Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Installati on complete. Some products failed to install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618
Rollback FaroSDK Failed Failure is ignored, Result=1618
Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
This is the error I'm receiving when trying to install Revit 2013. Someone please help me because I need this for school. Thanks.
Re: Installati on complete. Some products failed to install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1618 means that the MSI Installer thinks another installation is already in progress. Did you start an install and then cancel it? Have you tried rebooting?
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Installati on complete. Some products failed to install
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did cancel it because it was taking so long...but I later realized that I didn't have enough disk space. So, I cleaned the disk space and I restarted my PC. I tried to install Revit 13 again and now I'm receiving this error:
Install Autodesk Revit 2013 Failed Download Failed, Installation aborted, Result=1603
Rollback FaroSDK Failed Failure is ignored, Result=1619
Rollback DirectX Runtime Failed Failure is ignored, Result=1619
