I just went through the full installation of Revit Architecture 2012. When the installation completed, it said each component failed to install. A little frustrated, but wondering where to go from here. It is the third time I have done the install and it has failed each time. My computer meets or exceeds all of the system requirements and AutoCad installed easily.
I remember having this problem with 2012 - try loading each application seperately, this worked for me.
Hi eisaac
Welcome to Autodesk discussion group, we will help you with your problem.
In order to give you helpful suggestions, Please help us to provide more details about your issue.
1 Capture the error messages you got.
2 Find the installation log file under the folder %temp%
We will look at these files and try to do some troubleshooting.
