Installation & Licensing
New Member
bodiroga89
Message 1 of 3 (793 Views)
Installation complete. Some products failed to install. Please help :/
793 Views, 2 Replies
02-28-2013 03:21 AM
I tried to uninstall c ++, and .NET also but still get this message. Please help. Thank you. Here is the log:
2013/2/28:10:15:35    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:15:35    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:16:14    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:15:39    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:15:39    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:16:14    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:10:16:42    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:10:16:58    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:10:23:08    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:10:23:52    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:10:23:52    Dejan#4    DEJAN4-PC    Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:10:26:29    Dejan#4    DEJAN4-PC    Install    .NET Framework Runtime 4.0    Succeeded
2013/2/28:10:26:29    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:26:53    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:10:26:53    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:10:27:04    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:10:27:05    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI65F3.tmp\Media.mst"
 2013/2/28:10:27:21    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:10:27:23    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI65F3.tmp\Media.mst"
 2013/2/28:10:27:45    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:27:45    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:27:47    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:10:27:58    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:28:08    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    Rollback    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1619
2013/2/28:10:28:11    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:10:28:35    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:30:25    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:30:25    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:30:30    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:30:26    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:30:26    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:30:29    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:10:30:45    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:10:31:04    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:10:32:07    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:10:32:42    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:10:32:42    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:32:59    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:10:32:59    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:10:33:07    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:10:33:08    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIF077.tmp\Media.mst"
 2013/2/28:10:33:18    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:10:33:21    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIF077.tmp\Media.mst"
 2013/2/28:10:33:41    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:33:41    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:33:41    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:10:33:56    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:34:07    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:10:34:09    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:10:34:09    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:10:34:09    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:10:41:27    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:42:01    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:10:42:01    Dejan#4    DEJAN4-PC    Launch
2013/2/28:10:42:07    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:10:42:06    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:10:42:13    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:10:42:19    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:10:42:45    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:10:42:56    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:10:42:56    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:10:43:14    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:10:43:14    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:10:43:22    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:10:43:23    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI9B07.tmp\Media.mst"
 2013/2/28:10:43:33    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:10:43:33    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI9B07.tmp\Media.mst"
 2013/2/28:10:43:55    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:43:55    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:10:43:55    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:10:44:08    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:10:44:18    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:10:44:20    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:10:44:20    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:10:44:20    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:10:44:43    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:02:45    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:02:45    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:03:29    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:02:50    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:02:50    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:03:29    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:03:38    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:03:49    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:04:19    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:04:23    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:04:23    Dejan#4    DEJAN4-PC    Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:11:05:45    Dejan#4    DEJAN4-PC    Install    .NET Framework Runtime 4.0    Succeeded
2013/2/28:11:05:45    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:06:14    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:06:14    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:06:23    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:06:23    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI41C0.tmp\Media.mst"
 2013/2/28:11:06:38    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:06:38    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI41C0.tmp\Media.mst"
 2013/2/28:11:07:02    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:07:02    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:07:03    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:07:17    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:07:28    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:07:31    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:07:31    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:07:31    Dejan#4    DEJAN4-PC    Rollback    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1619
2013/2/28:11:07:32    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:15:50    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:16:28    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:16:28    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:16:34    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:16:29    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:16:29    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:16:34    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:16:41    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:16:47    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:17:12    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:17:15    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:17:16    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:17:34    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:17:34    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:17:47    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:17:48    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AID21D.tmp\Media.mst"
 2013/2/28:11:17:59    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:18:03    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AID21D.tmp\Media.mst"
 2013/2/28:11:18:24    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:18:24    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:18:24    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:18:40    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:18:51    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:18:53    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:18:53    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:18:53    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:23:00    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:23:22    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:23:22    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:23:28    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:23:23    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:23:23    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:23:28    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:23:35    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:23:40    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:24:00    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:24:07    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:24:07    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:24:25    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:24:25    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:24:33    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:24:34    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI2480.tmp\Media.mst"
 2013/2/28:11:24:44    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:24:47    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI2480.tmp\Media.mst"
 2013/2/28:11:25:07    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:25:07    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:25:08    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:25:22    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:25:33    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:25:35    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:25:35    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:25:35    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:25:43    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:28:27    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:28:27    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:28:33    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:28:28    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:28:28    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:28:33    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:28:43    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:28:47    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:28:57    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:28:59    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:28:59    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:29:18    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:29:18    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:29:26    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:29:28    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AICB5A.tmp\Media.mst"
 2013/2/28:11:29:38    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:29:40    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AICB5A.tmp\Media.mst"
 2013/2/28:11:30:02    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:30:02    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:30:02    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:30:15    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:30:25    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:30:27    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:30:27    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:30:27    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:33:22    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:33:28    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:33:28    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:33:34    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:33:29    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:33:29    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:33:34    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:33:40    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:33:45    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:33:53    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:33:55    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:33:55    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/28:11:34:08    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2013/2/28:11:34:08    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:34:27    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:34:27    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:34:35    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:34:36    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI5C43.tmp\Media.mst"
 2013/2/28:11:34:48    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:34:51    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AI5C43.tmp\Media.mst"
 2013/2/28:11:35:12    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:35:12    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:35:13    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:35:27    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:35:39    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:35:41    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:35:41    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:11:35:41    Dejan#4    DEJAN4-PC    PageOpen    InstallCompleteDialog
2013/2/28:11:35:59    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:41:29    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:41:29    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:41:37    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:41:30    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:41:30    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:41:35    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:41:39    Dejan#4    DEJAN4-PC    You are attempting to use a 64-bit installer on a 32-bit operating system.
Please exit and use the 32-bit installer available from your installation media or from Autodesk.com.2013/2/28:11:41:50    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:54:30    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:54:30    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:55:23    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:11:54:36    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:11:54:36    Dejan#4    DEJAN4-PC    Launch
2013/2/28:11:55:23    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:11:55:33    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:11:55:44    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:56:06    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:56:27    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:11:56:39    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:11:56:56    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:11:56:56    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:11:57:22    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:11:57:22    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:11:57:37    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:11:57:37    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIA332.tmp\Media.mst"
 2013/2/28:11:57:54    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:11:57:56    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIA332.tmp\Media.mst"
 2013/2/28:11:58:16    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:58:16    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:11:58:18    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:11:58:30    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:11:58:40    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:11:58:42    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:11:58:42    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:12:08:19    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:12:08:19    Dejan#4    DEJAN4-PC    Launch
2013/2/28:12:09:04    Dejan#4    DEJAN4-PC    === Setup ended ===
2013/2/28:12:08:24    Dejan#4    DEJAN4-PC    === Setup started on DEJAN4-PC by Dejan#4 ===
2013/2/28:12:08:24    Dejan#4    DEJAN4-PC    Launch
2013/2/28:12:09:04    Dejan#4    DEJAN4-PC    PageOpen    LaunchDialog
2013/2/28:12:09:34    Dejan#4    DEJAN4-PC    PageOpen    LicenseDialog
2013/2/28:12:09:39    Dejan#4    DEJAN4-PC    PageOpen    ProductInfoDialog
2013/2/28:12:09:52    Dejan#4    DEJAN4-PC    PageOpen    ProductSelectionDialog2
2013/2/28:12:09:56    Dejan#4    DEJAN4-PC    PageOpen    FullProgressDialog
2013/2/28:12:09:57    Dejan#4    DEJAN4-PC    Installing .NET Framework Runtime 4.0: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/2/28:12:13:06    Dejan#4    DEJAN4-PC    Install    .NET Framework Runtime 4.0    Succeeded
2013/2/28:12:13:06    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/28:12:13:24    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2013/2/28:12:13:24    Dejan#4    DEJAN4-PC    Installing DirectX Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/28:12:13:53    Dejan#4    DEJAN4-PC    Install    DirectX Runtime    Succeeded
2013/2/28:12:13:53    Dejan#4    DEJAN4-PC    Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/2/28:12:14:05    Dejan#4    DEJAN4-PC    Install    FaroSDK    Succeeded
2013/2/28:12:14:06    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIDFA4.tmp\Media.mst"
 2013/2/28:12:14:24    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012    Succeeded
2013/2/28:12:14:26    Dejan#4    DEJAN4-PC    Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Dejan#4\AppData\Local\Temp\_AIDFA4.tmp\Media.mst"
 2013/2/28:12:14:50    Dejan#4    DEJAN4-PC    Install    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:12:14:50    Dejan#4    DEJAN4-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dejan#4\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/2/28:12:14:53    Dejan#4    DEJAN4-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2013/2/28:12:15:06    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012 - Low Resolution    Succeeded
2013/2/28:12:15:18    Dejan#4    DEJAN4-PC    Rollback    Autodesk Material Library 2012    Succeeded
2013/2/28:12:15:20    Dejan#4    DEJAN4-PC    Rollback    FaroSDK    Succeeded
2013/2/28:12:15:20    Dejan#4    DEJAN4-PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/2/28:12:15:20    Dejan#4    DEJAN4-PC    Rollback    .NET Framework Runtime 4.0    Failed    Installation aborted, Result=1619
Product Support
david.lau
Message 2 of 3 (745 Views)
Re: Installation complete. Some products failed to install. Please help :/
03-01-2013 01:01 PM in reply to: bodiroga89
TravisNave
Message 3 of 3 (677 Views)
03-04-2013 08:45 AM in reply to: bodiroga89
If uninstalling the offending program and reinstalling does not solve the problem, then install the prereq direct from Microsoft and then edit the setup.ini to ignore the prerequisite check.  I have instructions on my follow-up post at this link:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
