Installation & Licensing
Installation Problems Revit 2012
3 REPLIES 3
255 Views, 3 Replies
I have tried to install this many times, one area will not install. Shows this message Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\beth\AppData\Local\Temp\vcredist_x86_2010.log
2012/9/4:21:14:29 beth BETHLIFFD325 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603.  Help thanks
3 REPLIES 3
emily.xu
Try to uninstall Microsoft Visual C++ 2010 from Control panel, then reinstall revit.
Emily Xu
Product Support
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
Thanks it's fixed and installed. Sent from my iPhone
Administrator Productivity
