2014/4/1:17:48:04 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:17:48:04 Warhead DUSTIN Path_Length: 151 2014/4/1:17:48:04 Warhead DUSTIN Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/4/1:17:48:04 Warhead DUSTIN Launch 2014/4/1:17:48:04 Warhead DUSTIN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/4/1:17:48:04 Warhead DUSTIN Path_Length: 151 2014/4/1:17:48:04 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI4EC5.tmp 2014/4/1:17:48:52 Warhead DUSTIN === Setup ended ===
2014/4/1:17:48:05 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:17:48:05 Warhead DUSTIN Path_Length: 151 2014/4/1:17:48:05 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI4EC5.tmp 2014/4/1:17:48:05 Warhead DUSTIN Launch 2014/4/1:17:48:40 Warhead DUSTIN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/1:17:48:52 Warhead DUSTIN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/1:17:48:52 Warhead DUSTIN PageOpen LaunchDialog 2014/4/1:17:49:00 Warhead DUSTIN PageOpen LicenseDialog 2014/4/1:17:49:00 Warhead DUSTIN PageOpen ProductInfoDialog 2014/4/1:17:49:18 Warhead DUSTIN PageOpen ProductSelectionDialog2 2014/4/1:17:49:30 Warhead DUSTIN PageOpen FullProgressDialog 2014/4/1:17:49:32 Warhead DUSTIN Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:17:49:36 Warhead DUSTIN Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:17:49:36 Warhead DUSTIN Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q 2014/4/1:17:49:54 Warhead DUSTIN Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2014/4/1:17:49:55 Warhead DUSTIN Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:17:49:58 Warhead DUSTIN Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:17:49:58 Warhead DUSTIN Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Warhead\AppData\Local\Temp\vcredist_x64_2005.log"" " 2014/4/1:17:50:19 Warhead DUSTIN Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded 2014/4/1:17:50:19 Warhead DUSTIN Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:17:50:23 Warhead DUSTIN Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:17:50:23 Warhead DUSTIN Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q 2014/4/1:17:50:44 Warhead DUSTIN Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2014/4/1:17:50:45 Warhead DUSTIN Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/1:17:51:48 Warhead DUSTIN Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/1:17:51:48 Warhead DUSTIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/4/1:17:52:17 Warhead DUSTIN Install DirectX® Runtime Succeeded 2014/4/1:17:52:18 Warhead DUSTIN Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:17:58:54 Warhead DUSTIN Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:17:58:54 Warhead DUSTIN Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603 2014/4/1:17:58:54 Warhead DUSTIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/4/1:17:58:55 Warhead DUSTIN PageOpen InstallCompleteDialog 2014/4/1:18:11:22 Warhead DUSTIN === Setup ended ===
2014/4/1:18:27:40 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:18:27:40 Warhead DUSTIN Path_Length: 151 2014/4/1:18:27:40 Warhead DUSTIN Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/4/1:18:27:40 Warhead DUSTIN Launch 2014/4/1:18:27:40 Warhead DUSTIN CommandLine 2014/4/1:18:27:40 Warhead DUSTIN Path_Length: 151 2014/4/1:18:27:40 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI90D0.tmp 2014/4/1:18:27:43 Warhead DUSTIN === Setup ended ===
2014/4/1:18:27:41 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:18:27:41 Warhead DUSTIN Path_Length: 151 2014/4/1:18:27:41 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI90D0.tmp 2014/4/1:18:27:41 Warhead DUSTIN Launch 2014/4/1:18:27:44 Warhead DUSTIN === Setup ended ===
2014/4/1:18:32:12 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:18:32:12 Warhead DUSTIN Path_Length: 151 2014/4/1:18:32:12 Warhead DUSTIN Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/4/1:18:32:12 Warhead DUSTIN Launch 2014/4/1:18:32:12 Warhead DUSTIN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/4/1:18:32:12 Warhead DUSTIN Path_Length: 151 2014/4/1:18:32:12 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AIB4A0.tmp 2014/4/1:18:32:13 Warhead DUSTIN === Setup ended ===
2014/4/1:18:32:12 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:18:32:12 Warhead DUSTIN Path_Length: 151 2014/4/1:18:32:12 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AIB4A0.tmp 2014/4/1:18:32:12 Warhead DUSTIN Launch 2014/4/1:18:32:13 Warhead DUSTIN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/1:18:32:13 Warhead DUSTIN PageOpen LaunchDialog 2014/4/1:18:32:42 Warhead DUSTIN PageOpen LicenseDialog 2014/4/1:18:32:42 Warhead DUSTIN PageOpen ProductInfoDialog 2014/4/1:18:32:46 Warhead DUSTIN PageOpen ProductSelectionDialog2 2014/4/1:18:32:56 Warhead DUSTIN PageOpen FullProgressDialog 2014/4/1:18:32:57 Warhead DUSTIN Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/1:18:32:57 Warhead DUSTIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/4/1:18:33:11 Warhead DUSTIN Install DirectX® Runtime Succeeded 2014/4/1:18:33:12 Warhead DUSTIN Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:18:41:17 Warhead DUSTIN Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:18:41:17 Warhead DUSTIN Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603 2014/4/1:18:41:17 Warhead DUSTIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/4/1:18:41:18 Warhead DUSTIN PageOpen InstallCompleteDialog 2014/4/1:18:42:51 Warhead DUSTIN === Setup ended ===
2014/4/1:20:19:35 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:20:19:35 Warhead DUSTIN Path_Length: 151 2014/4/1:20:19:35 Warhead DUSTIN Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/4/1:20:19:35 Warhead DUSTIN Launch 2014/4/1:20:19:35 Warhead DUSTIN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/4/1:20:19:35 Warhead DUSTIN Path_Length: 151 2014/4/1:20:19:35 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI5B2.tmp 2014/4/1:20:19:36 Warhead DUSTIN === Setup ended ===
2014/4/1:20:19:35 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:20:19:35 Warhead DUSTIN Path_Length: 151 2014/4/1:20:19:35 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI5B2.tmp 2014/4/1:20:19:35 Warhead DUSTIN Launch 2014/4/1:20:19:36 Warhead DUSTIN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/1:20:19:36 Warhead DUSTIN PageOpen LaunchDialog 2014/4/1:20:19:38 Warhead DUSTIN PageOpen LicenseDialog 2014/4/1:20:19:38 Warhead DUSTIN PageOpen ProductSelectionDialog2 2014/4/1:20:19:42 Warhead DUSTIN PageOpen LicenseDialog 2014/4/1:20:19:42 Warhead DUSTIN PageOpen LaunchDialog 2014/4/1:20:19:45 Warhead DUSTIN PageOpen LicenseDialog 2014/4/1:20:19:45 Warhead DUSTIN PageOpen ProductInfoDialog 2014/4/1:20:19:48 Warhead DUSTIN PageOpen ProductSelectionDialog2 2014/4/1:20:19:52 Warhead DUSTIN PageOpen FullProgressDialog 2014/4/1:20:19:53 Warhead DUSTIN Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:20:19:55 Warhead DUSTIN Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200... 2014/4/1:20:19:55 Warhead DUSTIN Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Warhead\AppData\Local\Temp\vcredist_x86_2005.log"" " 2014/4/1:20:20:11 Warhead DUSTIN Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded 2014/4/1:20:20:11 Warhead DUSTIN Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/1:20:20:11 Warhead DUSTIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/4/1:20:20:30 Warhead DUSTIN Install DirectX® Runtime Succeeded 2014/4/1:20:20:31 Warhead DUSTIN Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:20:28:21 Warhead DUSTIN Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:20:28:21 Warhead DUSTIN Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603 2014/4/1:20:28:21 Warhead DUSTIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/4/1:20:28:21 Warhead DUSTIN PageOpen InstallCompleteDialog 2014/4/1:20:31:05 Warhead DUSTIN === Setup ended ===
2014/4/1:21:06:48 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:21:06:48 Warhead DUSTIN Path_Length: 151 2014/4/1:21:06:48 Warhead DUSTIN Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/4/1:21:06:48 Warhead DUSTIN Launch 2014/4/1:21:06:48 Warhead DUSTIN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/4/1:21:06:48 Warhead DUSTIN Path_Length: 151 2014/4/1:21:06:48 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI3DF7.tmp 2014/4/1:21:06:57 Warhead DUSTIN === Setup ended ===
2014/4/1:21:06:48 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/1:21:06:48 Warhead DUSTIN Path_Length: 151 2014/4/1:21:06:48 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AI3DF7.tmp 2014/4/1:21:06:48 Warhead DUSTIN Launch 2014/4/1:21:06:49 Warhead DUSTIN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/1:21:06:57 Warhead DUSTIN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/1:21:06:57 Warhead DUSTIN PageOpen LaunchDialog 2014/4/1:21:07:20 Warhead DUSTIN PageOpen LicenseDialog 2014/4/1:21:07:20 Warhead DUSTIN PageOpen ProductInfoDialog 2014/4/1:21:07:26 Warhead DUSTIN PageOpen ProductSelectionDialog2 2014/4/1:21:08:03 Warhead DUSTIN PageOpen FullProgressDialog 2014/4/1:21:08:04 Warhead DUSTIN Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/1:21:08:39 Warhead DUSTIN Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/1:21:08:39 Warhead DUSTIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/4/1:21:08:57 Warhead DUSTIN Install DirectX® Runtime Succeeded 2014/4/1:21:08:58 Warhead DUSTIN Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:21:14:43 Warhead DUSTIN Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/1:21:14:43 Warhead DUSTIN Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603 2014/4/1:21:14:43 Warhead DUSTIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/4/1:21:14:43 Warhead DUSTIN PageOpen InstallCompleteDialog 2014/4/1:21:15:35 Warhead DUSTIN === Setup ended ===
2014/4/2:08:12:09 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/2:08:12:09 Warhead DUSTIN Path_Length: 151 2014/4/2:08:12:09 Warhead DUSTIN Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US 2014/4/2:08:12:09 Warhead DUSTIN Launch 2014/4/2:08:12:09 Warhead DUSTIN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/4/2:08:12:09 Warhead DUSTIN Path_Length: 151 2014/4/2:08:12:09 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AIACD3.tmp 2014/4/2:08:12:18 Warhead DUSTIN === Setup ended ===
2014/4/2:08:12:10 Warhead DUSTIN === Setup started on DUSTIN by Warhead === 2014/4/2:08:12:10 Warhead DUSTIN Path_Length: 151 2014/4/2:08:12:10 Warhead DUSTIN Current Directory C:\Users\Warhead\AppData\Local\Temp\_AIACD3.tmp 2014/4/2:08:12:10 Warhead DUSTIN Launch 2014/4/2:08:12:11 Warhead DUSTIN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/2:08:12:17 Warhead DUSTIN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t... 2014/4/2:08:12:18 Warhead DUSTIN PageOpen LaunchDialog 2014/4/2:08:13:23 Warhead DUSTIN PageOpen LicenseDialog 2014/4/2:08:13:23 Warhead DUSTIN PageOpen ProductSelectionDialog2 2014/4/2:08:13:29 Warhead DUSTIN PageOpen LicenseDialog 2014/4/2:08:13:29 Warhead DUSTIN PageOpen LaunchDialog 2014/4/2:08:13:31 Warhead DUSTIN PageOpen LicenseDialog 2014/4/2:08:13:31 Warhead DUSTIN PageOpen ProductInfoDialog 2014/4/2:08:13:39 Warhead DUSTIN PageOpen ProductSelectionDialog2 2014/4/2:08:14:17 Warhead DUSTIN PageOpen FullProgressDialog 2014/4/2:08:14:17 Warhead DUSTIN Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/2:08:14:45 Warhead DUSTIN Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar... 2014/4/2:08:14:45 Warhead DUSTIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent 2014/4/2:08:15:19 Warhead DUSTIN Install DirectX® Runtime Succeeded 2014/4/2:08:15:20 Warhead DUSTIN Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/2:08:18:55 Warhead DUSTIN Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.... 2014/4/2:08:18:55 Warhead DUSTIN Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603 2014/4/2:08:18:56 Warhead DUSTIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Installation Log file ^
This shows up on the Autodesk Maya 2014
FAILED X Autodesk Maya 2014
An error occurred while installing this product, For more information view the (Installation Log file)
X Mental ray renderer for Autodesk Maya 2014
X Autodesk MatchMover 2014
X Autodesk Composite 2014
X Autodesk backburner 2014
X Autodesk DirectConnect 2014
Download the latest SP and install it as a trail from there....
