Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Installati on Failure
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello everybody,
Whenever i try to install revit, it fails
I've reinstalled several times
here is my error log:
2012/5/23:21:45:57 Hrishi HRISHI-PC === Setup started on HRISHI-PC by Hrishi ===
2012/5/23:21:45:57 Hrishi HRISHI-PC Launch
2012/5/23:21:45:59 Hrishi HRISHI-PC === Setup ended ===
2012/5/23:22:12:16 Hrishi HRISHI-PC === Setup started on HRISHI-PC by Hrishi ===
2012/5/23:22:12:16 Hrishi HRISHI-PC Launch
2012/5/23:22:12:19 Hrishi HRISHI-PC === Setup ended ===
2012/5/23:22:12:17 Hrishi HRISHI-PC === Setup started on HRISHI-PC by Hrishi ===
2012/5/23:22:12:17 Hrishi HRISHI-PC Launch
2012/5/23:22:12:19 Hrishi HRISHI-PC PageOpen LaunchDialog
2012/5/23:22:12:54 Hrishi HRISHI-PC PageOpen LicenseDialog
2012/5/23:22:12:57 Hrishi HRISHI-PC PageOpen ProductInfoDialog
2012/5/23:22:14:38 Hrishi HRISHI-PC PageOpen ProductSelectionDialog2
2012/5/23:22:15:26 Hrishi HRISHI-PC PageOpen FullProgressDialog
2012/5/23:22:15:26 Hrishi HRISHI-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2013_Engli
2012/5/23:22:15:55 Hrishi HRISHI-PC Install DirectX® Runtime Succeeded
2012/5/23:22:15:55 Hrishi HRISHI-PC Installing FaroSDK: C:\Autodesk\Autodesk_Revit_Architecture_2013_Engli
2012/5/23:22:15:59 Hrishi HRISHI-PC Install FaroSDK Succeeded
2012/5/23:22:16:00 Hrishi HRISHI-PC Installing Autodesk® Revit® Architecture 2013: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architectur
2012/5/23:22:16:00 Hrishi HRISHI-PC Install Autodesk® Revit® Architecture 2013 Failed Installation aborted, Result=1618
2012/5/23:22:16:00 Hrishi HRISHI-PC Rollback FaroSDK Failed Failure is ignored, Result=1618
2012/5/23:22:16:00 Hrishi HRISHI-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
Any help would be appreciated.
Thank you very much
