Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Installati on Failure AutoCAD 2013
- Highlight
- Email to a Friend
I have tried numerous times to install AutoCAD 2013 and it gets to the end it says INSTALLATION COMPLETE SOME PRODUCTS FAILED TO INSTALL and NOTHING has installed.PLEASE HELP I have homework due!
Re: Installati on Failure AutoCAD 2013
- Highlight
- Email to a Friend
I had same problem with 2012, what's happening is you probably have a newer version of some required M$ component such as "Microsoft Visual C++ 2010 Redistributable". I has version 10.4.xxx Autodesk wanted 10.3.xxx but Windoze doesn't allow installing older version only newer. When this failed everything stops.
Autodesk installer should catch this and use the newer version or if M$ has their DLLs so screwed up that they can't use 10.4 instead of 10.3 at least report the error somewhere besides the installation log file wher I found it.
Work around:
Uninstall Microsoft Visual C++ 2010 Redistributable, and or Microsoft Visual C++ 2005 Redistributable (from the control panel) as needed and then AutoCAD will install. I don't know if it breaks if you then update your redist back to the latest and grat(ing)est version.
Good luck!
- Highlight
- Email to a Friend
Please include your installation log file and it should have more information on the reason for installation failure.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Installati on Failure AutoCAD 2013
- Highlight
- Email to a Friend
I'm also having trouble installing AutoCAD 2013 on my computer. I'm running Windows 7 Pro 64-bit and I receive the following in the installation log file:
2012/7/16:15:28:16 maddie BURTON_FEELGOOD === Setup started on BURTON_FEELGOOD by maddie ===
2012/7/16:15:28:16 maddie BURTON_FEELGOOD Launch
2012/7/16:15:28:18 maddie BURTON_FEELGOOD PageOpen LaunchDialog
2012/7/16:15:29:40 maddie BURTON_FEELGOOD PageOpen LicenseDialog
2012/7/16:15:29:43 maddie BURTON_FEELGOOD PageOpen ProductInfoDialog
2012/7/16:15:30:12 maddie BURTON_FEELGOOD PageOpen ProductSelectionDialog2
2012/7/16:15:30:22 maddie BURTON_FEELGOOD PageOpen FullProgressDialog
2012/7/16:15:30:22 maddie BURTON_FEELGOOD Installing DirectX Runtime: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdPart
2012/7/16:15:31:03 maddie BURTON_FEELGOOD Install DirectX Runtime Succeeded
2012/7/16:15:31:03 maddie BURTON_FEELGOOD Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English
2012/7/16:15:31:26 maddie BURTON_FEELGOOD Install FaroSDK Succeeded
2012/7/16:15:31:26 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English
2012/7/16:15:31:50 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 Succeeded
2012/7/16:15:31:50 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English
2012/7/16:15:32:03 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/16:15:32:03 maddie BURTON_FEELGOOD Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_6
2012/7/16:15:32:14 maddie BURTON_FEELGOOD Install Autodesk Content Service Succeeded
2012/7/16:15:32:14 maddie BURTON_FEELGOOD Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English
2012/7/16:15:32:22 maddie BURTON_FEELGOOD Install Autodesk Content Service Language Pack Succeeded
2012/7/16:15:32:23 maddie BURTON_FEELGOOD Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_6
2012/7/16:15:36:12 maddie BURTON_FEELGOOD Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/7/16:15:36:17 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Language Pack Succeeded
2012/7/16:15:36:23 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Succeeded
2012/7/16:15:36:32 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/16:15:36:47 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 Succeeded
2012/7/16:15:36:50 maddie BURTON_FEELGOOD Rollback FaroSDK Succeeded
2012/7/16:15:36:50 maddie BURTON_FEELGOOD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
- Highlight
- Email to a Friend
I too am having installation failures. Installation log attached. Need to get this up and running ASAP, so TIA for any help!
- Highlight
- Email to a Friend
Yours is easy.
Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensi
Good Luck!
- Highlight
- Email to a Friend
I uninstalled the C++ Redistributable and the .NET Runtime 4.0 and I'm still getting the following failed installation log:
2012/7/17:20:29:10 maddie BURTON_FEELGOOD === Setup started on BURTON_FEELGOOD by maddie ===
2012/7/17:20:29:10 maddie BURTON_FEELGOOD Launch
2012/7/17:20:29:22 maddie BURTON_FEELGOOD PageOpen LaunchDialog
2012/7/17:20:29:26 maddie BURTON_FEELGOOD PageOpen LicenseDialog
2012/7/17:20:29:28 maddie BURTON_FEELGOOD PageOpen ProductInfoDialog
2012/7/17:20:29:38 maddie BURTON_FEELGOOD PageOpen ProductSelectionDialog2
2012/7/17:20:29:44 maddie BURTON_FEELGOOD PageOpen FullProgressDialog
2012/7/17:20:29:44 maddie BURTON_FEELGOOD Installing .NET Framework Runtime 4.0: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_6
2012/7/17:20:31:54 maddie BURTON_FEELGOOD Install .NET Framework Runtime 4.0 Succeeded
2012/7/17:20:31:54 maddie BURTON_FEELGOOD Installing .NET Framework Runtime 4.0 KB2468871: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_6
2012/7/17:20:34:57 maddie BURTON_FEELGOOD Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2012/7/17:20:34:57 maddie BURTON_FEELGOOD Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_6
2012/7/17:20:35:05 maddie BURTON_FEELGOOD Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/7/17:20:35:05 maddie BURTON_FEELGOOD Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_6
2012/7/17:20:35:14 maddie BURTON_FEELGOOD Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/7/17:20:35:14 maddie BURTON_FEELGOOD Installing DirectX Runtime: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_6
2012/7/17:20:36:06 maddie BURTON_FEELGOOD Install DirectX Runtime Succeeded
2012/7/17:20:36:06 maddie BURTON_FEELGOOD Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_
2012/7/17:20:36:29 maddie BURTON_FEELGOOD Install FaroSDK Succeeded
2012/7/17:20:36:29 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_
2012/7/17:20:37:09 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 Succeeded
2012/7/17:20:37:09 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_
2012/7/17:20:37:24 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/17:20:37:24 maddie BURTON_FEELGOOD Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\maddie\Desktop\AutoCAD_2013_E
2012/7/17:20:37:41 maddie BURTON_FEELGOOD Install Autodesk Content Service Succeeded
2012/7/17:20:37:41 maddie BURTON_FEELGOOD Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_
2012/7/17:20:37:49 maddie BURTON_FEELGOOD Install Autodesk Content Service Language Pack Succeeded
2012/7/17:20:37:49 maddie BURTON_FEELGOOD Installing AutoCAD® 2013: TRANSFORMS="C:\Users\maddie\Desktop\AutoCAD_2013_E
2012/7/17:20:41:46 maddie BURTON_FEELGOOD Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/7/17:20:41:52 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Language Pack Succeeded
2012/7/17:20:41:57 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Succeeded
2012/7/17:20:42:09 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/17:20:42:26 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 Succeeded
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback FaroSDK Succeeded
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
- Highlight
- Email to a Friend
you're a saver. works for me now.
i just registered to say thanks!
- Highlight
- Email to a Friend
Can someone please help me. I'm having the same issue!
My Log file:
2012/12/1:10:52:41 johannes.burger JC_B1 PageOpen InstallCompleteDialog
2012/12/1:10:54:12 johannes.burger JC_B1 === Setup ended ===
2012/12/1:10:54:19 johannes.burger JC_B1 === Setup started on JC_B1 by johannes.burger ===
2012/12/1:10:54:19 johannes.burger JC_B1 Launch
2012/12/1:10:54:27 johannes.burger JC_B1 === Setup ended ===
2012/12/1:10:54:27 johannes.burger JC_B1 Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/1:10:54:27 johannes.burger JC_B1 Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/1:10:54:27 johannes.burger JC_B1 PageOpen LaunchDialog
2012/12/1:10:56:50 johannes.burger JC_B1 PageOpen LicenseDialog
2012/12/1:10:56:53 johannes.burger JC_B1 PageOpen ProductInfoDialog
2012/12/1:10:57:17 johannes.burger JC_B1 PageOpen ProductSelectionDialog2
2012/12/1:10:57:42 johannes.burger JC_B1 PageOpen FullProgressDialog
2012/12/1:10:57:42 johannes.burger JC_B1 Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/1:10:58:41 johannes.burger JC_B1 Install DirectX® Runtime Succeeded
2012/12/1:10:58:41 johannes.burger JC_B1 Installing AutoCAD® 2013: TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\JO
2012/12/1:11:00:09 johannes.burger JC_B1 Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/12/1:11:00:09 johannes.burger JC_B1 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
- Highlight
- Email to a Friend
I am facing this probelm loading Acad 2013...
2012/12/11:22:30:44 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:30:44 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:31:52 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:31:18 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:31:18 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:31:45 GB-Terence TERENCENOTEBOOK PageOpen LaunchDialog
2012/12/11:22:32:12 GB-Terence TERENCENOTEBOOK PageOpen LicenseDialog
2012/12/11:22:32:29 GB-Terence TERENCENOTEBOOK PageOpen ProductInfoDialog
2012/12/11:22:33:11 GB-Terence TERENCENOTEBOOK PageOpen ProductSelectionDialog2
2012/12/11:22:33:16 GB-Terence TERENCENOTEBOOK PageOpen FullProgressDialog
2012/12/11:22:33:17 GB-Terence TERENCENOTEBOOK Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP
2012/12/11:22:33:29 GB-Terence TERENCENOTEBOOK Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2012/12/11:22:34:04 GB-Terence TERENCENOTEBOOK PageOpen InstallCompleteDialog
2012/12/11:22:34:45 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:35:52 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:35:52 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:36:00 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:35:55 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:35:55 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:35:57 GB-Terence TERENCENOTEBOOK PageOpen LaunchDialog
2012/12/11:22:36:17 GB-Terence TERENCENOTEBOOK PageOpen BeginDeploymentDialog
2012/12/11:22:36:30 GB-Terence TERENCENOTEBOOK PageOpen LaunchDialog
2012/12/11:22:36:38 GB-Terence TERENCENOTEBOOK PageOpen LicenseDialog
2012/12/11:22:36:38 GB-Terence TERENCENOTEBOOK PageOpen ProductSelectionDialog2
2012/12/11:22:36:52 GB-Terence TERENCENOTEBOOK PageOpen FullProgressDialog
2012/12/11:22:36:52 GB-Terence TERENCENOTEBOOK Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_
2012/12/11:22:36:54 GB-Terence TERENCENOTEBOOK Install Network License Manager Succeeded
2012/12/11:22:36:54 GB-Terence TERENCENOTEBOOK Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x86_
2012/12/11:22:37:04 GB-Terence TERENCENOTEBOOK Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/12/11:22:37:04 GB-Terence TERENCENOTEBOOK Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x64_
2012/12/11:22:37:10 GB-Terence TERENCENOTEBOOK Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/12/11:22:37:10 GB-Terence TERENCENOTEBOOK Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_
2012/12/11:22:37:16 GB-Terence TERENCENOTEBOOK Install Autodesk CAD Manager Tools Succeeded
2012/12/11:22:37:16 GB-Terence TERENCENOTEBOOK Installing Autodesk Content Service: TRANSFORMS="E:\x64\en-us\Tools\snap\ContentService
2012/12/11:22:37:30 GB-Terence TERENCENOTEBOOK Install Autodesk Content Service Succeeded
2012/12/11:22:37:32 GB-Terence TERENCENOTEBOOK Installing Autodesk Content Service Language Pack: TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_
2012/12/11:22:37:35 GB-Terence TERENCENOTEBOOK Install Autodesk Content Service Language Pack Succeeded
2012/12/11:22:37:36 GB-Terence TERENCENOTEBOOK PageOpen InstallCompleteDialog
2012/12/11:22:37:39 GB-Terence TERENCENOTEBOOK [Error: 1056] An instance of the service is already running.
2012/12/11:22:37:39 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:37:52 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:37:52 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:37:59 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:37:54 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:37:54 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:37:57 GB-Terence TERENCENOTEBOOK PageOpen LaunchDialog
2012/12/11:22:38:00 GB-Terence TERENCENOTEBOOK PageOpen LicenseDialog
2012/12/11:22:38:08 GB-Terence TERENCENOTEBOOK PageOpen ProductInfoDialog
2012/12/11:22:38:24 GB-Terence TERENCENOTEBOOK PageOpen ProductSelectionDialog2
2012/12/11:22:38:31 GB-Terence TERENCENOTEBOOK PageOpen FullProgressDialog
2012/12/11:22:38:31 GB-Terence TERENCENOTEBOOK Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_
2012/12/11:22:40:26 GB-Terence TERENCENOTEBOOK Install Autodesk® Design Review 2013 Succeeded
2012/12/11:22:40:26 GB-Terence TERENCENOTEBOOK Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP
2012/12/11:22:40:34 GB-Terence TERENCENOTEBOOK Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2012/12/11:22:40:42 GB-Terence TERENCENOTEBOOK Rollback Autodesk® Design Review 2013 Succeeded
2012/12/11:22:40:42 GB-Terence TERENCENOTEBOOK PageOpen InstallCompleteDialog
2012/12/11:22:42:42 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:49:44 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:49:44 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:49:51 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:49:47 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:49:47 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:49:49 GB-Terence TERENCENOTEBOOK PageOpen LaunchDialog
2012/12/11:22:49:54 GB-Terence TERENCENOTEBOOK PageOpen LicenseDialog
2012/12/11:22:49:54 GB-Terence TERENCENOTEBOOK PageOpen ProductSelectionDialog2
2012/12/11:22:50:00 GB-Terence TERENCENOTEBOOK PageOpen FullProgressDialog
2012/12/11:22:50:00 GB-Terence TERENCENOTEBOOK Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x86_
2012/12/11:22:50:06 GB-Terence TERENCENOTEBOOK Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/12/11:22:50:06 GB-Terence TERENCENOTEBOOK Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x64_
2012/12/11:22:50:13 GB-Terence TERENCENOTEBOOK Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/12/11:22:50:13 GB-Terence TERENCENOTEBOOK Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_
2012/12/11:22:50:15 GB-Terence TERENCENOTEBOOK Install Autodesk CAD Manager Tools Succeeded
2012/12/11:22:50:15 GB-Terence TERENCENOTEBOOK PageOpen InstallCompleteDialog
2012/12/11:22:50:17 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:50:30 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:50:30 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:50:37 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:22:50:32 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:50:32 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:22:50:35 GB-Terence TERENCENOTEBOOK PageOpen LaunchDialog
2012/12/11:22:50:42 GB-Terence TERENCENOTEBOOK PageOpen LicenseDialog
2012/12/11:22:50:53 GB-Terence TERENCENOTEBOOK PageOpen ProductInfoDialog
2012/12/11:22:51:12 GB-Terence TERENCENOTEBOOK PageOpen ProductSelectionDialog2
2012/12/11:22:51:25 GB-Terence TERENCENOTEBOOK PageOpen FullProgressDialog
2012/12/11:22:51:25 GB-Terence TERENCENOTEBOOK Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_
2012/12/11:22:51:41 GB-Terence TERENCENOTEBOOK Install Autodesk® Design Review 2013 Succeeded
2012/12/11:22:51:41 GB-Terence TERENCENOTEBOOK Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP
2012/12/11:22:51:51 GB-Terence TERENCENOTEBOOK Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
2012/12/11:22:51:58 GB-Terence TERENCENOTEBOOK Rollback Autodesk® Design Review 2013 Succeeded
2012/12/11:22:52:06 GB-Terence TERENCENOTEBOOK PageOpen InstallCompleteDialog
2012/12/11:22:52:15 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:23:00:35 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:23:00:35 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:23:00:42 GB-Terence TERENCENOTEBOOK === Setup ended ===
2012/12/11:23:00:37 GB-Terence TERENCENOTEBOOK === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:23:00:37 GB-Terence TERENCENOTEBOOK Launch
2012/12/11:23:00:40 GB-Terence TERENCENOTEBOOK PageOpen LaunchDialog
2012/12/11:23:01:26 GB-Terence TERENCENOTEBOOK PageOpen LicenseDialog
2012/12/11:23:01:42 GB-Terence TERENCENOTEBOOK PageOpen ProductInfoDialog
2012/12/11:23:01:55 GB-Terence TERENCENOTEBOOK PageOpen ProductSelectionDialog2
2012/12/11:23:02:05 GB-Terence TERENCENOTEBOOK PageOpen FullProgressDialog
2012/12/11:23:02:05 GB-Terence TERENCENOTEBOOK Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP
2012/12/11:23:02:27 GB-Terence TERENCENOTEBOOK Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
