Installation & Licensing
New Member
ims2
Message 1 of 3 (1,575 Views)
Installation Error?
1575 Views, 2 Replies
07-11-2012 10:30 PM
So was able to download and start installing and at the very last step (I think) I get this eroor log:
=== Setup started on SUNG-HO-PC by Sung-Ho ===
Launch
PageOpen LaunchDialog
PageOpen LicenseDialog
PageOpen ProductInfoDialog
PageOpen ProductSelectionDialog2
PageOpen FullProgressDialog
Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\AppData\Local\Temp\vcredist_x86_2005.log"" "
Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Sung-Ho\AppData\Local\Temp\vcredist_x86_2010.log
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
=== Setup started on  ===
Launch
=== Setup ended ===
New Member
veta16
Message 2 of 3 (1,559 Views)
Re: Installation Error?
07-12-2012 11:21 AM in reply to: ims2
I have the same problem I try to install revit 2012 and it said that some windows visual c++  error existed  and the installation was not completed what can I do? my class mates have installed the same program with out problems how can I fix mine?? a technician told me to uninstall al 3dmax  would that be a solution??
TravisNave
Message 3 of 3 (1,519 Views)
07-16-2012 10:01 AM in reply to: ims2
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
