Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
Installation Failure AutoCAD 2013
2 REPLIES 2
Lpiu
681 Views, 2 Replies
I try to install AutoCAD 2013 but i have a problem.
I tried to uninstall all programs .NET, as suggested by Autodesk support, and re-install AutoCAD. The problem remains!
I attach the file log of installation.
How do I resolve this issue?
2 REPLIES 2
emily.xu
in reply to: Lpiu
Hi, mail
Wecome to autodesk community and I will help you with your installation issue.
From the log file, I can see the .net framework installation is successful. The error happens during installing AutoCAD with the error code 1603, this type of error generally related to your user rights,so I would give you the following suggestions:
1  Please try to install your Autodesk Product with an admin user. I recommand the default system Administrator user.
2  Please turn off the antivirus and firewall application.
3  Please turn off UAC if your OS is Windows vista/7.
4  Try to copy the installation file to your local harddisk and install from there.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Lpiu
in reply to: emily.xu
Thank you so much for your suggestions, but I can't install the program.
I've tried to install AutoCAD launching Windows in Diagnostic Mode and with admin user.
I attach the file log of installation. I hope to risolve the issue early.
Administrator Productivity
