Installation & Licensing
Installation autocad 2015 on windows 8.1
5 REPLIES 5
5126 Views, 5 Replies
Hi I am running a windows 8.1 toshiba p-255t-a and I have been trying to install autocad using free student software. I receive an error when trying to install. I have tried all three download methods. I have net 3.5 activated already. It says the installation location has changed, have closed the link from download or the firewall has blocked the download in the error message. None of these are true to my understanding. My firewall is off. Here is the installation log. I am not sure what I am doing wrong. I saw someone with a similar error but the resolution did not work for me.
2014/3/27:22:28:42 jhill_000 JOSH Path_Length: 157
2014/3/27:22:28:42 jhill_000 JOSH Current Directory F:
2014/3/27:22:28:42 jhill_000 JOSH Launch
2014/3/27:22:28:42 jhill_000 JOSH CommandLine
2014/3/27:22:28:42 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp
2014/3/27:22:29:01 jhill_000 JOSH === Setup ended ===
2014/3/27:22:28:48 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/3/27:22:28:48 jhill_000 JOSH Path_Length: 157
2014/3/27:22:28:48 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp
2014/3/27:22:28:48 jhill_000 JOSH Launch
2014/3/27:22:28:48 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp\Setup\AcSetup.dll
2014/3/27:22:28:48 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/27:22:29:01 jhill_000 JOSH PageOpen LaunchDialog
2014/3/27:22:29:03 jhill_000 JOSH PageOpen LicenseDialog
2014/3/27:22:29:07 jhill_000 JOSH PageOpen ProductInfoDialog
2014/3/27:22:29:41 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/3/27:22:29:49 jhill_000 JOSH PageOpen FullProgressDialog
2014/3/27:22:29:50 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "F:\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/3/27:22:30:55 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/3/27:22:30:55 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "F:\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/3/27:22:30:57 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/3/27:22:30:57 jhill_000 JOSH Installing DirectX Runtime: "F:\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/27:22:31:25 jhill_000 JOSH Install DirectX Runtime Succeeded
2014/3/27:22:31:26 jhill_000 JOSH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp\Media.mst"
2014/3/27:22:32:41 jhill_000 JOSH Install Autodesk Material Library 2015 Succeeded
2014/3/27:22:32:41 jhill_000 JOSH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp\Media.mst"
2014/3/27:22:34:09 jhill_000 JOSH Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/3/27:22:34:17 jhill_000 JOSH Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=F:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/27:22:34:35 jhill_000 JOSH Install Autodesk Content Service Succeeded
2014/3/27:22:34:36 jhill_000 JOSH Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp\Media.mst"
2014/3/27:22:34:42 jhill_000 JOSH Install Autodesk Content Service Language Pack Succeeded
2014/3/27:22:34:42 jhill_000 JOSH Installing Autodesk® AutoCAD® 2015: TRANSFORMS="F:\x64\en-us\acad\acad.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AIEE65.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/27:22:41:19 jhill_000 JOSH Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/3/27:22:41:27 jhill_000 JOSH Rollback Autodesk Content Service Language Pack Succeeded
2014/3/27:22:41:45 jhill_000 JOSH Rollback Autodesk Content Service Succeeded
2014/3/27:22:41:52 jhill_000 JOSH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/3/27:22:42:37 jhill_000 JOSH Rollback Autodesk Material Library 2015 Succeeded
2014/3/27:22:42:37 jhill_000 JOSH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/3/27:22:42:37 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/3/27:22:42:37 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/3/27:22:42:39 jhill_000 JOSH PageOpen InstallCompleteDialog
2014/3/27:22:44:39 jhill_000 JOSH === Setup ended ===
2014/3/27:22:51:41 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/3/27:22:51:41 jhill_000 JOSH Path_Length: 157
2014/3/27:22:51:41 jhill_000 JOSH Current Directory C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~
2014/3/27:22:51:41 jhill_000 JOSH Launch
2014/3/27:22:51:41 jhill_000 JOSH CommandLine
2014/3/27:22:51:41 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIF777.tmp
2014/3/27:22:52:00 jhill_000 JOSH === Setup ended ===
2014/3/27:22:51:47 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/3/27:22:51:47 jhill_000 JOSH Path_Length: 157
2014/3/27:22:51:47 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIF777.tmp
2014/3/27:22:51:47 jhill_000 JOSH Launch
2014/3/27:22:51:47 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AIF777.tmp\Setup\AcSetup.dll
2014/3/27:22:51:47 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/27:22:51:56 jhill_000 JOSH PageOpen LaunchDialog
2014/3/27:22:52:06 jhill_000 JOSH PageOpen LicenseDialog
2014/3/27:22:52:10 jhill_000 JOSH PageOpen ProductInfoDialog
2014/3/27:22:52:19 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/3/27:22:52:21 jhill_000 JOSH PageOpen FullProgressDialog
2014/3/27:22:52:22 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/3/27:22:52:26 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/3/27:22:52:26 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/3/27:22:52:28 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/3/27:22:52:28 jhill_000 JOSH Installing DirectX Runtime: "C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/27:22:52:46 jhill_000 JOSH Install DirectX Runtime Succeeded
2014/3/27:22:52:46 jhill_000 JOSH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/27:22:53:43 jhill_000 JOSH Install Autodesk Material Library 2015 Succeeded
2014/3/27:22:53:44 jhill_000 JOSH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/27:22:54:39 jhill_000 JOSH Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/3/27:22:54:40 jhill_000 JOSH Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/27:22:54:54 jhill_000 JOSH Install Autodesk Content Service Succeeded
2014/3/27:22:54:54 jhill_000 JOSH Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/27:22:54:58 jhill_000 JOSH Install Autodesk Content Service Language Pack Succeeded
2014/3/27:22:54:58 jhill_000 JOSH Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\x64\en-us\acad\acad.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AIF777.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\jhill_000\Downloads\AUTODESK.AUTOCAD.V2015.WIN64-ISO[rarbg]\ISOS~\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/27:22:59:45 jhill_000 JOSH Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/3/27:22:59:49 jhill_000 JOSH Rollback Autodesk Content Service Language Pack Succeeded
2014/3/27:22:59:59 jhill_000 JOSH Rollback Autodesk Content Service Succeeded
2014/3/27:23:00:07 jhill_000 JOSH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/3/27:23:00:45 jhill_000 JOSH Rollback Autodesk Material Library 2015 Succeeded
2014/3/27:23:00:45 jhill_000 JOSH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/3/27:23:00:45 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/3/27:23:00:45 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/3/27:23:00:47 jhill_000 JOSH PageOpen InstallCompleteDialog
2014/3/27:23:03:26 jhill_000 JOSH === Setup ended ===
2014/4/23:09:16:12 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/23:09:16:12 jhill_000 JOSH Path_Length: 157
2014/4/23:09:16:12 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_wi_en-us
2014/4/23:09:16:12 jhill_000 JOSH Launch
2014/4/23:09:16:12 jhill_000 JOSH CommandLine
2014/4/23:09:16:12 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIB715.tmp
2014/4/23:09:16:27 jhill_000 JOSH === Setup ended ===
2014/4/26:20:03:32 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:03:32 jhill_000 JOSH Path_Length: 157
2014/4/26:20:03:32 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm
2014/4/26:20:03:32 jhill_000 JOSH Launch
2014/4/26:20:03:32 jhill_000 JOSH CommandLine
2014/4/26:20:03:32 jhill_000 JOSH Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/4/26:20:05:01 jhill_000 JOSH Path_Length: 157
2014/4/26:20:05:01 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI6F06.tmp
2014/4/26:20:05:11 jhill_000 JOSH === Setup ended ===
2014/4/26:20:05:05 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:05:05 jhill_000 JOSH Path_Length: 157
2014/4/26:20:05:05 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI6F06.tmp
2014/4/26:20:05:05 jhill_000 JOSH Launch
2014/4/26:20:05:06 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AI6F06.tmp\Setup\AcSetup.dll
2014/4/26:20:05:06 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/26:20:05:11 jhill_000 JOSH PageOpen LaunchDialog
2014/4/26:20:05:14 jhill_000 JOSH PageOpen LicenseDialog
2014/4/26:20:05:19 jhill_000 JOSH PageOpen ProductInfoDialog
2014/4/26:20:06:04 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/4/26:20:06:18 jhill_000 JOSH PageOpen FullProgressDialog
2014/4/26:20:06:18 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/4/26:20:07:07 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/4/26:20:07:07 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/4/26:20:07:40 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/4/26:20:07:40 jhill_000 JOSH Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/26:20:08:10 jhill_000 JOSH Install DirectX Runtime Succeeded
2014/4/26:20:08:11 jhill_000 JOSH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:20:09:06 jhill_000 JOSH Install Autodesk Material Library 2015 Succeeded
2014/4/26:20:09:06 jhill_000 JOSH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:20:10:23 jhill_000 JOSH Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:20:10:23 jhill_000 JOSH Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:20:10:46 jhill_000 JOSH Install Autodesk Content Service Succeeded
2014/4/26:20:10:46 jhill_000 JOSH Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:20:11:01 jhill_000 JOSH Install Autodesk Content Service Language Pack Succeeded
2014/4/26:20:11:11 jhill_000 JOSH Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AI6F06.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:20:18:47 jhill_000 JOSH Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/4/26:20:18:52 jhill_000 JOSH Rollback Autodesk Content Service Language Pack Succeeded
2014/4/26:20:19:10 jhill_000 JOSH Rollback Autodesk Content Service Succeeded
2014/4/26:20:19:16 jhill_000 JOSH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:20:19:59 jhill_000 JOSH Rollback Autodesk Material Library 2015 Succeeded
2014/4/26:20:20:00 jhill_000 JOSH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/4/26:20:20:00 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:20:20:00 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:20:20:04 jhill_000 JOSH PageOpen InstallCompleteDialog
2014/4/26:20:28:47 jhill_000 JOSH === Setup ended ===
2014/4/26:20:34:47 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:34:47 jhill_000 JOSH Path_Length: 157
2014/4/26:20:34:47 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIFEEA.tmp
2014/4/26:20:34:47 jhill_000 JOSH Launch
2014/4/26:20:34:56 jhill_000 JOSH === Setup ended ===
2014/4/26:20:34:43 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:34:43 jhill_000 JOSH Path_Length: 157
2014/4/26:20:34:43 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_wi_en-us
2014/4/26:20:34:43 jhill_000 JOSH Launch
2014/4/26:20:34:43 jhill_000 JOSH CommandLine
2014/4/26:20:34:43 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIFEEA.tmp
2014/4/26:20:34:58 jhill_000 JOSH === Setup ended ===
2014/4/26:20:35:56 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:35:56 jhill_000 JOSH Path_Length: 157
2014/4/26:20:35:56 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI13E4.tmp
2014/4/26:20:35:56 jhill_000 JOSH Launch
2014/4/26:20:36:15 jhill_000 JOSH === Setup ended ===
2014/4/26:20:35:54 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:35:54 jhill_000 JOSH Path_Length: 157
2014/4/26:20:35:54 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_wi_en-us
2014/4/26:20:35:54 jhill_000 JOSH Launch
2014/4/26:20:35:54 jhill_000 JOSH CommandLine
2014/4/26:20:35:54 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI13E4.tmp
2014/4/26:20:56:15 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:56:15 jhill_000 JOSH Path_Length: 157
2014/4/26:20:56:15 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm
2014/4/26:20:56:15 jhill_000 JOSH Launch
2014/4/26:20:56:15 jhill_000 JOSH CommandLine
2014/4/26:20:56:15 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIB472.tmp
2014/4/26:20:56:37 jhill_000 JOSH === Setup ended ===
2014/4/26:20:56:21 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:20:56:21 jhill_000 JOSH Path_Length: 157
2014/4/26:20:56:21 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIB472.tmp
2014/4/26:20:56:21 jhill_000 JOSH Launch
2014/4/26:20:56:28 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AIB472.tmp\Setup\AcSetup.dll
2014/4/26:20:56:28 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/26:20:56:37 jhill_000 JOSH PageOpen LaunchDialog
2014/4/26:20:56:45 jhill_000 JOSH PageOpen LicenseDialog
2014/4/26:20:56:48 jhill_000 JOSH PageOpen ProductInfoDialog
2014/4/26:20:57:30 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/4/26:20:57:36 jhill_000 JOSH PageOpen FullProgressDialog
2014/4/26:20:57:36 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/4/26:20:57:40 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/4/26:20:57:40 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/4/26:20:57:41 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/4/26:20:57:41 jhill_000 JOSH Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/26:20:58:00 jhill_000 JOSH Install DirectX Runtime Succeeded
2014/4/26:20:58:00 jhill_000 JOSH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:20:58:49 jhill_000 JOSH Install Autodesk Material Library 2015 Succeeded
2014/4/26:20:58:49 jhill_000 JOSH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:20:59:45 jhill_000 JOSH Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:20:59:45 jhill_000 JOSH Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:00:14 jhill_000 JOSH Install Autodesk Content Service Succeeded
2014/4/26:21:00:14 jhill_000 JOSH Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:00:20 jhill_000 JOSH Install Autodesk Content Service Language Pack Succeeded
2014/4/26:21:00:21 jhill_000 JOSH Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AIB472.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:08:51 jhill_000 JOSH Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/4/26:21:08:54 jhill_000 JOSH Rollback Autodesk Content Service Language Pack Succeeded
2014/4/26:21:09:04 jhill_000 JOSH Rollback Autodesk Content Service Succeeded
2014/4/26:21:09:09 jhill_000 JOSH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:21:09:45 jhill_000 JOSH Rollback Autodesk Material Library 2015 Succeeded
2014/4/26:21:09:45 jhill_000 JOSH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/4/26:21:09:45 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:21:09:45 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:21:09:47 jhill_000 JOSH PageOpen InstallCompleteDialog
2014/4/26:21:09:55 jhill_000 JOSH === Setup ended ===
2014/4/26:21:28:46 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:21:28:46 jhill_000 JOSH Path_Length: 157
2014/4/26:21:28:46 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI6AA5.tmp
2014/4/26:21:28:46 jhill_000 JOSH Launch
2014/4/26:21:28:47 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AI6AA5.tmp\Setup\AcSetup.dll
2014/4/26:21:28:47 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/26:21:28:53 jhill_000 JOSH PageOpen LaunchDialog
2014/4/26:21:28:55 jhill_000 JOSH PageOpen LicenseDialog
2014/4/26:21:28:42 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:21:28:42 jhill_000 JOSH Path_Length: 157
2014/4/26:21:28:42 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm
2014/4/26:21:28:42 jhill_000 JOSH Launch
2014/4/26:21:28:42 jhill_000 JOSH CommandLine
2014/4/26:21:28:42 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI6AA5.tmp
2014/4/26:21:28:59 jhill_000 JOSH === Setup ended ===
2014/4/26:21:28:59 jhill_000 JOSH PageOpen ProductInfoDialog
2014/4/26:21:29:26 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/4/26:21:29:34 jhill_000 JOSH PageOpen FullProgressDialog
2014/4/26:21:29:35 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/4/26:21:29:36 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/4/26:21:29:37 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/4/26:21:29:37 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/4/26:21:29:37 jhill_000 JOSH Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/26:21:29:52 jhill_000 JOSH Install DirectX Runtime Succeeded
2014/4/26:21:29:52 jhill_000 JOSH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:30:31 jhill_000 JOSH Install Autodesk Material Library 2015 Succeeded
2014/4/26:21:30:31 jhill_000 JOSH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:31:24 jhill_000 JOSH Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:21:31:24 jhill_000 JOSH Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:31:46 jhill_000 JOSH Install Autodesk Content Service Succeeded
2014/4/26:21:31:46 jhill_000 JOSH Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:31:53 jhill_000 JOSH Install Autodesk Content Service Language Pack Succeeded
2014/4/26:21:31:55 jhill_000 JOSH Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AI6AA5.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:38:47 jhill_000 JOSH Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/4/26:21:38:57 jhill_000 JOSH Rollback Autodesk Content Service Language Pack Succeeded
2014/4/26:21:39:18 jhill_000 JOSH Rollback Autodesk Content Service Succeeded
2014/4/26:21:39:23 jhill_000 JOSH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:21:39:56 jhill_000 JOSH Rollback Autodesk Material Library 2015 Succeeded
2014/4/26:21:39:56 jhill_000 JOSH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/4/26:21:39:56 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:21:39:56 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:21:40:00 jhill_000 JOSH PageOpen InstallCompleteDialog
2014/4/26:21:40:31 jhill_000 JOSH === Setup ended ===
2014/4/26:21:40:33 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:21:40:33 jhill_000 JOSH Path_Length: 157
2014/4/26:21:40:33 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm
2014/4/26:21:40:33 jhill_000 JOSH Launch
2014/4/26:21:40:33 jhill_000 JOSH CommandLine
2014/4/26:21:40:33 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI44A9.tmp
2014/4/26:21:41:01 jhill_000 JOSH === Setup ended ===
2014/4/26:21:40:40 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:21:40:40 jhill_000 JOSH Path_Length: 157
2014/4/26:21:40:40 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI44A9.tmp
2014/4/26:21:40:40 jhill_000 JOSH Launch
2014/4/26:21:40:41 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AI44A9.tmp\Setup\AcSetup.dll
2014/4/26:21:40:41 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/26:21:40:50 jhill_000 JOSH PageOpen LaunchDialog
2014/4/26:21:41:01 jhill_000 JOSH PageOpen LicenseDialog
2014/4/26:21:41:01 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/4/26:21:41:34 jhill_000 JOSH PageOpen FullProgressDialog
2014/4/26:21:41:34 jhill_000 JOSH Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:41:36 jhill_000 JOSH Install Network License Manager Succeeded
2014/4/26:21:41:36 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/4/26:21:41:40 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/4/26:21:41:40 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/4/26:21:41:41 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/4/26:21:41:41 jhill_000 JOSH Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:41:44 jhill_000 JOSH Install Autodesk CAD Manager Tools Succeeded
2014/4/26:21:41:44 jhill_000 JOSH PageOpen InstallCompleteDialog
2014/4/26:21:41:52 jhill_000 JOSH === Setup ended ===
2014/4/26:21:42:31 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:21:42:31 jhill_000 JOSH Path_Length: 157
2014/4/26:21:42:31 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm
2014/4/26:21:42:31 jhill_000 JOSH Launch
2014/4/26:21:42:31 jhill_000 JOSH CommandLine
2014/4/26:21:42:31 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIF57.tmp
2014/4/26:21:42:35 jhill_000 JOSH === Setup ended ===
2014/4/26:21:42:32 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:21:42:32 jhill_000 JOSH Path_Length: 157
2014/4/26:21:42:32 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AIF57.tmp
2014/4/26:21:42:32 jhill_000 JOSH Launch
2014/4/26:21:42:33 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AIF57.tmp\Setup\AcSetup.dll
2014/4/26:21:42:33 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/26:21:42:35 jhill_000 JOSH PageOpen LaunchDialog
2014/4/26:21:42:38 jhill_000 JOSH PageOpen LicenseDialog
2014/4/26:21:42:42 jhill_000 JOSH PageOpen ProductInfoDialog
2014/4/26:21:42:59 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/4/26:21:43:45 jhill_000 JOSH PageOpen FullProgressDialog
2014/4/26:21:43:46 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/4/26:21:43:47 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/4/26:21:43:47 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/4/26:21:43:48 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/4/26:21:43:48 jhill_000 JOSH Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/26:21:44:04 jhill_000 JOSH Install DirectX Runtime Succeeded
2014/4/26:21:44:04 jhill_000 JOSH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:44:35 jhill_000 JOSH Install Autodesk Material Library 2015 Succeeded
2014/4/26:21:44:35 jhill_000 JOSH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:45:13 jhill_000 JOSH Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:21:45:13 jhill_000 JOSH Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:45:26 jhill_000 JOSH Install Autodesk Content Service Succeeded
2014/4/26:21:45:26 jhill_000 JOSH Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:45:29 jhill_000 JOSH Install Autodesk Content Service Language Pack Succeeded
2014/4/26:21:45:29 jhill_000 JOSH Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AIF57.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:21:51:34 jhill_000 JOSH Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/4/26:21:51:37 jhill_000 JOSH Rollback Autodesk Content Service Language Pack Succeeded
2014/4/26:21:51:52 jhill_000 JOSH Rollback Autodesk Content Service Succeeded
2014/4/26:21:51:57 jhill_000 JOSH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:21:52:34 jhill_000 JOSH Rollback Autodesk Material Library 2015 Succeeded
2014/4/26:21:52:34 jhill_000 JOSH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/4/26:21:52:34 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:21:52:34 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:21:52:37 jhill_000 JOSH PageOpen InstallCompleteDialog
2014/4/26:21:53:27 jhill_000 JOSH === Setup ended ===
2014/4/26:22:14:18 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:22:14:18 jhill_000 JOSH Path_Length: 157
2014/4/26:22:14:18 jhill_000 JOSH Current Directory C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm
2014/4/26:22:14:18 jhill_000 JOSH Launch
2014/4/26:22:14:18 jhill_000 JOSH CommandLine
2014/4/26:22:14:18 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI2A45.tmp
2014/4/26:22:14:39 jhill_000 JOSH === Setup ended ===
2014/4/26:22:14:22 jhill_000 JOSH === Setup started on JOSH by jhill_000 ===
2014/4/26:22:14:22 jhill_000 JOSH Path_Length: 157
2014/4/26:22:14:22 jhill_000 JOSH Current Directory C:\Users\JHILL_~1\AppData\Local\Temp\_AI2A45.tmp
2014/4/26:22:14:22 jhill_000 JOSH Launch
2014/4/26:22:14:26 jhill_000 JOSH Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\JHILL_~1\AppData\Local\Temp\_AI2A45.tmp\Setup\AcSetup.dll
2014/4/26:22:14:26 jhill_000 JOSH Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/26:22:14:39 jhill_000 JOSH PageOpen LaunchDialog
2014/4/26:22:14:42 jhill_000 JOSH PageOpen LicenseDialog
2014/4/26:22:14:46 jhill_000 JOSH PageOpen ProductInfoDialog
2014/4/26:22:15:21 jhill_000 JOSH PageOpen ProductSelectionDialog2
2014/4/26:22:27:09 jhill_000 JOSH PageOpen FullProgressDialog
2014/4/26:22:27:10 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/4/26:22:27:16 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/4/26:22:27:16 jhill_000 JOSH Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\JHILL_~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/4/26:22:27:18 jhill_000 JOSH Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/4/26:22:27:18 jhill_000 JOSH Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/26:22:27:36 jhill_000 JOSH Install DirectX Runtime Succeeded
2014/4/26:22:27:36 jhill_000 JOSH Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:22:28:26 jhill_000 JOSH Install Autodesk Material Library 2015 Succeeded
2014/4/26:22:28:26 jhill_000 JOSH Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:22:29:13 jhill_000 JOSH Install Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:22:29:15 jhill_000 JOSH Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:22:29:42 jhill_000 JOSH Install Autodesk Content Service Succeeded
2014/4/26:22:29:43 jhill_000 JOSH Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:22:29:48 jhill_000 JOSH Install Autodesk Content Service Language Pack Succeeded
2014/4/26:22:29:50 jhill_000 JOSH Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\JHILL_~1\AppData\Local\Temp\_AI2A45.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/26:22:37:12 jhill_000 JOSH Install Autodesk® AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/4/26:22:37:19 jhill_000 JOSH Rollback Autodesk Content Service Language Pack Succeeded
2014/4/26:22:37:37 jhill_000 JOSH Rollback Autodesk Content Service Succeeded
2014/4/26:22:37:42 jhill_000 JOSH Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/4/26:22:38:19 jhill_000 JOSH Rollback Autodesk Material Library 2015 Succeeded
2014/4/26:22:38:19 jhill_000 JOSH Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/4/26:22:38:19 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/4/26:22:38:19 jhill_000 JOSH Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
Tags (2)
5 REPLIES 5
Here is one of the error messages
Cavalier91
which processor is being used in ur system/laptop,how much is RAM and which graphics card you are using?
in reply to: Cavalier91
Intel i5 processor
8 of ram
and intel 4400 graphics I think
pendean
The log indicates a 1619 error and visual c++ not bring able to install: there are many topics about both in this forum if you want to try a search for a solution while you wait.
pendean
Administrator Productivity
