Installation & Licensing
Installation Problem AutoCAD 2014 - .NET Framework problem
14 REPLIES 14
Message 1 of 15
a093310
59080 Views, 14 Replies
I have a 64-bit Windows 8, and when trying to install AutoCAD 2014, the following error message shows up:
2013/4/4:16:34:30 Alan ALAN-PC === Setup started on ALAN-PC by Alan ===
2013/4/4:16:34:30 Alan ALAN-PC Path_Length: 155
2013/4/4:16:34:30 Alan ALAN-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/4/4:16:34:30 Alan ALAN-PC Launch
2013/4/4:16:34:30 Alan ALAN-PC CommandLine
2013/4/4:16:34:30 Alan ALAN-PC Current Directory C:\Users\Vita\AppData\Local\Temp\_AI6F01.tmp
2013/4/4:16:34:38 Alan ALAN-PC === Setup ended ===
2013/4/4:16:34:31 Alan ALAN-PC === Setup started on ALAN-PC by Alan ===
2013/4/4:16:34:31 Alan ALAN-PC Path_Length: 155
2013/4/4:16:34:31 Alan ALAN-PC Current Directory C:\Users\Vita\AppData\Local\Temp\_AI6F01.tmp
2013/4/4:16:34:31 Alan ALAN-PC Launch
2013/4/4:16:34:31 Alan ALAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Vita\AppData\Local\Temp\_AI6F01.tmp\Setup\AcSetup.dll
2013/4/4:16:34:31 Alan ALAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/4:16:34:38 Alan ALAN-PC PageOpen LaunchDialog
2013/4/4:16:34:40 Alan ALAN-PC PageOpen LicenseDialog
2013/4/4:16:34:43 Alan ALAN-PC PageOpen ProductInfoDialog
2013/4/4:16:35:04 Alan ALAN-PC PageOpen ProductSelectionDialog2
2013/4/4:16:35:16 Alan ALAN-PC PageOpen FullProgressDialog
2013/4/4:16:35:16 Alan ALAN-PC Installing .NET
: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe" /q
2013/4/4:16:35:22 Alan ALAN-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
Could anyone please tell me what to do? Thank you!
14 REPLIES 14
Message 2 of 15
go_to_101
in reply to: a093310
did u solve the problem? i also face this kind of problem. If yes, can u teach me stap by stap. ThxSmiley Happy
Message 3 of 15
Awong701
If you are are installing...
  • AutoCAD 2014 non English version
  • Using Windows 8 operating system
You will get a .NET 4 and a .NET 4.5 Language Pack error when installing the product.
The following workaround that will help resolve this issue:
1. Copy the Media contents to a local drive or use a browser downloadedversion of software.
2. Copy and backup the setup.ini file and call it:  setup-BACKUP.ini.
3. Open file setup.ini from the root folder using a text editor.
4 .Search for (without quotes) “[DOTNET4LANG]” and “[DOTNET45LANG]”
5. Add a new line “IGNORE_FAILURE=YES” for them if found. This line can be added anywhere below “EXE_PARAM=”
Message 4 of 15
dragonsuperbat
in reply to: Awong701
HI, I have follow the step and the installation go smooth. But there is still problem after thaht. When I start the apps, a conservation box pop up and show that there is unhandled exception error e06d7363h. How to fix this?
Message 5 of 15
720121
Message 6 of 15
dragonsuperbat
Here I attached the erroe code durng I start up the apps.
I downloaded the installer from autodesk website.
Message 7 of 15
zhaoqi_zq
What about an English version Autocad 2014?I cannot find any sentence you required.
Thx
Message 8 of 15
zhaoqi_zq
in reply to: zhaoqi_zq
I have fixed the problem,now the installation go smooth
Message 9 of 15
JustinCase1
want to tell us how you fixed it?
Message 10 of 15
TravisNave
in reply to: JustinCase1
I suspect like the instructions listed above.
Or you can find more information here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 11 of 15
manugarban
we have a problem when I open the Civil 3D Your application was not able to obtain a license because the flexnet license server manager could not determine where to find the licensing data it neet please choose one of the following:
specify the license server
specify the licence fie
Message 12 of 15
TravisNave
in reply to: manugarban
Is your license manager running?  And can you PING the server and get an IPv4 response?
Autodesk Forums:
Message 13 of 15
micha1989
Thanks a lot, now I the installation was succesful.
Obs.: I couldn't find [DOTNET45LANG] in my setup.ini
Message 14 of 15
slimk7shav
hey guys, I've run autocad 2014, it successfully do and then a box crops up telling intialization failed. Unable to set up the software...NEED HELP!!!!
Message 15 of 15
GeminiKY
in reply to: TravisNave
Hi Travis, I get a issue about autocad cannot be installed in win 8 system. After installing .NET Framework Runtime 4.0 language Pack, the installation progress is disappeared. Finally, the installation is failed. Could you help provide some solutions or suggestions? Thank you in advance !
Administrator Productivity
