Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Installati on Failure AutoCAD 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have tried many times to get this to install, yet it has failed every time.
here is my installation log:
2012/12/16:13:00:55 Bobby KIDSPC === Setup started on KIDSPC by Bobby === 2012/12/16:13:00:55 Bobby KIDSPC Launch 2012/12/16:13:00:55 Bobby KIDSPC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013
2012/12/16:13:01:00 Bobby KIDSPC === Setup started on KIDSPC by Bobby === 2012/12/16:13:01:00 Bobby KIDSPC Launch 2012/12/16:13:01:06 Bobby KIDSPC Download Play SET
2012/12/16:13:06:03 Bobby KIDSPC Install Autodesk
2012/12/16:13:08:45 Bobby KIDSPC Install Autodesk Material Library 2013 Succeeded 2012/12/16:13:08:46 Bobby KIDSPC Download Play CMI
2012/12/16:13:11:06 Bobby KIDSPC Install Autodesk Material Library 2013 - Base Image Library Succeeded 2012/12/16:13:11:07 Bobby KIDSPC Download Play DIR
2012/12/16:13:18:45 Bobby KIDSPC Install Autodesk Material Library 2013 - Low Image Library Succeeded 2012/12/16:13:18:46 Bobby KIDSPC Download Play UNI
2012/12/16:13:18:53 Bobby KIDSPC Install Quick Uninstall Tool for Autodesk® Inventor® 2013 Succeeded 2012/12/16:13:18:54 Bobby KIDSPC Download Play INV
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having the same problem, but with a diferent error code 1625 (see the log attached). Can anybody help me please?
Tks
Paulo
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My installation failled of "Infrastruc Design Ste Premium 2013 English". Some of the products said it successfully installed, but nothing worked. So I tried un-installing.Some products where able to be un-installed, but Civil 3D would not. It would hang as soon as you clicked un-install from "Add/Remove" Programs. I even let it sit over night, it just said "initiallizing", but never progressed. I've tried re-booting.
How can I completely uninstall, so I can re-install.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can someone help me with this problem? I am trying to install this product for two days and I can't pass from this error.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
One thing that I note is odd is that your profile appears to be on the D:\ while the application is trying to install default to C:\. Perhaps your non-standard setup is causing some odd behavior?
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Installati on Failure AutoCAD 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My installation of AutoCAD 2013 failed. I'm unable to figure out what exactly failed from the log. Anyone?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mkrones wrote:My installation of AutoCAD 2013 failed. I'm unable to figure out what exactly failed from the log. Anyone?
Make sure you don't have any other flavor of AutoCAD 2013 already installed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you. Will the new 2013 installation use configurations from my 2012 installation? Directory locations, desktop setup, etc. Or will I have to set all of that stuff up again?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It should ask you to migrate your settings from the old version.
You do not need to uninstall 2012.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello and thank you for your answer. D: is my windows drive, and I let the program to install in his default location but unfortunately with no result. Can you please help me with further information?
Thank you for your time and support.
Best regards,
Ionut Manea
