Installation & Licensing
Installation complete. Some products failed to install
2 REPLIES 2
gbr294
3894 Views, 2 Replies
Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618
Rollback FaroSDK Failed Failure is ignored, Result=1618
Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
This is the error I'm receiving when trying to install Revit 2013. Someone please help me because I need this for school. Thanks.
2 REPLIES 2
TravisNave
in reply to: gbr294
1618 means that the MSI Installer thinks another installation is already in progress.  Did you start an install and then cancel it?  Have you tried rebooting?
Autodesk Forums:
gbr294
in reply to: TravisNave
I did cancel it because it was taking so long...but I later realized that I didn't have enough disk space. So, I cleaned the disk space and I restarted my PC. I tried to install Revit 13 again and now I'm receiving this error:
Install Autodesk Revit 2013  Failed Download Failed, Installation aborted, Result=1603
Rollback FaroSDK                Failed Failure is ignored, Result=1619
Rollback DirectX Runtime     Failed Failure is ignored, Result=1619
Administrator Productivity
