Hi
I've tried many hints and I still can't instal AutoCAD Mechanical 2015. I have install files on hard drive.
Things, which I've tried are listed below:
1) reinstalling net framework and visual c++,
2) edit setup.ini file (removing vcred, dotnet - according to posts on this forum),
3) installing as administrator with disabled UAC and anty-virus,
4) removing registry by CCleaner software
I still haven't found a solution. I'm attaching log from the install, maybe someone will help me. I suppose that there's no error due to net framework or visual c++. Log file shows, that installation for these files was succeeded. The error appears when installing ACAD. Please, correct me if I'm wrong.
This case is urgent due to my dissertation project. Could yoy please help me? š
2014/8/11:18:44:54 Administrator LAPTSON === Setup started on LAPTSON by Administrator === 2014/8/11:18:44:54 Administrator LAPTSON Path_Length: 157 2014/8/11:18:44:54 Administrator LAPTSON Current Directory D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm 2014/8/11:18:44:54 Administrator LAPTSON Launch 2014/8/11:18:44:54 Administrator LAPTSON CommandLine 2014/8/11:18:44:54 Administrator LAPTSON Path_Length: 157 2014/8/11:18:44:54 Administrator LAPTSON Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp 2014/8/11:18:44:58 Administrator LAPTSON === Setup ended === 2014/8/11:18:44:55 Administrator LAPTSON === Setup started on LAPTSON by Administrator === 2014/8/11:18:44:55 Administrator LAPTSON Path_Length: 157 2014/8/11:18:44:55 Administrator LAPTSON Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp 2014/8/11:18:44:55 Administrator LAPTSON Launch 2014/8/11:18:44:55 Administrator LAPTSON Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp\Setup\AcSetup.dll 2014/8/11:18:44:55 Administrator LAPTSON Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/8/11:18:44:57 Administrator LAPTSON Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=CBVaultInfoMessage CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI58F8.tmp\Setup\AcSetup.dll 2014/8/11:18:44:57 Administrator LAPTSON Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=If you are a Subscription Customer, you can download Vault Basic (server and client) from Autodesk Subscription Center. If you are not a Subscription Customer, you can download from: URLTitle=https://accounts.autodesk.com URLLink=https://accounts.autodesk.com 2014/8/11:18:44:58 Administrator LAPTSON PageOpen LaunchDialog 2014/8/11:18:45:03 Administrator LAPTSON === Setup ended === 2014/8/11:18:45:06 Administrator LAPTSON === Setup started on LAPTSON by Administrator === 2014/8/11:18:45:06 Administrator LAPTSON Path_Length: 157 2014/8/11:18:45:06 Administrator LAPTSON Current Directory D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm 2014/8/11:18:45:06 Administrator LAPTSON Launch 2014/8/11:18:45:06 Administrator LAPTSON CommandLine 2014/8/11:18:45:06 Administrator LAPTSON Path_Length: 157 2014/8/11:18:45:06 Administrator LAPTSON Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp 2014/8/11:18:45:07 Administrator LAPTSON === Setup ended === 2014/8/11:18:45:06 Administrator LAPTSON === Setup started on LAPTSON by Administrator === 2014/8/11:18:45:06 Administrator LAPTSON Path_Length: 157 2014/8/11:18:45:06 Administrator LAPTSON Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp 2014/8/11:18:45:06 Administrator LAPTSON Launch 2014/8/11:18:45:06 Administrator LAPTSON Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp\Setup\AcSetup.dll 2014/8/11:18:45:06 Administrator LAPTSON Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/8/11:18:45:07 Administrator LAPTSON Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=CBVaultInfoMessage CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp\Setup\AcSetup.dll 2014/8/11:18:45:07 Administrator LAPTSON Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=If you are a Subscription Customer, you can download Vault Basic (server and client) from Autodesk Subscription Center. If you are not a Subscription Customer, you can download from: URLTitle=https://accounts.autodesk.com URLLink=https://accounts.autodesk.com 2014/8/11:18:45:08 Administrator LAPTSON PageOpen LaunchDialog 2014/8/11:18:45:09 Administrator LAPTSON PageOpen LicenseDialog 2014/8/11:18:45:11 Administrator LAPTSON PageOpen ProductInfoDialog 2014/8/11:18:45:26 Administrator LAPTSON PageOpen ProductSelectionDialog2 2014/8/11:18:45:49 Administrator LAPTSON PageOpen FullProgressDialog 2014/8/11:18:45:49 Administrator LAPTSON Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/8/11:18:45:52 Administrator LAPTSON Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/8/11:18:45:52 Administrator LAPTSON Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/8/11:18:45:52 Administrator LAPTSON Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/8/11:18:45:52 Administrator LAPTSON Installing DirectX Runtime: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/8/11:18:46:00 Administrator LAPTSON Install DirectX Runtime Succeeded 2014/8/11:18:46:00 Administrator LAPTSON Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:46:20 Administrator LAPTSON Install Autodesk Material Library 2015 Succeeded 2014/8/11:18:46:20 Administrator LAPTSON Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:46:37 Administrator LAPTSON Install Autodesk Material Library 2015 - Base Image Library Succeeded 2014/8/11:18:46:38 Administrator LAPTSON Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:46:41 Administrator LAPTSON Install Autodesk Content Service Succeeded 2014/8/11:18:46:41 Administrator LAPTSON Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:46:42 Administrator LAPTSON Install Autodesk Content Service Language Pack Succeeded 2014/8/11:18:46:42 Administrator LAPTSON Installing AutodeskĀ® AutoCADĀ® Mechanical 2015: TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\acadm\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI86FD.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:50:03 Administrator LAPTSON Install AutodeskĀ® AutoCADĀ® Mechanical 2015 Failed Installation aborted, Result=1603 2014/8/11:18:50:04 Administrator LAPTSON Rollback Autodesk Content Service Language Pack Succeeded 2014/8/11:18:50:06 Administrator LAPTSON Rollback Autodesk Content Service Succeeded 2014/8/11:18:50:13 Administrator LAPTSON Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/8/11:18:50:27 Administrator LAPTSON Rollback Autodesk Material Library 2015 Succeeded 2014/8/11:18:50:27 Administrator LAPTSON Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/8/11:18:50:27 Administrator LAPTSON Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2014/8/11:18:50:27 Administrator LAPTSON Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619 2014/8/11:18:50:28 Administrator LAPTSON PageOpen InstallCompleteDialog 2014/8/11:18:51:56 Administrator LAPTSON === Setup ended === 2014/8/11:18:54:46 Administrator LAPTSON === Setup started on LAPTSON by Administrator === 2014/8/11:18:54:46 Administrator LAPTSON Path_Length: 157 2014/8/11:18:54:46 Administrator LAPTSON Current Directory D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm 2014/8/11:18:54:46 Administrator LAPTSON Launch 2014/8/11:18:54:46 Administrator LAPTSON CommandLine 2014/8/11:18:54:46 Administrator LAPTSON Path_Length: 157 2014/8/11:18:54:46 Administrator LAPTSON Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp 2014/8/11:18:54:48 Administrator LAPTSON === Setup ended === 2014/8/11:18:54:47 Administrator LAPTSON === Setup started on LAPTSON by Administrator === 2014/8/11:18:54:47 Administrator LAPTSON Path_Length: 157 2014/8/11:18:54:47 Administrator LAPTSON Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp 2014/8/11:18:54:47 Administrator LAPTSON Launch 2014/8/11:18:54:47 Administrator LAPTSON Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp\Setup\AcSetup.dll 2014/8/11:18:54:47 Administrator LAPTSON Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/8/11:18:54:48 Administrator LAPTSON Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=CBVaultInfoMessage CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp\Setup\AcSetup.dll 2014/8/11:18:54:48 Administrator LAPTSON Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=If you are a Subscription Customer, you can download Vault Basic (server and client) from Autodesk Subscription Center. If you are not a Subscription Customer, you can download from: URLTitle=https://accounts.autodesk.com URLLink=https://accounts.autodesk.com 2014/8/11:18:54:48 Administrator LAPTSON PageOpen LaunchDialog 2014/8/11:18:54:50 Administrator LAPTSON PageOpen LicenseDialog 2014/8/11:18:54:54 Administrator LAPTSON PageOpen ProductInfoDialog 2014/8/11:18:55:01 Administrator LAPTSON PageOpen ProductSelectionDialog2 2014/8/11:18:55:45 Administrator LAPTSON PageOpen FullProgressDialog 2014/8/11:18:55:45 Administrator LAPTSON Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log 2014/8/11:18:55:46 Administrator LAPTSON Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded 2014/8/11:18:55:46 Administrator LAPTSON Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log 2014/8/11:18:55:46 Administrator LAPTSON Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded 2014/8/11:18:55:46 Administrator LAPTSON Installing DirectX Runtime: "D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/8/11:18:55:50 Administrator LAPTSON Install DirectX Runtime Succeeded 2014/8/11:18:55:50 Administrator LAPTSON Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:55:56 Administrator LAPTSON Install Autodesk Material Library 2015 Succeeded 2014/8/11:18:55:56 Administrator LAPTSON Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:56:02 Administrator LAPTSON Install Autodesk Material Library 2015 - Base Image Library Succeeded 2014/8/11:18:56:02 Administrator LAPTSON Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:56:04 Administrator LAPTSON Install Autodesk Content Service Succeeded 2014/8/11:18:56:04 Administrator LAPTSON Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="AutodeskĀ® AutoCADĀ® Mechanical 2015" SETUP_PACKAGECODE={C5613D97-F129-48FF-AF9C-D072C27B3815} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:56:06 Administrator LAPTSON Install Autodesk Content Service Language Pack Succeeded 2014/8/11:18:56:06 Administrator LAPTSON Installing AutodeskĀ® AutoCADĀ® Mechanical 2015: TRANSFORMS="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\x64\en-us\acadm\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI62A1.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_Mechanical_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\CAD_CAE\AutoCAD Mechanical 2015\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/8/11:18:57:39 Administrator LAPTSON Install AutodeskĀ® AutoCADĀ® Mechanical 2015 Failed Installation aborted, Result=1603 2014/8/11:18:57:40 Administrator LAPTSON Rollback Autodesk Content Service Language Pack Succeeded 2014/8/11:18:57:41 Administrator LAPTSON Rollback Autodesk Content Service Succeeded 2014/8/11:18:57:47 Administrator LAPTSON Rollback Autodesk Material Library 2015 - Base Image Library Succeeded 2014/8/11:18:57:57 Administrator LAPTSON Rollback Autodesk Material Library 2015 Succeeded 2014/8/11:18:57:57 Administrator LAPTSON Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2014/8/11:18:57:57 Administrator LAPTSON Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619 2014/8/11:18:57:57 Administrator LAPTSON Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
Which drive is your D:\ drive?
Also, never use CCleaner. It is very bad.
"D" drive is not a system partition. Previously I've tried to install from "C" (system partition)
I haven't found a solution. Any ideas?
What about net framework? I'm afraid I might have a mess. What should I do for proper reinstalling? NET Framework Cleanup Tool didnt' delete net framework.
We are having same problem.
Tried massess of different 'solutions'.
Without antivirus, without UAC, creating deployment without service packs, creating deployment on different machines, making shorter deployment paths, uninstalling some windows updates, uninstaling net frameworks, modifying deployment, etc.....
And all the time we have the same problem.
Were you able to solve it ?
regards
miroko
