• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    mbeffinger
    Installation Error
    2107 Views, 13 Replies
    06-24-2011 02:56 PM
    I keep getting the following error message during installation of Maya 2012 (Student Edition):
    1: 5 2: Failed to install/uninstall the anchor service. 3: 1002
    I have already done the following:
    -turned off UAC
    -uninstalled previous version of Maya (2010 and 2008)
    -restarted computer
    Any other suggestions or recommendations?  If there is a 3rd party utility needed?
    Thank you.
    Please use plain text.
    Product Support
    Re: Installation Error
    06-27-2011 02:10 AM in reply to: mbeffinger
    Please try to install the software in diagnostics mode as described here
    http://usa.autodesk.com/getdoc/id=TS75218?
    If the issue persisits, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    mbeffinger
    07-06-2011 05:08 PM in reply to: hashim.mundol
    Still have problems installing.  Attached are zipped logfiles of all.
    Thanks again.
    Product Support
    07-07-2011 10:52 AM in reply to: mbeffinger
    there should be more log files (bigger in size). if not please enable msi verbose log and try to install again which will create MSI*.log in temp folder
    http://support.microsoft.com/kb/223300
    Hashim Mundol
    mbeffinger
    07-09-2011 10:12 AM in reply to: hashim.mundol
    Have the correct file but even when zipped it is over 4600KB - any other suggestions?  Also it appears that the same problem now exists when I attempt to re-install my OLDER versions of Maya as well (2009 and 2011).  Now I have NO Maya to work with.  Most of my class mates are having similar issues.
    Thanks again.
    Michael
    mbeffinger
    07-10-2011 03:07 PM in reply to: mbeffinger
    Have broken the logs into separate files and zipped.  Hope this works.  There are 5 total - might have to send more than 1 reply.
    Thanks.
    #1
    mbeffinger
    mbeffinger
    07-10-2011 03:08 PM in reply to: mbeffinger
    #3
    LAST ONE.
    Product Support
    07-11-2011 12:09 AM in reply to: mbeffinger
    Did you have any other version of Maya on this machine ?
    If you have no other Autodesk Software on this machine, please try to delete following folders manually and try to install
    C:\ProgramData\programdata\autodesk
    C:\ProgramData\programdata\flexnet\adsk*.*
    Hashim Mundol
    mbeffinger
    07-11-2011 09:50 AM in reply to: hashim.mundol
    Still didn't work - removed ALL Autodesk products (Motionbuilder and Mudbox) and all associated folders.  Attempted to install in both normal and diagnostic modes.
    What's next?
