Installation & Licensing
Installation error: 1606. Could not access network location setup
19 REPLIES 19
Message 1 of 20
cookml
6646 Views, 19 Replies
After migrating to a new Windows domain I received the following error:
"error: 1606. Could not access network location setup"
I have been unable to install and run Autocad LT 2011. I have confirmed that I have local administrative privileges I have uninstalled the application and completely removed it from the machine by deleting the necessary files and registry entries with no success.
The install is from local optical media and I have successfully used the disk for installation on another PC, there are 8 users license associated with this serial number, this means that the media is not damaged.
At this point any help would be appreciated.
19 REPLIES 19
Message 2 of 20
TravisNave
in reply to: cookml
Copy the media to a folder on your harddrive and install from there.  That should solve it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 20
cookml
in reply to: TravisNave
I copied the installation files to the local file system as sugested but unfortunatly continue to get Error: 1606. I also removed all the old installation folders that were created during the unssuccesful install and purged the temp installation log files and also attempted the install while being logged in locally with full administration rights, additionally both the firewall ,intrusion prevention and Antivirus software was disabled. A little bit frustrating to say the least.
Any new suggestions? anyone?
Message 4 of 20
TBat55
in reply to: cookml
Uninstall any AutoDesk products.
Delete any folders related to AutoCAD.
Run Regedit.  Click Find, enter "autocad".  Delete.  F3 to find again.  Repeat.  Delete all references.
                        Do it again for "autodesk".  Delete all references.
Exit the Registry and reboot.  Installation will work.
   ...except I had to browse to AcadltXX.msi (it's in the installation folder!)
Message 5 of 20
dembkod
in reply to: cookml
Cookml,
Hello. I would copy the contents of the disk to a folder on your drive, to eliminate the drive a s a source of conflict. Then delete the AutoCAD LT folders:
C:\Program Files\Autodesk\AutoCAD LT
C:\ProgramData\Autodesk\AutoCAD LT 2013
C:\ProgramData\Autodesk\ACDLT
C:\Users\All Users\ ACDLT
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\ACDLT
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\Autocad LT 2013
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\Autocad LT 2013
You will also want to rename your ADSKFLEX_*****_tsf.data file. It is located here:
C:\ProgramData\FLEXnet\
Now install and see if you receive the same message.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Message 6 of 20
3bplanproje
in reply to: dembkod
I did all off, but i see this error  "Installation error: 1606. Could not access network location setup" still
What can i do for tthis error
Message 7 of 20
TravisNave
in reply to: 3bplanproje
Disconnect your network cable.  See if it makes any difference.
Autodesk Forums:
Message 8 of 20
3bplanproje
in reply to: cookml
I did it, but nothing has changed, we paid money for this upgrade every year.
Message 9 of 20
TravisNave
So does everyone else.
Post your installation log file.  Let's see if there is anything in there that might be helpful.
Autodesk Forums:
Message 10 of 20
3bplanproje
in reply to: cookml
Installation log file?, There isn't log file, because I couldn't install.
Message 11 of 20
TravisNave
There's always a log.  Even on failed installs.
Autodesk Forums:
Message 12 of 20
Darin.Green
To get access to the temp files, open windows explorer and type %temp% in the address box and hit enter. This will take you to the temp directory. Sort the files by "Date Modifed" and you should see the log files.
If this information was helpful, please consider using the Accept Solution
Message 13 of 20
TravisNave
in reply to: Darin.Green
Thanks Darin.  I have been debating making an article describing these steps as well, since it is generally a common occurrence here.
Autodesk Forums:
Message 14 of 20
Darin.Green
Although we don't have the log files, it appears the issue is related to user directories being mapped to different locations. To check this, navigate within the registry to the following key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
If any of these paths are pointing to a different location other than the defaults begining with %USERPROFILE% then that would explain the issue. Change the modified path to the defaults which you can find attached:
Message 15 of 20
3bplanproje
in reply to: cookml
These are my log files
Message 16 of 20
3bplanproje
I sent the log files last week
I am waiting solution for this problem
Message 17 of 20
Darin.Green
Log out and log in with the Administrative account and try the installation again.
Message 18 of 20
edarchitect
I compared my "User Shell Folders" with your example and found two of them to be different.  They are "Cache" and "Cookies".  I'm wondering if these are really significant to the problem.  Would like your opinion before changing the registry.  I've attached a screen shot of my list.
Message 19 of 20
Darin.Green
in reply to: edarchitect
Not sure if the installation would be effected by those keys (Cache and Cookies) but they should also reflect the following:
Cache: %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
Cookies: %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
Let me know if this helps.
Message 20 of 20
ukdxb012
Administrator Productivity
