Installation & Licensing
cec
Active Member
cec
Message 1 of 7 (336 Views)
Installation Failure AutoCad LT 2013
336 Views, 6 Replies
02-25-2013 09:50 AM
Here is my log.
2013/2/25:09:40:50 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:40:50 ce1 CE001 Launch
2013/2/25:09:41:54 ce1 CE001 === Setup ended ===
2013/2/25:09:41:06 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:41:06 ce1 CE001 Launch
2013/2/25:09:41:53 ce1 CE001 PageOpen LaunchDialog
2013/2/25:09:42:22 ce1 CE001 PageOpen LicenseDialog
2013/2/25:09:42:32 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:09:44:37 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:09:44:47 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:09:44:47 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:09:44:56 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:09:45:13 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:09:45:41 ce1 CE001 === Setup ended ===
2013/2/25:09:46:08 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:46:08 ce1 CE001 Launch
2013/2/25:09:46:10 ce1 CE001 === Setup ended ===
2013/2/25:09:46:09 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:09:46:09 ce1 CE001 Launch
2013/2/25:09:46:10 ce1 CE001 PageOpen LaunchDialog
2013/2/25:09:46:14 ce1 CE001 PageOpen LicenseDialog
2013/2/25:09:46:17 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:09:46:40 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:09:47:07 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:09:47:07 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:09:47:11 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:09:47:11 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:09:48:38 ce1 CE001 === Setup ended ===
2013/2/25:10:41:43 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:10:41:43 ce1 CE001 Launch
2013/2/25:10:42:30 ce1 CE001 === Setup ended ===
2013/2/25:10:41:53 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:10:41:53 ce1 CE001 Launch
2013/2/25:10:42:30 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:01:14 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:01:18 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:01:46 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:01:48 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:01:48 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:01:56 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:02:05 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:02:44 ce1 CE001 === Setup ended ===
2013/2/25:11:30:34 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:30:34 ce1 CE001 Launch
2013/2/25:11:30:36 ce1 CE001 === Setup ended ===
2013/2/25:11:30:35 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:30:35 ce1 CE001 Launch
2013/2/25:11:30:36 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:30:38 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:30:41 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:31:05 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:31:09 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:31:09 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:31:14 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:31:14 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:31:21 ce1 CE001 === Setup ended ===
2013/2/25:11:32:04 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:32:04 ce1 CE001 Launch
2013/2/25:11:32:06 ce1 CE001 === Setup ended ===
2013/2/25:11:32:05 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:32:05 ce1 CE001 Launch
2013/2/25:11:32:06 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:32:08 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:13 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:32:19 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:19 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:32:34 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:34 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:32:37 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:32:41 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:32:56 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:34:23 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:34:23 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:34:29 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:34:30 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:37:46 ce1 CE001 === Setup ended ===
2013/2/25:11:48:00 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:48:00 ce1 CE001 Launch
2013/2/25:11:48:47 ce1 CE001 === Setup ended ===
2013/2/25:11:48:10 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:48:10 ce1 CE001 Launch
2013/2/25:11:48:47 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:48:50 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:48:52 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:49:08 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:49:13 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:49:13 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:49:18 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:49:27 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:49:32 ce1 CE001 === Setup ended ===
2013/2/25:11:50:04 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:50:04 ce1 CE001 Launch
2013/2/25:11:50:06 ce1 CE001 === Setup ended ===
2013/2/25:11:50:05 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:50:05 ce1 CE001 Launch
2013/2/25:11:50:06 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:50:10 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:50:12 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:50:14 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:50:16 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:50:16 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:50:20 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:50:20 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:50:24 ce1 CE001 === Setup ended ===
2013/2/25:11:51:31 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:51:31 ce1 CE001 Launch
2013/2/25:11:52:23 ce1 CE001 === Setup ended ===
2013/2/25:11:51:40 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:51:40 ce1 CE001 Launch
2013/2/25:11:52:23 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:52:27 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:52:29 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:52:31 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:52:37 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:52:37 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:52:41 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:52:50 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:11:55:00 ce1 CE001 === Setup ended ===
2013/2/25:11:56:16 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:56:16 ce1 CE001 Launch
2013/2/25:11:56:18 ce1 CE001 === Setup ended ===
2013/2/25:11:56:17 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:11:56:17 ce1 CE001 Launch
2013/2/25:11:56:18 ce1 CE001 PageOpen LaunchDialog
2013/2/25:11:56:21 ce1 CE001 PageOpen LicenseDialog
2013/2/25:11:56:23 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:11:56:27 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:11:56:28 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:11:56:28 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:11:56:32 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/25:11:56:32 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:12:01:40 ce1 CE001 === Setup ended ===
2013/2/25:12:32:47 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:12:32:47 ce1 CE001 Launch
2013/2/25:12:33:38 ce1 CE001 === Setup ended ===
2013/2/25:12:32:56 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/25:12:32:56 ce1 CE001 Launch
2013/2/25:12:33:38 ce1 CE001 PageOpen LaunchDialog
2013/2/25:12:46:53 ce1 CE001 PageOpen LicenseDialog
2013/2/25:12:46:57 ce1 CE001 PageOpen ProductInfoDialog
2013/2/25:12:46:59 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/25:12:47:01 ce1 CE001 PageOpen FullProgressDialog
2013/2/25:12:47:20 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/25:12:47:27 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
Thank You!
Mike
philip.s
Message 2 of 7 (304 Views)
Re: Installation Failure AutoCad LT 2013
02-25-2013 03:55 PM in reply to: cec
Hi john,
This is most likely failing because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer.  Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
A typical workaround is to uinstall the prerequisite (Microsoft Visual C++ 2008 SP1 Redistributable) via the Control Panel (add / remove programs), and then reinstall the software.
For additional 1603 error causes and corresponding solutions, click here.
Please accept as a solution if this fully resolves the issue, or reply with specifics if the problem still persists.
Philip Schmelzer
cec
Active Member
cec
Message 3 of 7 (225 Views)
02-27-2013 07:34 AM in reply to: philip.s
Still not working and coming up with the same error, I uninstalled all the visuals and then tryied to reinstall AutoCAD it made it throught the visual 84 install but failed at the visual 64 install.
cec
Active Member
cec
Message 4 of 7 (222 Views)
02-27-2013 07:51 AM in reply to: philip.s
here is my new log
2013/2/25:12:47:36 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/25:12:48:09 ce1 CE001 === Setup ended ===
2013/2/27:09:48:45 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:48:45 ce1 CE001 Launch
2013/2/27:09:49:35 ce1 CE001 === Setup ended ===
2013/2/27:09:48:54 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:48:54 ce1 CE001 Launch
2013/2/27:09:49:35 ce1 CE001 PageOpen LaunchDialog
2013/2/27:09:49:38 ce1 CE001 PageOpen LicenseDialog
2013/2/27:09:49:41 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:09:49:54 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:09:49:56 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:09:49:56 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:09:50:02 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:09:50:12 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:09:50:15 ce1 CE001 === Setup ended ===
2013/2/27:09:52:22 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:52:22 ce1 CE001 Launch
2013/2/27:09:52:24 ce1 CE001 === Setup ended ===
2013/2/27:09:52:23 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:52:23 ce1 CE001 Launch
2013/2/27:09:52:24 ce1 CE001 PageOpen LaunchDialog
2013/2/27:09:52:25 ce1 CE001 PageOpen LicenseDialog
2013/2/27:09:52:27 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:09:52:30 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:09:52:32 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:09:52:32 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:09:52:36 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:09:52:36 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:09:52:40 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:09:52:40 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:09:53:06 ce1 CE001 === Setup ended ===
2013/2/27:09:59:07 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:59:07 ce1 CE001 Launch
2013/2/27:09:59:09 ce1 CE001 === Setup ended ===
2013/2/27:09:59:08 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:09:59:08 ce1 CE001 Launch
2013/2/27:09:59:09 ce1 CE001 PageOpen LaunchDialog
2013/2/27:09:59:10 ce1 CE001 PageOpen LicenseDialog
2013/2/27:09:59:13 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:09:59:15 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:09:59:18 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:09:59:18 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:09:59:20 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:09:59:20 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:09:59:25 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:09:59:25 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:09:59:52 ce1 CE001 === Setup ended ===
2013/2/27:10:00:12 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:00:12 ce1 CE001 Launch
2013/2/27:10:00:15 ce1 CE001 === Setup ended ===
2013/2/27:10:00:14 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:00:14 ce1 CE001 Launch
2013/2/27:10:00:15 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:00:16 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:00:17 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:00:20 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:00:22 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:00:22 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:00:26 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:10:00:26 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:10:00:34 ce1 CE001 === Setup ended ===
2013/2/27:10:15:43 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:15:43 ce1 CE001 Launch
2013/2/27:10:16:26 ce1 CE001 === Setup ended ===
2013/2/27:10:15:49 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:15:49 ce1 CE001 Launch
2013/2/27:10:16:26 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:16:28 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:16:30 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:16:33 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:16:34 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:16:35 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:10:16:38 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:10:16:38 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:16:42 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:10:16:52 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:10:20:06 ce1 CE001 === Setup ended ===
2013/2/27:10:29:08 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:29:08 ce1 CE001 Launch
2013/2/27:10:29:10 ce1 CE001 === Setup ended ===
2013/2/27:10:29:09 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:29:09 ce1 CE001 Launch
2013/2/27:10:29:10 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:29:11 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:29:13 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:29:16 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:29:18 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:29:18 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:29:21 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/2/27:10:29:22 ce1 CE001 PageOpen InstallCompleteDialog
2013/2/27:10:29:43 ce1 CE001 === Setup ended ===
2013/2/27:10:46:19 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:46:19 ce1 CE001 Launch
2013/2/27:10:46:21 ce1 CE001 === Setup ended ===
2013/2/27:10:46:20 ce1 CE001 === Setup started on CE001 by ce1 ===
2013/2/27:10:46:20 ce1 CE001 Launch
2013/2/27:10:46:21 ce1 CE001 PageOpen LaunchDialog
2013/2/27:10:46:22 ce1 CE001 PageOpen LicenseDialog
2013/2/27:10:46:24 ce1 CE001 PageOpen ProductInfoDialog
2013/2/27:10:46:27 ce1 CE001 PageOpen ProductSelectionDialog2
2013/2/27:10:48:24 ce1 CE001 PageOpen FullProgressDialog
2013/2/27:10:48:24 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/2/27:10:48:26 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/2/27:10:48:26 ce1 CE001 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/2/27:10:48:29 ce1 CE001 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
TravisNave
Message 5 of 7 (213 Views)
02-27-2013 08:30 AM in reply to: cec
See if you can install this prerequisite manually from Microsoft direct.
http://www.microsoft.com/en-us/download/details.aspx?id=2092
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. If it is already installed, uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
cec
Active Member
cec
Message 6 of 7 (197 Views)
02-27-2013 10:00 AM in reply to: TravisNave
Yes i was able to install it directly from the link but it still fails with the same error, I also read through your other post and nothing from there has worked either. I have completly uninstalled visual from the computer and nothing has worked.
TravisNave
Message 7 of 7 (194 Views)
02-27-2013 10:02 AM in reply to: cec
Your only recourse will be to install directly from the link, then modify the setup.ini file to exclude the requirement check for the prerequisite.  This is a very difficult task.  I do have instructions on how to do that in the follow-up to the link I provided.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
