Path_Length: 151
Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AI41E3.tmp
Launch
[Error: 1060] The specified service does not exist as an installed service.
[Error: 6] The handle is invalid.
Download Play SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...2014/4/7:18:43:56 Christopher CADMUS Download Complete SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...2014/4/7:18:43:58 Christopher CADMUS PageOpen LaunchDialog
2014/4/7:18:46:28 Christopher CADMUS PageOpen LicenseDialog
2014/4/7:18:46:28 Christopher CADMUS PageOpen ProductInfoDialog
2014/4/7:18:46:28 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/7:18:46:43 Christopher CADMUS PageOpen FullProgressDialog
2014/4/7:18:46:43 Christopher CADMUS WebInstaller2014/4/7:18:54:08 Christopher CADMUS Download Play VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/7:18:54:38 Christopher CADMUS Download Complete VCREDIST2005SP1ATLX86
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/7:18:54:40 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/7:18:56:17 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/7:18:56:40 Christopher CADMUS Download Play VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/7:18:57:00 Christopher CADMUS Download Complete VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/7:18:57:01 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/7:18:57:43 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/7:18:57:44 Christopher CADMUS PageOpen InstallCompleteDialog
2014/4/7:18:58:27 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/7:18:58:27 Christopher CADMUS === Setup ended ===
2014/4/7:19:00:31 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/7:19:00:31 Christopher CADMUS Path_Length: 151
2014/4/7:19:00:31 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/7:19:00:31 Christopher CADMUS Launch
2014/4/7:19:00:31 Christopher CADMUS CommandLine /url "
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-46443375 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/7:19:00:31 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIA9E9.tmp
2014/4/7:19:00:43 Christopher CADMUS === Setup ended ===
2014/4/7:19:00:36 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/7:19:00:36 Christopher CADMUS Path_Length: 151
2014/4/7:19:00:36 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIA9E9.tmp
2014/4/7:19:00:36 Christopher CADMUS Launch
2014/4/7:19:00:36 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/7:19:00:36 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/7:19:00:40 Christopher CADMUS Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...2014/4/7:19:00:42 Christopher CADMUS PageOpen LaunchDialog
2014/4/7:19:00:55 Christopher CADMUS PageOpen LicenseDialog
2014/4/7:19:00:56 Christopher CADMUS PageOpen ProductInfoDialog
2014/4/7:19:00:56 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/7:19:01:33 Christopher CADMUS PageOpen FullProgressDialog
2014/4/7:19:01:34 Christopher CADMUS Download Skipped VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/7:19:01:34 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/7:19:01:48 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/7:19:01:48 Christopher CADMUS PageOpen InstallCompleteDialog
2014/4/7:19:01:55 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/7:19:01:55 Christopher CADMUS === Setup ended ===
2014/4/7:19:17:01 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/7:19:17:01 Christopher CADMUS Path_Length: 151
2014/4/7:19:17:01 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIA538.tmp
2014/4/7:19:17:01 Christopher CADMUS Launch
2014/4/7:19:17:01 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/7:19:17:01 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/7:19:17:11 Christopher CADMUS Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe2014/4/7:19:17:12 Christopher CADMUS Connection has expired. Please reconnect to site.2014/4/7:19:17:18 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/7:19:17:18 Christopher CADMUS === Setup ended ===
2014/4/7:19:16:53 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/7:19:16:53 Christopher CADMUS Path_Length: 151
2014/4/7:19:16:53 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/7:19:16:53 Christopher CADMUS Launch
2014/4/7:19:16:53 Christopher CADMUS CommandLine /url "
2014/4/7:19:16:53 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIA538.tmp
2014/4/7:19:17:19 Christopher CADMUS === Setup ended ===
2014/4/8:23:03:38 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/8:23:03:38 Christopher CADMUS Path_Length: 151
2014/4/8:23:03:38 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/8:23:03:38 Christopher CADMUS Launch
2014/4/8:23:03:38 Christopher CADMUS CommandLine /url "
2014/4/8:23:03:38 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIA073.tmp
2014/4/8:23:03:54 Christopher CADMUS === Setup ended ===
2014/4/8:23:03:45 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/8:23:03:45 Christopher CADMUS Path_Length: 151
2014/4/8:23:03:45 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIA073.tmp
2014/4/8:23:03:45 Christopher CADMUS Launch
2014/4/8:23:03:45 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/8:23:03:45 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/8:23:03:52 Christopher CADMUS Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...2014/4/8:23:03:54 Christopher CADMUS PageOpen LaunchDialog
2014/4/8:23:04:23 Christopher CADMUS PageOpen LicenseDialog
2014/4/8:23:04:24 Christopher CADMUS PageOpen ProductInfoDialog
2014/4/8:23:04:24 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/8:23:04:35 Christopher CADMUS PageOpen FullProgressDialog
2014/4/8:23:04:35 Christopher CADMUS Download Skipped VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/8:23:04:35 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/8:23:06:03 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/8:23:06:04 Christopher CADMUS PageOpen InstallCompleteDialog
2014/4/8:23:06:43 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/8:23:06:43 Christopher CADMUS === Setup ended ===
2014/4/8:23:27:46 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/8:23:27:46 Christopher CADMUS Path_Length: 151
2014/4/8:23:27:46 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/8:23:27:46 Christopher CADMUS Launch
2014/4/8:23:27:46 Christopher CADMUS CommandLine /url "
2014/4/8:23:27:46 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIBBDF.tmp
2014/4/8:23:29:25 Christopher CADMUS === Setup ended ===
2014/4/8:23:27:49 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/8:23:27:49 Christopher CADMUS Path_Length: 151
2014/4/8:23:27:49 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIBBDF.tmp
2014/4/8:23:27:49 Christopher CADMUS Launch
2014/4/8:23:27:49 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/8:23:27:49 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/8:23:27:58 Christopher CADMUS Download Play SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...2014/4/8:23:29:22 Christopher CADMUS Download Complete SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...2014/4/8:23:29:25 Christopher CADMUS PageOpen LaunchDialog
2014/4/8:23:29:59 Christopher CADMUS PageOpen LicenseDialog
2014/4/8:23:29:59 Christopher CADMUS PageOpen ProductInfoDialog
2014/4/8:23:29:59 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/8:23:30:32 Christopher CADMUS PageOpen FullProgressDialog
2014/4/8:23:30:40 Christopher CADMUS Download Play VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/8:23:31:01 Christopher CADMUS Download Complete VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...2014/4/8:23:31:01 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/8:23:31:45 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/8:23:31:45 Christopher CADMUS PageOpen InstallCompleteDialog
2014/4/8:23:38:13 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/8:23:38:13 Christopher CADMUS === Setup ended ===
2014/4/9:01:31:16 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:01:31:16 Christopher CADMUS Path_Length: 151
2014/4/9:01:31:16 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/9:01:31:16 Christopher CADMUS Launch
2014/4/9:01:31:16 Christopher CADMUS CommandLine /url "
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/9:01:31:16 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIC988.tmp
2014/4/9:01:36:01 Christopher CADMUS === Setup ended ===
2014/4/9:01:31:28 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:01:31:28 Christopher CADMUS Path_Length: 151
2014/4/9:01:31:28 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AIC988.tmp
2014/4/9:01:31:28 Christopher CADMUS Launch
2014/4/9:01:31:29 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/9:01:31:29 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:01:32:06 Christopher CADMUS Download Play SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t...2014/4/9:01:35:57 Christopher CADMUS Download Complete SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t...2014/4/9:01:36:02 Christopher CADMUS PageOpen LaunchDialog
2014/4/9:01:36:13 Christopher CADMUS PageOpen LicenseDialog
2014/4/9:01:36:13 Christopher CADMUS PageOpen ProductInfoDialog
2014/4/9:01:38:15 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/9:01:38:23 Christopher CADMUS PageOpen FullProgressDialog
2014/4/9:01:38:55 Christopher CADMUS Download Play VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200...2014/4/9:01:40:25 Christopher CADMUS Download Complete VCREDIST2005SP1ATLX64
http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST200...2014/4/9:01:40:30 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/9:01:44:18 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/9:01:44:21 Christopher CADMUS PageOpen InstallCompleteDialog
2014/4/9:01:45:53 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:01:45:53 Christopher CADMUS === Setup ended ===
2014/4/9:14:19:43 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:14:19:43 Christopher CADMUS Path_Length: 151
2014/4/9:14:19:43 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/9:14:19:43 Christopher CADMUS Launch
2014/4/9:14:19:43 Christopher CADMUS CommandLine
2014/4/9:14:19:43 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AI5689.tmp
2014/4/9:14:20:13 Christopher CADMUS === Setup ended ===
2014/4/9:14:19:51 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:14:19:51 Christopher CADMUS Path_Length: 151
2014/4/9:14:19:51 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AI5689.tmp
2014/4/9:14:19:51 Christopher CADMUS Launch
2014/4/9:14:19:51 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/9:14:19:51 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:14:19:52 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:14:20:10 Christopher CADMUS PageOpen LaunchDialog
2014/4/9:14:20:16 Christopher CADMUS PageOpen LicenseDialog
2014/4/9:14:20:21 Christopher CADMUS PageOpen ProductInfoDialog
2014/4/9:14:22:55 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/9:14:22:58 Christopher CADMUS PageOpen FullProgressDialog
2014/4/9:14:22:58 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/9:14:26:59 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/9:14:26:59 Christopher CADMUS PageOpen InstallCompleteDialog
2014/4/9:14:30:36 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:14:30:36 Christopher CADMUS === Setup ended ===
2014/4/9:14:30:41 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:14:30:41 Christopher CADMUS Path_Length: 151
2014/4/9:14:30:41 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/9:14:30:41 Christopher CADMUS Launch
2014/4/9:14:30:41 Christopher CADMUS CommandLine
2014/4/9:14:30:41 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AI5A70.tmp
2014/4/9:14:31:48 Christopher CADMUS === Setup ended ===
2014/4/9:14:31:16 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:14:31:16 Christopher CADMUS Path_Length: 151
2014/4/9:14:31:16 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AI5A70.tmp
2014/4/9:14:31:16 Christopher CADMUS Launch
2014/4/9:14:31:16 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/9:14:31:16 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:14:31:53 Christopher CADMUS PageOpen LaunchDialog
2014/4/9:15:27:31 Christopher CADMUS PageOpen LicenseDialog
2014/4/9:15:28:07 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/9:15:28:14 Christopher CADMUS PageOpen FullProgressDialog
2014/4/9:15:28:15 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/9:15:29:40 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/4/9:15:29:43 Christopher CADMUS PageOpen InstallCompleteDialog
2014/4/9:16:20:05 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:16:20:05 Christopher CADMUS === Setup ended ===
2014/4/9:16:51:12 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:16:51:12 Christopher CADMUS Path_Length: 151
2014/4/9:16:51:12 Christopher CADMUS Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/9:16:51:12 Christopher CADMUS Launch
2014/4/9:16:51:12 Christopher CADMUS CommandLine
2014/4/9:16:51:12 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AI486.tmp
2014/4/9:16:51:41 Christopher CADMUS === Setup ended ===
2014/4/9:16:51:24 Christopher CADMUS === Setup started on CADMUS by Christopher ===
2014/4/9:16:51:24 Christopher CADMUS Path_Length: 151
2014/4/9:16:51:24 Christopher CADMUS Current Directory C:\Users\CHRIST~1\AppData\Local\Temp\_AI486.tmp
2014/4/9:16:51:24 Christopher CADMUS Launch
2014/4/9:16:51:24 Christopher CADMUS [Error: 1060] The specified service does not exist as an installed service.
2014/4/9:16:51:25 Christopher CADMUS [Error: 6] The handle is invalid.
2014/4/9:16:51:42 Christopher CADMUS PageOpen LaunchDialog
2014/4/9:16:51:50 Christopher CADMUS PageOpen LicenseDialog
2014/4/9:16:52:00 Christopher CADMUS PageOpen ProductInfoDialog
2014/4/9:16:52:58 Christopher CADMUS PageOpen ProductSelectionDialog2
2014/4/9:16:53:32 Christopher CADMUS PageOpen FullProgressDialog
2014/4/9:16:53:32 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/9:16:53:47 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/4/9:16:53:47 Christopher CADMUS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHRIST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/9:16:55:09 Christopher CADMUS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
