2014/4/8:20:17:07 === Setup started on HOLF-PC by Holf ===
2014/4/8:20:17:07 Path_Length: 151
2014/4/8:20:17:07 Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2014/4/8:20:17:07 Launch
2014/4/8:20:17:07 CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-46457004 /PK 128F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/8:20:17:07 Current Directory C:\Users\Holf\AppData\Local\Temp\_AI9B45.tmp
2014/4/8:20:18:45 === Setup ended ===
2014/4/8:20:17:09 === Setup started on HOLF-PC by Holf ===
2014/4/8:20:17:09 Path_Length: 151
2014/4/8:20:17:09 Current Directory C:\Users\Holf\AppData\Local\Temp\_AI9B45.tmp
2014/4/8:20:17:09 Launch
2014/4/8:20:17:53 Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/4/8:20:18:44 Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/4/8:20:18:45 PageOpen LaunchDialog
2014/4/8:20:21:49 PageOpen LicenseDialog
2014/4/8:20:21:49-PageOpen ProductInfoDialog
2014/4/8:20:21:49- PageOpen ProductSelectionDialog2
2014/4/8:20:22:41-PC PageOpen FullProgressDialog
2014/4/8:20:22:42-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/4/8:20:22:45-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/4/8:20:22:45-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Holf\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/8:21:18:08-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
Please help~
you can try this: http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
DarrenP
Darren is right. Specifically the error is here:
I have tried the above suggestions.
However, the problem is still there.
I have uninstalled all the Visual C++ 2005 and (x64).
However, the installation process still stop at there
Then go ahead and manually install the prereq from Microsoft or Windows Update, then use my solution to edit the setup.ini to ignore the check for this.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good luck!
