Hey,
i tried to install the Autodesk Inventor 2014 several times. Always the same problem.
This is an excerpt of the Logfile. The complete logfile is attached.
2013/12/18:16:20:43 Mario EBBE Install Autodesk Material Library 2014 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2013/12/18:16:20:44 Mario EBBE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I don´t know how i can fix the problem. I checked several communities but i can´t find a solution.
I would be happy i someone can help me.
Best regards,
Ebbe
Solved by TravisNave. Go to Solution.
Solved by jessica.t. Go to Solution.
Hi Mario and welcome to the Autodesk Community!
We have some great existing solutions that should be very helpful:
I hope this helps resolves your issue. If you have any other questions or concerns please reply to this post. Or if you need additional assistance please do not hesitate to ask.
Thank you!
As your log indicates, the material library is failing to download. Others are having this problem currently. Makes me wonder if the problem is on the Autodesk server end.
Download Aborted CMILL http://trial2.autodesk.com/SWDLDNET3/2014/INVNTOR/WI/{B9510038-243B-480F-B5FC-E0F475093CA5}/CMILL.ta...
What your might try is downloading from the virtual assistant instead. Sometimes it just works better than other distributions.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Hey Travis and Jessica,
thank you for your posts. Your ideas solves my problem. I`ve downloaded the Installation File.
After installing the Service Pack 1 on my Win8.1 Notebook, the Inventor starts without problems.
Best regards,
Mario
