Installation & Licensing
Installation Error : AutoDesk Product Design Suite Ult. 2013
1 REPLY 1
matthew.ram
653 Views, 1 Reply
I'm trying to install a trial of ADPDS-Ult and I have received this installation error log:
2012/12/14:13:05:31 Matt MATT-PC === Setup started on MATT-PC by Matt ===
2012/12/14:13:05:31 Matt MATT-PC Launch
2012/12/14:13:05:31 Matt MATT-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDDLM/2013/PDSU/WI/{F19EABA2-FFDD-49F4-B613-B8BBB543C697}/SETUP_x64.ta...
2012/12/14:13:05:32 Matt MATT-PC PageOpen LaunchDialog
2012/12/14:13:06:55 Matt MATT-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/14:13:06:55 Matt MATT-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/14:13:06:55 Matt MATT-PC PageOpen LicenseDialog
2012/12/14:13:06:57 Matt MATT-PC PageOpen ProductInfoDialog
2012/12/14:13:07:18 Matt MATT-PC PageOpen ProductSelectionDialog2
2012/12/14:13:08:29 Matt MATT-PC PageOpen FullProgressDialog
2012/12/14:13:08:29 Matt MATT-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDDLM/2013/PDSU/WI/{F19EABA2-FFDD-49F4-B613-B8BBB543C697}/DIRECTX.tar....
2012/12/14:13:08:29 Matt MATT-PC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Product Design Suite Ultimate 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/14:13:09:32 Matt MATT-PC Install DirectX® Runtime Succeeded
2012/12/14:13:09:32 Matt MATT-PC Download Skipped ACM http://trial2.autodesk.com/SWDLDDLM/2013/PDSU/WI/{F19EABA2-FFDD-49F4-B613-B8BBB543C697}/ACM_x64.tar....
2012/12/14:13:09:33 Matt MATT-PC Installing AutoCAD® Mechanical 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Product Design Suite Ultimate 2013\x64\en-us\acadm\acad.mst;C:\Users\Matt\AppData\Local\Temp\_AI2E80.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Product Design Suite Ultimate 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/12/14:13:11:51 Matt MATT-PC Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603
I've restarted the computer multiple times, and have tried to run as administrator, and it has still failed to install.  I do have AutoDesk's Building Design Suite install and curious if that is causing interference. I've attached the whole log file.
Thanks!
1 REPLY 1
emily.xu
in reply to: matthew.ram
Did you install AutoCAD 2013 SP 1.1? If yes, please unstall the SP, then install AutoCAD Mechanical, after all the autodesk product installed, then apply the autocad sp.
Details you can refer to this solution
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Administrator Productivity
