Installation & Licensing
Installation Screen > Next
1 REPLY 1
david.lau
228 Views, 1 Reply
Just a quick note that if the resolution of a monitor is 800 x 600 and you try to install the software, the Setup Wizard buttons will be out of view and you maybe stuck.
You can use the Enter key to continue and you can also use the Tab key to cycle though the different fields if you need to enter your Serial Number and Product Key.
David Lau
1 REPLY 1
frhervet
in reply to: david.lau
Hi David,
Requirements for AutoCAD indicates 1,024 x 768 as resolution.Smiley Wink
Franck Hervet
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
Administrator Productivity
