The AutoCAD 2014 installer window is too large for my screen despite the minimun req. being 1024 x 768. My computers resolution is 1366 x 768. I was wondering what i should do.
Solved by JTBWorld. Go to Solution.
I've installed on that screen resolution and dont recall any problems. At what point is it too large?
The laucher is too large vertically. I am unable to see the butons that confirm i want to install/uninstall any autodesk products
Is it any of the windows seen here?
http://www.jtbworld.com/autocad2014.htm#Deployment/setup
If so, click on the image and let me know the link.
If possible take a screenshot yourself and post here.
I've not tried that but do you have Windows text scaling set to other than 100%?
I checked my scaling. It was set to medium (125%). I set to to the default and this fixed the problem. Thank you for the help!
