Installation & Licensing
Installation Path not changeable
2 REPLIES 2
2574 Views, 2 Replies
I am trying to install Autodesk Inventor 2013.
But I can not really change the installation path.
Standard is C:\Program Files\Autodesk\
The problem is that C is for my Windows only.
And also has not got much room left (about 800MB).
So I wanted to change the Path to H where all my other Programs are installed.
On H I got over 100 GBs of free space.
I can type it in and the Free space on H is then calculated correctly on the bottom right.
But if I try to continue and install the Programm there
there an Error pops up saying that I haven't got enough free Space and showing my all my partitions with their size and free space.
In this box I cannot select any of the partiotions.
I can just click Try Again or OK.
If I press try again it pops up again and with OK I get back to the Selection and Configuration Screen for the installation.
In the path it still says H:\Program Files\Autodesk like I changed before and the calculated free space is still enough...
There has to be a problem that I can type in another installation path but it is not really changed....
Hope you can help me out how to really change the path.
2 REPLIES 2
TravisNave
No, it's because the Windows installer uses your %TEMP% path to install.  You can either clear enough space on your C:\ by cleaning out the %TEMP% folder, disabling hibernation, and moving your virtual memory swap file to H:\ or you can move your %TEMP% variable to a folder on H:\ instead.  In any case, that should help.  There will always be some items that will need to be installed on the C:\ drive, like in your user profile, registry, and icons, etc.
Just do all the above.  Smiley Very Happy
Autodesk Forums:
in reply to: TravisNave
I have a problem where i can't even change the location of installation when installing, both the browse and line of path are blocked out where i can click and edit nothing. Also i changed the location of my temp file and still it wanted to install to the C: drive. What should i do then?
Administrator Productivity
