• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Installation Error
    139 Views, 7 Replies
    10-08-2012 04:49 PM
    Been trying to install 3DS Max for serveral hours now and just getting the same issues upon completion of the download and installation process. Several of the features will install, but 3DS Max will not after trying a fresh download and install it still yields the same problems over and over. I've checked google and the forums for similiar issues but none seem to match up to what i am experiencing, Any help is appreciate.
    I posted the attachment with the error files at the end. Not sure what to do.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Installation Error
    10-09-2012 08:47 AM in reply to: donny.evason
    There seems to be a failure in downloading from this link:
    http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    10-09-2012 08:53 AM in reply to: donny.evason
    I'm not sure on what i need to do with the file you gave me to download? If you could add some additonal information with it i'd be very grateful.
    //Donny
    *Expert Elite*
    TravisNave
    10-09-2012 09:00 AM in reply to: donny.evason
    All I know is that is the file location that the installer is supposed to be downloading.  It is failing to download.  You might see if you can even download it manually by clicking it.  Perhaps there is a problem with that file on the server or there is an issue with you connecting to it.
    Travis Nave
    Member
    10-09-2012 09:04 AM in reply to: TravisNave
    Hmm seems a bit wierd, just my that my friend downloaded and installed it at the same time as me with no issues and such, so don't know how to fix the issue really.
    *Expert Elite*
    TravisNave
    10-09-2012 09:06 AM in reply to: donny.evason
    I hear ya.  There have been a lot of odd happenings with the student downloads.  I suspect one of the servers might have an issue.
    Travis Nave
    Member
    10-09-2012 09:11 AM in reply to: TravisNave
    Should i just wait for someone to maybe resolve the issue or try another method? I'm at a loss here as i've just started university and will noi doubt be burdened with a heavy workload soon.
    //donny
    *Expert Elite*
    TravisNave
    10-09-2012 09:25 AM in reply to: donny.evason
    Try downloading it from another computer, maybe.
    Travis Nave
