Installation & Licensing
Installation error AutoCAD 2013 - .Net Framework
8 REPLIES 8
Message 1 of 9
dkennard
18185 Views, 8 Replies
While installing AutoCAD 2013 i get the following error:
2012/7/19:15:14:30 DKennard SLB-6DDPJ4J === Setup started on SLB-6DDPJ4J by DKennard ===
2012/7/19:15:14:30 DKennard SLB-6DDPJ4J Launch
2012/7/19:15:14:31 DKennard SLB-6DDPJ4J Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDDLM/2013/PNID/WI/{8EDC40A6-2393-4C08-BB5E-9011AFAB4A7B}/SETUP_...
2012/7/19:15:14:33 DKennard SLB-6DDPJ4J PageOpen LaunchDialog
2012/7/19:15:14:36 DKennard SLB-6DDPJ4J PageOpen LicenseDialog
2012/7/19:15:14:38 DKennard SLB-6DDPJ4J PageOpen ProductInfoDialog
2012/7/19:15:14:59 DKennard SLB-6DDPJ4J PageOpen ProductSelectionDialog2
2012/7/19:15:15:00 DKennard SLB-6DDPJ4J PageOpen FullProgressDialog
2012/7/19:15:15:01 DKennard SLB-6DDPJ4J Download Skipped DOTNET4 http://efulfillment.autodesk.com/SWDLDDLM/2013/PNID/WI/{8EDC40A6-2393-4C08-BB5E-9011AFAB4A7B}/DOTNET...
2012/7/19:15:15:01 DKennard SLB-6DDPJ4J Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD P&ID 2013 English\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Install .NET Framework Runtime 4.0 Succeeded
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Download Skipped DOTNET4KB2468871 http://efulfillment.autodesk.com/SWDLDDLM/2013/PNID/WI/{8EDC40A6-2393-4C08-BB5E-9011AFAB4A7B}/DOTNET...
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\WI\AutoCAD P&ID 2013 English\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=2
2012/7/19:15:19:10 DKennard SLB-6DDPJ4J Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
I have unistalled both .Net frameowork Extended and Client.Also i have used the .Net framework clenup tool, but i still get the same messege each time. I have had a search in the forums but cannot find a solution.
Regards
Danny
8 REPLIES 8
Message 2 of 9
TravisNave
in reply to: dkennard
Have you tried installing the prerequisite direct from Microsoft first?  If it installs without error, then simply modify your setup.ini file to no longer check for the .NET Framework install.
Autodesk Forums:
Message 3 of 9
dkennard
in reply to: TravisNave
I tried to install direct from Microsoft but also had an error. In the end i installed 4.5 RC which has allowed the installation of AutoCAD, but now i have a new issue where AutoCAD crashes often and with no real consistency.
Message 4 of 9
TravisNave
Random crashes could be video driver related.  Are you running a certified driver?
Autodesk Forums:
Message 5 of 9
yumij
I'm having the same issue.  I have a brand new computer with Windows 7 and I'm awaiting my Autocad software to arrive.  In the mean time, I was going to put the 30 day trial on and then update the software again when mine came in.  This is driving me crazy - I've never run into this before.  Will try the 4.5 RC and see if the same thing happens.
Message 6 of 9
yumij
in reply to: yumij
The 4.5 install wouldn't take either. Smiley Sad
I get an error code of HRESULT 0xc8000222
I have my IT guy on this too and he's stumped at the moment.
Message 7 of 9
concrete1988
I got the same error.  I had to uninstall Microsoft NET Framework Client Profile and Microsoft NET Framework Extended before I could install.
Hope it works for ya!
http://upandready.typepad.com/up_and_ready/2012/08/error-install-net-framework-runtime-40-kb2468871-...
Message 8 of 9
10166344
2013/1/16:11:49:22    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:11:49:22    Administrador    WINDOWSXP    Launch
2013/1/16:12:01:16    Administrador    WINDOWSXP    === Setup ended ===
2013/1/16:12:00:26    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:12:00:26    Administrador    WINDOWSXP    Launch
2013/1/16:12:01:18    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/16:12:11:08    Administrador    WINDOWSXP    PageOpen    BeginDeploymentDialog
2013/1/16:12:11:25    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/16:12:11:54    Administrador    WINDOWSXP    PageOpen    LicenseDialog
2013/1/16:12:11:54    Administrador    WINDOWSXP    PageOpen    ProductSelectionDialog2
2013/1/16:12:12:19    Administrador    WINDOWSXP    PageOpen    LicenseDialog
2013/1/16:12:12:19    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/16:12:12:24    Administrador    WINDOWSXP    Su equipo utiliza una versión de Microsoft .NET Framework no compatible. El producto que va a instalar requiere Microsoft .NET Framework 4.0 o una versión posterior.
Actualice .NET Framework 4.0 y reinicie su equipo antes de instalar el producto de Autodesk.2013/1/16:12:12:43    Administrador    WINDOWSXP    === Setup ended ===
2013/1/16:12:41:46    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:12:41:46    Administrador    WINDOWSXP    Launch
2013/1/16:12:42:06    Administrador    WINDOWSXP    === Setup ended ===
2013/1/16:12:41:52    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:12:41:52    Administrador    WINDOWSXP    Launch
2013/1/16:12:42:07    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/16:12:42:11    Administrador    WINDOWSXP    PageOpen    LicenseDialog
2013/1/16:12:42:16    Administrador    WINDOWSXP    PageOpen    ProductInfoDialog
2013/1/16:12:44:05    Administrador    WINDOWSXP    PageOpen    ProductSelectionDialog2
2013/1/16:12:46:31    Administrador    WINDOWSXP    PageOpen    FullProgressDialog
2013/1/16:12:46:32    Administrador    WINDOWSXP    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): D:\software variado\Autodesk Architecture 2013 sp\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\vcredist_x86_2010.log
2013/1/16:12:46:46    Administrador    WINDOWSXP    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2013/1/16:12:46:46    Administrador    WINDOWSXP    Installing .NET Framework Runtime 4.0 KB2468871: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x86.exe /q /norestart
2013/1/16:13:01:40    Administrador    WINDOWSXP    Install    .NET Framework Runtime 4.0 KB2468871    Succeeded
2013/1/16:13:01:42    Administrador    WINDOWSXP    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\DOCUME~1\ADMINI~1\CONFIG~1\Temp\_AIB.tmp\x86\es-es\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=es-es ADSK_SOURCE_ROOT="D:\software variado\Autodesk Architecture 2013 sp\" INSTALLDIR="d:\Archivos de programa\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:13:01:54    Administrador    WINDOWSXP    Install    Autodesk® Design Review 2013    Failed    Failure is ignored, Result=1603
2013/1/16:13:01:54    Administrador    WINDOWSXP    Installing .NET Framework Runtime 4.0 Language Pack: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2013/1/16:13:04:31    Administrador    WINDOWSXP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2013/1/16:13:04:32    Administrador    WINDOWSXP    Rollback    .NET Framework Runtime 4.0 KB2468871    Failed    Installation aborted, Result=1619
2013/1/16:13:04:32    Administrador    WINDOWSXP    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2013/1/16:13:04:43    Administrador    WINDOWSXP    PageOpen    InstallCompleteDialog
2013/1/16:13:08:49    Administrador    WINDOWSXP    === Setup ended ===
2013/1/16:13:26:20    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:26:20    Administrador    WINDOWSXP    Launch
2013/1/16:13:26:40    Administrador    WINDOWSXP    === Setup ended ===
2013/1/16:13:26:24    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:26:24    Administrador    WINDOWSXP    Launch
2013/1/16:13:26:39    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/16:13:26:42    Administrador    WINDOWSXP    PageOpen    LicenseDialog
2013/1/16:13:26:47    Administrador    WINDOWSXP    PageOpen    ProductInfoDialog
2013/1/16:13:28:55    Administrador    WINDOWSXP    PageOpen    ProductSelectionDialog2
2013/1/16:13:30:19    Administrador    WINDOWSXP    PageOpen    FullProgressDialog
2013/1/16:13:30:19    Administrador    WINDOWSXP    Installing .NET Framework Runtime 4.0 Language Pack: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2013/1/16:13:32:40    Administrador    WINDOWSXP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2013/1/16:13:32:44    Administrador    WINDOWSXP    PageOpen    InstallCompleteDialog
2013/1/16:13:35:31    Administrador    WINDOWSXP    === Setup ended ===
2013/1/16:13:56:03    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:56:03    Administrador    WINDOWSXP    Launch
2013/1/16:13:56:25    Administrador    WINDOWSXP    === Setup ended ===
2013/1/16:13:56:10    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/16:13:56:10    Administrador    WINDOWSXP    Launch
2013/1/16:13:56:26    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/16:13:56:28    Administrador    WINDOWSXP    PageOpen    LicenseDialog
2013/1/16:13:56:32    Administrador    WINDOWSXP    PageOpen    ProductInfoDialog
2013/1/16:13:56:57    Administrador    WINDOWSXP    PageOpen    ProductSelectionDialog2
2013/1/16:13:57:58    Administrador    WINDOWSXP    PageOpen    FullProgressDialog
2013/1/16:13:57:58    Administrador    WINDOWSXP    Installing .NET Framework Runtime 4.0 Language Pack: D:\software variado\Autodesk Architecture 2013 sp\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2013/1/16:14:00:17    Administrador    WINDOWSXP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2013/1/16:14:00:21    Administrador    WINDOWSXP    PageOpen    InstallCompleteDialog
2013/1/16:14:00:36    Administrador    WINDOWSXP    === Setup ended ===
2013/1/22:12:55:54    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/22:12:55:54    Administrador    WINDOWSXP    Launch
2013/1/22:12:56:38    Administrador    WINDOWSXP    === Setup ended ===
2013/1/22:12:56:13    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/22:12:56:13    Administrador    WINDOWSXP    Launch
2013/1/22:12:56:38    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/22:12:56:47    Administrador    WINDOWSXP    PageOpen    LicenseDialog
2013/1/22:12:56:51    Administrador    WINDOWSXP    PageOpen    ProductInfoDialog
2013/1/22:12:57:41    Administrador    WINDOWSXP    PageOpen    ProductSelectionDialog2
2013/1/22:13:01:27    Administrador    WINDOWSXP    PageOpen    FullProgressDialog
2013/1/22:13:01:27    Administrador    WINDOWSXP    Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_ACA_2013_Spanish_Win_32bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2013/1/22:13:04:03    Administrador    WINDOWSXP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2013/1/22:13:04:17    Administrador    WINDOWSXP    PageOpen    InstallCompleteDialog
2013/1/22:13:04:33    Administrador    WINDOWSXP    === Setup ended ===
2013/1/22:17:02:31    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/22:17:02:31    Administrador    WINDOWSXP    Launch
2013/1/22:17:03:25    Administrador    WINDOWSXP    === Setup ended ===
2013/1/22:17:02:54    Administrador    WINDOWSXP    === Setup started on WINDOWSXP by Administrador ===
2013/1/22:17:02:54    Administrador    WINDOWSXP    Launch
2013/1/22:17:03:25    Administrador    WINDOWSXP    PageOpen    LaunchDialog
2013/1/22:17:04:17    Administrador    WINDOWSXP    PageOpen    LicenseDialog
2013/1/22:17:04:21    Administrador    WINDOWSXP    PageOpen    ProductInfoDialog
2013/1/22:17:04:57    Administrador    WINDOWSXP    PageOpen    ProductSelectionDialog2
2013/1/22:17:05:24    Administrador    WINDOWSXP    PageOpen    FullProgressDialog
2013/1/22:17:05:24    Administrador    WINDOWSXP    Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_ACA_2013_Spanish_Win_32bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1034.exe /q
2013/1/22:17:08:26    Administrador    WINDOWSXP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
Message 9 of 9
TravisNave
in reply to: 10166344
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
Administrator Productivity
