Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
Installation Server Issues
7 REPLIES 7
Message 1 of 8
azhark14
625 Views, 7 Replies
(Refer to attachments)
After numerous attempts to install Revit it seems I keep hurdling at this server issue.
I have reported the problem before and it was suggested that maybe I had accidently selected "network server" but i can confidently say now I have not done this! The icon is all there -- and I have watched all the help videos out there --but the screen to select standalone license or network license has not even came up!!!
 i cant even get to the stage where you enter your product key!
I am guessing maybe my windows server is not new enough so I am in the process of downlaoding 2012 trial. In fact all I seem to be doing is downlaoding other programs to assist with the download of REVIT!!!
How do i get to the screen to enter my standalone license?
AutodeskĀ® RevitĀ® Server is an optional server application for Revit software. Can this not be ignored for my downlaod?
HELP!!! A repeatedly agitated student who is becoming more frustrated with the term 'autodesk installation"!
Thanks in advance
A
7 REPLIES 7
Message 2 of 8
DarrenP
in reply to: azhark14
this is what revit server is: http://wikihelp.autodesk.com/Revit/enu/community/videos/Revit_Server/Revit_Server_-_What_It_Is_and_W...
it has nothing to do with licensing
by default all software is set to standalone licensing
i have no idea what you did or what you are doing
DarrenP
Message 3 of 8
DarrenP
in reply to: DarrenP
did you watch these videos: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16854078&linkID=9240657&CMP=OTC-RSS...
DarrenP
Message 4 of 8
DarrenP
did you also read the system requirements: http://usa.autodesk.com/revit/system-requirements/#server
DarrenP
Message 5 of 8
azhark14
Yes i have watched all the videos and checked the requirments!! It seems to install everything but the server issue is  just the problem everytime!
Message 6 of 8
DarrenP
did you read the system requirements for revit server
Operating System
 ā€¢MicrosoftĀ® Windows ServerĀ® 2008 64-bit
ā€¢Microsoft Windows Server 2008 R2 64-bit
this is required to install revit server
DarrenP
Message 7 of 8
TravisNave
Do you even want Revit server?  You know you don't have to install those optional tools, right?
Autodesk Forums:
Message 8 of 8
azhark14
in reply to: TravisNave
Ni I dnt need the server at all.
But i cant rememeber coming across an option to deselect this.
I have always selected stand alone license opposed to the other option but same message error.
A
Administrator Productivity
