Installation & Licensing
Installation Failure AutoCAD 2013
37 REPLIES 37
Message 1 of 38
39287 Views, 37 Replies
I have tried numerous times to install AutoCAD 2013 and it gets to the end it says INSTALLATION COMPLETE SOME PRODUCTS FAILED TO INSTALL and NOTHING has installed.PLEASE HELP I have homework due!
37 REPLIES 37
Message 2 of 38
I had same problem with 2012, what's happening is you probably have a newer version of some required M$ component such as "Microsoft Visual C++ 2010 Redistributable". I has version 10.4.xxx Autodesk wanted 10.3.xxx but Windoze doesn't allow installing older version only newer. When this failed everything stops.
Autodesk installer should catch this and use the newer version or if M$ has their DLLs so screwed up that they can't use 10.4 instead of 10.3 at least report the error somewhere besides the installation log file wher I found it.
Work around:
Uninstall Microsoft Visual C++ 2010 Redistributable, and or Microsoft Visual C++ 2005 Redistributable (from the control panel) as needed and then AutoCAD will install. I don't know if it breaks if you then update your redist back to the latest and grat(ing)est version.
Good luck!
Message 3 of 38
TravisNave
Please include your installation log file and it should have more information on the reason for installation failure.
Autodesk Forums:
Message 4 of 38
I'm also having trouble installing AutoCAD 2013 on my computer. I'm running Windows 7 Pro 64-bit and I receive the following in the installation log file:
2012/7/16:15:28:16 maddie BURTON_FEELGOOD === Setup started on BURTON_FEELGOOD by maddie ===
2012/7/16:15:28:16 maddie BURTON_FEELGOOD Launch
2012/7/16:15:28:18 maddie BURTON_FEELGOOD PageOpen LaunchDialog
2012/7/16:15:29:40 maddie BURTON_FEELGOOD PageOpen LicenseDialog
2012/7/16:15:29:43 maddie BURTON_FEELGOOD PageOpen ProductInfoDialog
2012/7/16:15:30:12 maddie BURTON_FEELGOOD PageOpen ProductSelectionDialog2
2012/7/16:15:30:22 maddie BURTON_FEELGOOD PageOpen FullProgressDialog
2012/7/16:15:30:22 maddie BURTON_FEELGOOD Installing DirectX Runtime: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/7/16:15:31:03 maddie BURTON_FEELGOOD Install DirectX Runtime Succeeded
2012/7/16:15:31:03 maddie BURTON_FEELGOOD Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:31:26 maddie BURTON_FEELGOOD Install FaroSDK Succeeded
2012/7/16:15:31:26 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:31:50 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 Succeeded
2012/7/16:15:31:50 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:32:03 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/16:15:32:03 maddie BURTON_FEELGOOD Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:32:14 maddie BURTON_FEELGOOD Install Autodesk Content Service Succeeded
2012/7/16:15:32:14 maddie BURTON_FEELGOOD Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:32:22 maddie BURTON_FEELGOOD Install Autodesk Content Service Language Pack Succeeded
2012/7/16:15:32:23 maddie BURTON_FEELGOOD Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\maddie\AppData\Local\Temp\_AIBA2B.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/16:15:36:12 maddie BURTON_FEELGOOD Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/7/16:15:36:17 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Language Pack Succeeded
2012/7/16:15:36:23 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Succeeded
2012/7/16:15:36:32 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/16:15:36:47 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 Succeeded
2012/7/16:15:36:50 maddie BURTON_FEELGOOD Rollback FaroSDK Succeeded
2012/7/16:15:36:50 maddie BURTON_FEELGOOD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Message 5 of 38
Com-Ex
I too am having installation failures.  Installation log attached.  Need to get this up and running ASAP, so TIA for any help!
Message 6 of 38
TravisNave
in reply to: Com-Ex
Yours is easy.
Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Message 7 of 38
in reply to: TravisNave
I uninstalled the C++ Redistributable and the .NET Runtime 4.0 and I'm still getting the following failed installation log:
2012/7/17:20:29:10 maddie BURTON_FEELGOOD === Setup started on BURTON_FEELGOOD by maddie ===
2012/7/17:20:29:10 maddie BURTON_FEELGOOD Launch
2012/7/17:20:29:22 maddie BURTON_FEELGOOD PageOpen LaunchDialog
2012/7/17:20:29:26 maddie BURTON_FEELGOOD PageOpen LicenseDialog
2012/7/17:20:29:28 maddie BURTON_FEELGOOD PageOpen ProductInfoDialog
2012/7/17:20:29:38 maddie BURTON_FEELGOOD PageOpen ProductSelectionDialog2
2012/7/17:20:29:44 maddie BURTON_FEELGOOD PageOpen FullProgressDialog
2012/7/17:20:29:44 maddie BURTON_FEELGOOD Installing .NET Framework Runtime 4.0: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/7/17:20:31:54 maddie BURTON_FEELGOOD Install .NET Framework Runtime 4.0 Succeeded
2012/7/17:20:31:54 maddie BURTON_FEELGOOD Installing .NET Framework Runtime 4.0 KB2468871: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/7/17:20:34:57 maddie BURTON_FEELGOOD Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2012/7/17:20:34:57 maddie BURTON_FEELGOOD Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\maddie\AppData\Local\Temp\vcredist_x86_2010.log
2012/7/17:20:35:05 maddie BURTON_FEELGOOD Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/7/17:20:35:05 maddie BURTON_FEELGOOD Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\maddie\AppData\Local\Temp\vcredist_x64_2010.log
2012/7/17:20:35:14 maddie BURTON_FEELGOOD Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/7/17:20:35:14 maddie BURTON_FEELGOOD Installing DirectX Runtime: C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/7/17:20:36:06 maddie BURTON_FEELGOOD Install DirectX Runtime Succeeded
2012/7/17:20:36:06 maddie BURTON_FEELGOOD Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:36:29 maddie BURTON_FEELGOOD Install FaroSDK Succeeded
2012/7/17:20:36:29 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:09 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 Succeeded
2012/7/17:20:37:09 maddie BURTON_FEELGOOD Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:24 maddie BURTON_FEELGOOD Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/17:20:37:24 maddie BURTON_FEELGOOD Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:41 maddie BURTON_FEELGOOD Install Autodesk Content Service Succeeded
2012/7/17:20:37:41 maddie BURTON_FEELGOOD Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:37:49 maddie BURTON_FEELGOOD Install Autodesk Content Service Language Pack Succeeded
2012/7/17:20:37:49 maddie BURTON_FEELGOOD Installing AutoCAD® 2013: TRANSFORMS="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\maddie\AppData\Local\Temp\_AIB901.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\maddie\Desktop\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/7/17:20:41:46 maddie BURTON_FEELGOOD Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/7/17:20:41:52 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Language Pack Succeeded
2012/7/17:20:41:57 maddie BURTON_FEELGOOD Rollback Autodesk Content Service Succeeded
2012/7/17:20:42:09 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/7/17:20:42:26 maddie BURTON_FEELGOOD Rollback Autodesk Material Library 2013 Succeeded
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback FaroSDK Succeeded
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2012/7/17:20:42:31 maddie BURTON_FEELGOOD Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
Message 8 of 38
you're a saver. works for me now.
i just registered to say thanks!
Message 9 of 38
staaldraad
Can someone please help me. I'm having the same issue!
My Log file:
2012/12/1:10:52:41    johannes.burger    JC_B1    PageOpen    InstallCompleteDialog
2012/12/1:10:54:12    johannes.burger    JC_B1    === Setup ended ===
2012/12/1:10:54:19    johannes.burger    JC_B1    === Setup started on JC_B1 by johannes.burger ===
2012/12/1:10:54:19    johannes.burger    JC_B1    Launch
2012/12/1:10:54:27    johannes.burger    JC_B1    === Setup ended ===
2012/12/1:10:54:27    johannes.burger    JC_B1    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/1:10:54:27    johannes.burger    JC_B1    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/1:10:54:27    johannes.burger    JC_B1    PageOpen    LaunchDialog
2012/12/1:10:56:50    johannes.burger    JC_B1    PageOpen    LicenseDialog
2012/12/1:10:56:53    johannes.burger    JC_B1    PageOpen    ProductInfoDialog
2012/12/1:10:57:17    johannes.burger    JC_B1    PageOpen    ProductSelectionDialog2
2012/12/1:10:57:42    johannes.burger    JC_B1    PageOpen    FullProgressDialog
2012/12/1:10:57:42    johannes.burger    JC_B1    Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/1:10:58:41    johannes.burger    JC_B1    Install    DirectX® Runtime    Succeeded
2012/12/1:10:58:41    johannes.burger    JC_B1    Installing AutoCAD® 2013:  TRANSFORMS="E:\x64\en-us\acad\acad.mst;C:\Users\JOHANN~1.BUR\AppData\Local\Temp\_AI25B9.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/1:11:00:09    johannes.burger    JC_B1    Install    AutoCAD® 2013    Failed    Installation aborted, Result=1603
2012/12/1:11:00:09    johannes.burger    JC_B1    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
Message 10 of 38
Terenceng
I am facing this probelm loading Acad 2013...
2012/12/11:22:30:44    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:30:44    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:31:52    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:31:18    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:31:18    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:31:45    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:32:12    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:32:29    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:22:33:11    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:33:16    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:33:17    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:22:33:29    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2012/12/11:22:34:04    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:34:45    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:35:52    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:35:52    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:36:00    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:35:55    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:35:55    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:35:57    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:36:17    GB-Terence    TERENCENOTEBOOK    PageOpen    BeginDeploymentDialog
2012/12/11:22:36:30    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:36:38    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:36:38    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:36:52    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:36:52    GB-Terence    TERENCENOTEBOOK    Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\Media.mst"
 2012/12/11:22:36:54    GB-Terence    TERENCENOTEBOOK    Install    Network License Manager    Succeeded
2012/12/11:22:36:54    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/11:22:37:04    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2012/12/11:22:37:04    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x64_2010.log
2012/12/11:22:37:10    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2012/12/11:22:37:10    GB-Terence    TERENCENOTEBOOK    Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\Media.mst"
 2012/12/11:22:37:16    GB-Terence    TERENCENOTEBOOK    Install    Autodesk CAD Manager Tools    Succeeded
2012/12/11:22:37:16    GB-Terence    TERENCENOTEBOOK    Installing Autodesk Content Service:  TRANSFORMS="E:\x64\en-us\Tools\snap\ContentService.mst;C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\x64\Tools\snap\ContentService-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:37:30    GB-Terence    TERENCENOTEBOOK    Install    Autodesk Content Service    Succeeded
2012/12/11:22:37:32    GB-Terence    TERENCENOTEBOOK    Installing Autodesk Content Service Language Pack:  TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI24DD.tmp\_laA6B0.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:37:35    GB-Terence    TERENCENOTEBOOK    Install    Autodesk Content Service Language Pack    Succeeded
2012/12/11:22:37:36    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:37:39    GB-Terence    TERENCENOTEBOOK    [Error: 1056] An instance of the service is already running.
2012/12/11:22:37:39    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:37:52    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:37:52    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:37:59    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:37:54    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:37:54    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:37:57    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:38:00    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:38:08    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:22:38:24    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:38:31    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:38:31    GB-Terence    TERENCENOTEBOOK    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AIF865.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:40:26    GB-Terence    TERENCENOTEBOOK    Install    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:40:26    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:22:40:34    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2012/12/11:22:40:42    GB-Terence    TERENCENOTEBOOK    Rollback    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:40:42    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:42:42    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:49:44    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:49:44    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:49:51    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:49:47    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:49:47    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:49:49    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:49:54    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:49:54    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:50:00    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:50:00    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/11:22:50:06    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2012/12/11:22:50:06    GB-Terence    TERENCENOTEBOOK    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\GB-TER~1\AppData\Local\Temp\vcredist_x64_2010.log
2012/12/11:22:50:13    GB-Terence    TERENCENOTEBOOK    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2012/12/11:22:50:13    GB-Terence    TERENCENOTEBOOK    Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AID557.tmp\Media.mst"
 2012/12/11:22:50:15    GB-Terence    TERENCENOTEBOOK    Install    Autodesk CAD Manager Tools    Succeeded
2012/12/11:22:50:15    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:50:17    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:50:30    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:50:30    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:50:37    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:22:50:32    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:22:50:32    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:22:50:35    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:22:50:42    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:22:50:53    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:22:51:12    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:22:51:25    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:22:51:25    GB-Terence    TERENCENOTEBOOK    Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\GB-TER~1\AppData\Local\Temp\_AI89E1.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/11:22:51:41    GB-Terence    TERENCENOTEBOOK    Install    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:51:41    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:22:51:51    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
2012/12/11:22:51:58    GB-Terence    TERENCENOTEBOOK    Rollback    Autodesk® Design Review 2013    Succeeded
2012/12/11:22:52:06    GB-Terence    TERENCENOTEBOOK    PageOpen    InstallCompleteDialog
2012/12/11:22:52:15    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:23:00:35    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:23:00:35    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:23:00:42    GB-Terence    TERENCENOTEBOOK    === Setup ended ===
2012/12/11:23:00:37    GB-Terence    TERENCENOTEBOOK    === Setup started on TERENCENOTEBOOK by GB-Terence ===
2012/12/11:23:00:37    GB-Terence    TERENCENOTEBOOK    Launch
2012/12/11:23:00:40    GB-Terence    TERENCENOTEBOOK    PageOpen    LaunchDialog
2012/12/11:23:01:26    GB-Terence    TERENCENOTEBOOK    PageOpen    LicenseDialog
2012/12/11:23:01:42    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductInfoDialog
2012/12/11:23:01:55    GB-Terence    TERENCENOTEBOOK    PageOpen    ProductSelectionDialog2
2012/12/11:23:02:05    GB-Terence    TERENCENOTEBOOK    PageOpen    FullProgressDialog
2012/12/11:23:02:05    GB-Terence    TERENCENOTEBOOK    Installing .NET Framework Runtime 4.0 Language Pack: E:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2012/12/11:23:02:27    GB-Terence    TERENCENOTEBOOK    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=1603
Message 11 of 38
I have tried many times to get this to install, yet it has failed every time.
here is my installation log:
2012/12/16:13:00:55 Bobby KIDSPC === Setup started on KIDSPC by Bobby === 2012/12/16:13:00:55 Bobby KIDSPC Launch 2012/12/16:13:00:55 Bobby KIDSPC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/Autodesk_Inventor_2013_English_Win_32b..." /SN 900-34593757 /PK 797E1 /student /skipEULA /akamai /auth  /sid   2012/12/16:13:02:47 Bobby KIDSPC === Setup ended ===
2012/12/16:13:01:00 Bobby KIDSPC === Setup started on KIDSPC by Bobby === 2012/12/16:13:01:00 Bobby KIDSPC Launch 2012/12/16:13:01:06 Bobby KIDSPC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:02:47 Bobby KIDSPC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:02:48 Bobby KIDSPC PageOpen LaunchDialog   2012/12/16:13:02:53 Bobby KIDSPC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2012/12/16:13:02:53 Bobby KIDSPC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2012/12/16:13:02:54 Bobby KIDSPC Inventorui== Parameter: Prereq_4 SetupMode:1 InstallState:2 InstallAction:0 Message: 2012/12/16:13:03:14 Bobby KIDSPC PageOpen LicenseDialog   2012/12/16:13:03:15 Bobby KIDSPC PageOpen ProductInfoDialog   2012/12/16:13:03:15 Bobby KIDSPC PageOpen InventorFlavorSelectionDialog   2012/12/16:13:03:15 Bobby KIDSPC Inventorui==DefaultLanguage: en-us    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==InstallName: INVENTOR    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==ProductName: Autodesk Inventor 2013    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==DisplayName: Autodesk® Inventor® 2013    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==DeploymentName:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==SetupTitle: Autodesk Inventor 2013    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==ConfigTransform:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==ExeParams:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==ProductCode: {7F4DD591-1732-0001-0000-7107D70F3DB4}    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==SupportLink:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==InfotainmentLink:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==MsiFileName: inventor.msi    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==AdminImageConfigName: AdminImagex86    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==AdminImageRoot:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==GetBaseDeploymentName:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==DeploymentLocation:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2013-enu    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==InstallDeploymentShortcut:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==ModifyDeploymentShortcut:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==SetupLockType: 2    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==SetupNetworkType:  1    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==SystemLocale: 1033    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==EvalMsiFilePath: C:\Users\Bobby\AppData\Local\Temp\_AI60E4.tmp\SetupRes\eval.msi    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2013\EULA    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==InstallLogPath: C:\Users\Bobby\AppData\Local\Temp\Inventor2013Install.log    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==ConfigFile: C:\Users\Bobby\AppData\Local\Temp\_AI60E4.tmp\Setup.ini    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==SetupPath: C:\Users\Bobby\AppData\Local\Temp\_AI60E4.tmp\    2012/12/16:13:03:15 Bobby KIDSPC Inventorui==NetworkLogPath:     2012/12/16:13:03:15 Bobby KIDSPC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2013    2012/12/16:13:03:31 Bobby KIDSPC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2012/12/16:13:03:31 Bobby KIDSPC PageOpen ProductSelectionDialog2   2012/12/16:13:03:44 Bobby KIDSPC PageOpen FullProgressDialog   2012/12/16:13:03:44 Bobby KIDSPC Uninstall {8D20B4D7-3422-4099-9332-39F27E617A6F} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {55D9E026-DCB0-46FF-B60A-68B972228CF6} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {450063AA-643B-417C-8CF5-405BA3F4EF40} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {106EC844-9F5E-4B72-BB3B-1E47D274A944} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {FACF203E-0F4D-489A-B80C-D185253C8FCB} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {1A2948E0-9445-42BE-9D01-472952F2657F} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {9A346205-EA92-4406-B1AB-50379DA3F057} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {C46C3C20-039E-4D7C-869F-9C0C05D65C06} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {577D60CB-0D5E-48D1-8850-84098AD34804} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {0576A3D0-0000-0409-0000-491C453655D7} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21} Failed  2012/12/16:13:03:44 Bobby KIDSPC Uninstall {4780F600-0000-0409-0000-114715ACF216} Failed  2012/12/16:13:03:45 Bobby KIDSPC Download Play ADR2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:04:50 Bobby KIDSPC Download Complete ADR2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:04:50 Bobby KIDSPC Installing Autodesk® Design Review 2013:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/16:13:06:03 Bobby KIDSPC Install Autodesk® Design Review 2013 Succeeded  2012/12/16:13:06:05 Bobby KIDSPC Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:07:43 Bobby KIDSPC Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:07:43 Bobby KIDSPC Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/16:13:08:45 Bobby KIDSPC Install Autodesk Material Library 2013 Succeeded  2012/12/16:13:08:46 Bobby KIDSPC Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:10:38 Bobby KIDSPC Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:10:38 Bobby KIDSPC Installing Autodesk Material Library 2013 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/16:13:11:06 Bobby KIDSPC Install Autodesk Material Library 2013 - Base Image Library Succeeded  2012/12/16:13:11:07 Bobby KIDSPC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:11:22 Bobby KIDSPC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:11:22 Bobby KIDSPC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Inventor 2013\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/16:13:11:43 Bobby KIDSPC Install DirectX® Runtime Succeeded  2012/12/16:13:11:44 Bobby KIDSPC Download Play CMILL2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:18:00 Bobby KIDSPC Download Complete CMILL2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:18:00 Bobby KIDSPC Installing Autodesk Material Library 2013 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/16:13:18:45 Bobby KIDSPC Install Autodesk Material Library 2013 - Low Image Library Succeeded  2012/12/16:13:18:46 Bobby KIDSPC Download Play UNINSTALLTOOL http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:18:49 Bobby KIDSPC Download Complete UNINSTALLTOOL http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:18:49 Bobby KIDSPC Installing Quick Uninstall Tool for Autodesk® Inventor® 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/16:13:18:53 Bobby KIDSPC Install Quick Uninstall Tool for Autodesk® Inventor® 2013 Succeeded  2012/12/16:13:18:54 Bobby KIDSPC Download Play INVENTOR http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:22:48 Bobby KIDSPC Download Aborted INVENTOR http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{80FA2C43-9949-47AE-8790-932325627F06}... 2012/12/16:13:22:48 Bobby KIDSPC Install Autodesk® Inventor® 2013 Failed Download Failed, Installation aborted, Result=1603 2012/12/16:13:23:37 Bobby KIDSPC Rollback Autodesk Material Library 2013 - Low Image Library Succeeded  2012/12/16:13:23:38 Bobby KIDSPC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/12/16:13:24:24 Bobby KIDSPC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded  2012/12/16:13:25:54 Bobby KIDSPC Rollback Autodesk Material Library 2013 Succeeded  2012/12/16:13:26:52 Bobby KIDSPC Rollback Autodesk® Design Review 2013 Succeeded
Message 12 of 38
I am having the same problem, but with a diferent error code 1625  (see the log attached). Can anybody help me please?
Tks
Paulo
Message 13 of 38
RobertMartin1782
My installation failled of "Infrastruc Design Ste Premium 2013 English". Some of the products said it successfully installed, but nothing worked. So I tried un-installing.Some products where able to be un-installed, but Civil 3D would not. It would hang as soon as you clicked un-install from "Add/Remove" Programs. I even let it sit over night, it just said "initiallizing", but never progressed. I've tried re-booting.
How can I completely uninstall, so I can re-install.
Message 14 of 38
Can someone help me with this problem? I am trying to install this product for two days and I can't pass from this error.
Message 15 of 38
TravisNave
One thing that I note is odd is that your profile appears to be on the D:\ while the application is trying to install default to C:\.  Perhaps your non-standard setup is causing some odd behavior?
Autodesk Forums:
Message 16 of 38
mkrones
My installation of AutoCAD 2013 failed.  I'm unable to figure out what exactly failed from the log.  Anyone?
Message 17 of 38
TravisNave
in reply to: mkrones
Make sure you don't have any other flavor of AutoCAD 2013  already installed.
Autodesk Forums:
Message 18 of 38
mkrones
Thank you.  Will the new 2013 installation use configurations from my 2012 installation?  Directory locations, desktop setup, etc. Or will I have to set all of that stuff up again?
Message 19 of 38
TravisNave
It should ask you to migrate your settings from the old version.
You do not need to uninstall 2012.
Autodesk Forums:
Message 20 of 38
Hello and thank you for your answer. 😧 is my windows drive, and I let the program to install in his default location but unfortunately with no result. Can you please help me with further information?
Thank you for your time and support.
Best regards,
Ionut Manea
Administrator Productivity
