Installation & Licensing
Active Member
joey.williams
Message 1 of 8 (416 Views)
Installation Failed Message, Numerous other errors on other attempts. Argh
416 Views, 7 Replies
12-02-2012 07:00 PM
I've tried installing 3ds max multiple times with no success, either a fail to start message, communication error message, or in this case, an installation failed message. I've probably tried to install 6 times, uninstalling and reinstalling each time, no success any time.
Computer specs:
8gb Ram
200+gb free hard drive space
2gb (pretty sure) graphics card
i7 1.5 GHz processor
Running windows 7, 64 bit
Any help would be greatly appreciated, hoping to install sketchbook and maya on here as well. Thanks a lot in advance!
Also: if you need more information to help solve, please let me know and i can email anything else; apparently the files are too large to attach in the message.
Product Support
aaronhai
Message 2 of 8 (406 Views)
Re: Installation Failed Message, Numerous other errors on other attempts. Argh
12-03-2012 02:02 AM in reply to: joey.williams
Hi joey.williams,
Please see if this Autodesk blogpost helps.
Thank you.
Aaron Hai
Active Member
joey.williams
Message 3 of 8 (379 Views)
12-03-2012 12:55 PM in reply to: aaronhai
I downloaded the direct x update, first time it said it was up to date and no further installation was necessary, so i tried once more and it said installation failed. uninstalled all of my autodesk files except for the one outside of my program files folder, and used the setup once more to try installation, all parts of the program failed to install, again.
Active Member
joey.williams
Message 4 of 8 (377 Views)
12-03-2012 12:58 PM in reply to: joey.williams
2012/12/3:14:51:24 Joey JOEY-PC === Setup started on JOEY-PC by Joey ===
2012/12/3:14:51:24 Joey JOEY-PC Launch
2012/12/3:14:51:27 Joey JOEY-PC PageOpen LaunchDialog
2012/12/3:14:51:30 Joey JOEY-PC PageOpen LicenseDialog
2012/12/3:14:51:34 Joey JOEY-PC PageOpen ProductInfoDialog
2012/12/3:14:52:03 Joey JOEY-PC PageOpen ProductSelectionDialog2
2012/12/3:14:52:13 Joey JOEY-PC PageOpen FullProgressDialog
2012/12/3:14:52:14 Joey JOEY-PC Installing 3dsMax Composite 2013: INSTALLDIR="C:\Program Files\Autodesk\Composite 2013\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:14:54:05 Joey JOEY-PC Install 3dsMax Composite 2013 Succeeded
2012/12/3:14:54:05 Joey JOEY-PC Installing Autodesk® Backburner 2013: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\x86\Components\backburner\BackburnerCIF.exe
2012/12/3:14:54:08 Joey JOEY-PC Install Autodesk® Backburner 2013 Succeeded
2012/12/3:14:54:08 Joey JOEY-PC Installing Autodesk® DirectConnect 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:14:55:45 Joey JOEY-PC Install Autodesk® DirectConnect 2013 Succeeded
2012/12/3:14:55:45 Joey JOEY-PC Installing Autodesk Inventor Server Engine For 3ds Max 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:14:56:36 Joey JOEY-PC Install Autodesk Inventor Server Engine For 3ds Max 2013 Succeeded
2012/12/3:14:56:36 Joey JOEY-PC Installing Autodesk® Revit Interoperability 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:14:57:26 Joey JOEY-PC Install Autodesk® Revit Interoperability 2013 Succeeded
2012/12/3:14:57:26 Joey JOEY-PC Installing Autodesk® Essential Skills Movies for 3dsMax 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:14:57:40 Joey JOEY-PC Install Autodesk® Essential Skills Movies for 3dsMax 2013 Succeeded
2012/12/3:14:57:40 Joey JOEY-PC PageOpen InstallCompleteDialog
2012/12/3:15:00:55 Joey JOEY-PC === Setup ended ===
2012/12/3:15:36:20 Joey JOEY-PC === Setup started on JOEY-PC by Joey ===
2012/12/3:15:36:20 Joey JOEY-PC Launch
2012/12/3:15:36:24 Joey JOEY-PC === Setup ended ===
2012/12/3:15:36:22 Joey JOEY-PC === Setup started on JOEY-PC by Joey ===
2012/12/3:15:36:22 Joey JOEY-PC Launch
2012/12/3:15:36:24 Joey JOEY-PC PageOpen LaunchDialog
2012/12/3:15:36:26 Joey JOEY-PC PageOpen LicenseDialog
2012/12/3:15:36:29 Joey JOEY-PC PageOpen ProductInfoDialog
2012/12/3:15:37:05 Joey JOEY-PC PageOpen ProductSelectionDialog2
2012/12/3:15:37:35 Joey JOEY-PC PageOpen FullProgressDialog
2012/12/3:15:37:35 Joey JOEY-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/3:15:39:47 Joey JOEY-PC Install DirectX® Runtime Succeeded
2012/12/3:15:39:47 Joey JOEY-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:15:40:08 Joey JOEY-PC Install Autodesk Material Library 2013 Succeeded
2012/12/3:15:40:08 Joey JOEY-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:15:40:26 Joey JOEY-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2012/12/3:15:40:26 Joey JOEY-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:15:41:33 Joey JOEY-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/12/3:15:41:34 Joey JOEY-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Joey\AppData\Local\Temp\_AIF883.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGJKS_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/3:15:51:54 Joey JOEY-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2012/12/3:15:52:10 Joey JOEY-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/12/3:15:52:30 Joey JOEY-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/12/3:15:52:55 Joey JOEY-PC Rollback Autodesk Material Library 2013 Succeeded
2012/12/3:15:52:55 Joey JOEY-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
My installation Log in case that helps at all, i saw where they were getting 1603 and 1619 as well. I can't figure out how anybody solved the issue outside of direct x updates, which i guess mine is up to date by what it said the first time i downloaded.
Active Member
joey.williams
Message 5 of 8 (356 Views)
12-04-2012 07:43 AM in reply to: joey.williams
Tried the install again this morning, got an entirely new error to keep things fresh. "There is a problem with this windows installer package. A program run as part of the setup did not finish as expected. Contact your support personell or package vendor."
Im doomed to not have autodesk products
Product Support
aaronhai
Message 6 of 8 (338 Views)
12-06-2012 02:55 AM in reply to: joey.williams
Hi joey.williams,
Please try a clean install in Diagnostics Mode.
Thank you.
Aaron Hai
Active Member
joey.williams
Message 7 of 8 (327 Views)
12-06-2012 07:46 AM in reply to: joey.williams
Tried this laSt night a few times, error 1601 was the number that time. Should I just install an older version? People aren't seeming to have much luck with 2013
Active Member
joey.williams
Message 8 of 8 (177 Views)
04-12-2013 08:56 AM in reply to: joey.williams
Is there any solution for error 1619?? i've tried everything from diagnostics mode to uninstalling java before hand. Literally anything that was even rumored to make this installation go through. I started trying to install this in november and I've yet to see a working version of 3ds max on my PC. I would appreciate any tips or information.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
