Installation error 2738 for AutoCAD 2012
I'm struggeling to install 2012 and keep getting the error 2738. I've searched the forum and tried everything. Can someone please help this is driving me MAD. Attached is the installation log file
Thanx
hashim.mundol
Please try this
http://upandready.typepad.com/up_and_ready/2011/07/error-2738-installation-could-not-access-vbscript...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Hello everyone. i know this problem and solution too ))) please fallow this steps.
first of all you have to delete the relevant registry entries and re-register the DLL.
Please make sure you back up the registry/system before you make any changes to the registry (how u can look at from microsft official site)
To delete the registry, please run following commands with elevated privileges
On Windows 7/64 bit System
1-) reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
2-) reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
u must delete both
optional if you have 32 bit win7
On Windows 7 32 bit
To Re-register the DLL please run following commands with elevated privileges
make copy+paste one by one
On Windows 7 64 bit System
c:\windows\syswow64\regsvr32 vbscript.dll
c:\windows\system32\regsvr32 vbscript.dll
On Windows 7 32 bit (optional for 32 bit win7)
this step is so important. if u want to solve then you have to trust me. If you had McAfee Antivirus in the past (even if you have unistalled it might leave some trace)
please use this tool to remove it completly.
http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
now intsall again. it will work, be sure )))) if you had activation problem after install then write me again. i know that slotion too...
Best Regard
Osman from Turkey
