 Administrador WINDOWSXP PageOpen ProductSelectionDialog2
2013/1/16:12:12:19 Administrador WINDOWSXP PageOpen LicenseDialog
2013/1/16:12:12:19 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/16:12:12:24 Administrador WINDOWSXP Su equipo utiliza una versión de Microsoft .NET Framework no compatible. El producto que va a instalar requiere Microsoft .NET Framework 4.0 o una versión posterior.
Actualice .NET Framework 4.0 y reinicie su equipo antes de instalar el producto de Autodesk.2013/1/16:12:12:43 Administrador WINDOWSXP === Setup ended ===
2013/1/16:12:41:46 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:12:41:46 Administrador WINDOWSXP Launch
2013/1/16:12:42:06 Administrador WINDOWSXP === Setup ended ===
2013/1/16:12:41:52 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:12:41:52 Administrador WINDOWSXP Launch
2013/1/16:12:42:07 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/16:12:42:11 Administrador WINDOWSXP PageOpen LicenseDialog
2013/1/16:12:42:16 Administrador WINDOWSXP PageOpen ProductInfoDialog
2013/1/16:12:44:05 Administrador WINDOWSXP PageOpen ProductSelectionDialog2
2013/1/16:12:46:31 Administrador WINDOWSXP PageOpen FullProgressDialog
2013/1/16:12:46:32 Administrador WINDOWSXP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): D:\software variado\Autodesk Architecture 2013 sp\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\vcredist_x86_20
2013/1/16:12:46:46 Administrador WINDOWSXP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/16:12:46:46 Administrador WINDOWSXP Installing .NET Framework Runtime 4.0 KB2468871: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468
2013/1/16:13:01:40 Administrador WINDOWSXP Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/1/16:13:01:42 Administrador WINDOWSXP Installing Autodesk® Design Review 2013: TRANSFORMS="C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\_AI
2013/1/16:13:01:54 Administrador WINDOWSXP Install Autodesk® Design Review 2013 Failed Failure is ignored, Result=1603
2013/1/16:13:01:54 Administrador WINDOWSXP Installing .NET Framework Runtime 4.0 Language Pack: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP
2013/1/16:13:04:31 Administrador WINDOWSXP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/1/16:13:04:32 Administrador WINDOWSXP Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2013/1/16:13:04:32 Administrador WINDOWSXP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/16:13:04:43 Administrador WINDOWSXP PageOpen InstallCompleteDialog
2013/1/16:13:08:49 Administrador WINDOWSXP === Setup ended ===
2013/1/16:13:26:20 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:26:20 Administrador WINDOWSXP Launch
2013/1/16:13:26:40 Administrador WINDOWSXP === Setup ended ===
2013/1/16:13:26:24 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:26:24 Administrador WINDOWSXP Launch
2013/1/16:13:26:39 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/16:13:26:42 Administrador WINDOWSXP PageOpen LicenseDialog
2013/1/16:13:26:47 Administrador WINDOWSXP PageOpen ProductInfoDialog
2013/1/16:13:28:55 Administrador WINDOWSXP PageOpen ProductSelectionDialog2
2013/1/16:13:30:19 Administrador WINDOWSXP PageOpen FullProgressDialog
2013/1/16:13:30:19 Administrador WINDOWSXP Installing .NET Framework Runtime 4.0 Language Pack: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP
2013/1/16:13:32:40 Administrador WINDOWSXP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/1/16:13:32:44 Administrador WINDOWSXP PageOpen InstallCompleteDialog
2013/1/16:13:35:31 Administrador WINDOWSXP === Setup ended ===
2013/1/16:13:56:03 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:56:03 Administrador WINDOWSXP Launch
2013/1/16:13:56:25 Administrador WINDOWSXP === Setup ended ===
2013/1/16:13:56:10 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:56:10 Administrador WINDOWSXP Launch
2013/1/16:13:56:26 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/16:13:56:28 Administrador WINDOWSXP PageOpen LicenseDialog
2013/1/16:13:56:32 Administrador WINDOWSXP PageOpen ProductInfoDialog
2013/1/16:13:56:57 Administrador WINDOWSXP PageOpen ProductSelectionDialog2
2013/1/16:13:57:58 Administrador WINDOWSXP PageOpen FullProgressDialog
2013/1/16:13:57:58 Administrador WINDOWSXP Installing .NET Framework Runtime 4.0 Language Pack: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP
2013/1/16:14:00:17 Administrador WINDOWSXP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/1/16:14:00:21 Administrador WINDOWSXP PageOpen InstallCompleteDialog
2013/1/16:14:00:36 Administrador WINDOWSXP === Setup ended ===
2013/1/22:12:55:54 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/22:12:55:54 Administrador WINDOWSXP Launch
2013/1/22:12:56:38 Administrador WINDOWSXP === Setup ended ===
2013/1/22:12:56:13 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/22:12:56:13 Administrador WINDOWSXP Launch
2013/1/22:12:56:38 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/22:12:56:47 Administrador WINDOWSXP PageOpen LicenseDialog
2013/1/22:12:56:51 Administrador WINDOWSXP PageOpen ProductInfoDialog
2013/1/22:12:57:41 Administrador WINDOWSXP PageOpen ProductSelectionDialog2
2013/1/22:13:01:27 Administrador WINDOWSXP PageOpen FullProgressDialog
2013/1/22:13:01:27 Administrador WINDOWSXP Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_ACA_2013_Spanish_Win_32bit\3rd
2013/1/22:13:04:03 Administrador WINDOWSXP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2013/1/22:13:04:17 Administrador WINDOWSXP PageOpen InstallCompleteDialog
2013/1/22:13:04:33 Administrador WINDOWSXP === Setup ended ===
2013/1/22:17:02:31 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/22:17:02:31 Administrador WINDOWSXP Launch
2013/1/22:17:03:25 Administrador WINDOWSXP === Setup ended ===
2013/1/22:17:02:54 Administrador WINDOWSXP === Setup started on WINDOWSXP by Administrador ===
2013/1/22:17:02:54 Administrador WINDOWSXP Launch
2013/1/22:17:03:25 Administrador WINDOWSXP PageOpen LaunchDialog
2013/1/22:17:04:17 Administrador WINDOWSXP PageOpen LicenseDialog
2013/1/22:17:04:21 Administrador WINDOWSXP PageOpen ProductInfoDialog
2013/1/22:17:04:57 Administrador WINDOWSXP PageOpen ProductSelectionDialog2
2013/1/22:17:05:24 Administrador WINDOWSXP PageOpen FullProgressDialog
2013/1/22:17:05:24 Administrador WINDOWSXP Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_ACA_2013_Spanish_Win_32bit\3rd
2013/1/22:17:08:26 Administrador WINDOWSXP Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensi
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
Good Luck!
