• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Installation Error AutoCAD2013 - already modified setup.ini file
    1447 Views, 1 Replies
    10-03-2012 10:15 PM
    Hi there
    I am having problems installing AutoCAD on my computer.
    I am running Windows 7 Ultimate with .NET Framework 4 client profile and Extended installed version 4.0.30319
    I have already modified the setup.ini file by deleting all references to  .Net Framework as per this post.
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
    This is the message I received in the installation log
    2012/9/24:20:59:24 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/9/24:20:59:24 Home HOME-PC Launch
    2012/9/24:20:59:54 Home HOME-PC === Setup ended ===
    2012/9/24:20:59:31 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/9/24:20:59:31 Home HOME-PC Launch
    2012/9/24:20:59:43 Home HOME-PC PageOpen LaunchDialog
    2012/9/24:20:59:44 Home HOME-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
    Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/9/24:20:59:56 Home HOME-PC === Setup ended ===
    2012/9/24:21:03:04 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/9/24:21:03:04 Home HOME-PC Launch
    2012/9/24:21:03:09 Home HOME-PC === Setup ended ===
    2012/9/24:21:03:06 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/9/24:21:03:06 Home HOME-PC Launch
    2012/9/24:21:03:08 Home HOME-PC PageOpen LaunchDialog
    2012/9/24:21:08:57 Home HOME-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
    Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/9/24:21:09:05 Home HOME-PC === Setup ended ===
    2012/10/4:12:59:44 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:12:59:44 Home HOME-PC Launch
    2012/10/4:12:59:50 Home HOME-PC === Setup ended ===
    2012/10/4:12:59:45 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:12:59:45 Home HOME-PC Launch
    2012/10/4:12:59:50 Home HOME-PC PageOpen LaunchDialog
    2012/10/4:13:00:01 Home HOME-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
    Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/10/4:13:00:15 Home HOME-PC === Setup ended ===
    2012/10/4:14:42:20 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:14:42:20 Home HOME-PC Launch
    2012/10/4:14:42:27 Home HOME-PC === Setup ended ===
    2012/10/4:14:42:22 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:14:42:22 Home HOME-PC Launch
    2012/10/4:14:42:27 Home HOME-PC PageOpen LaunchDialog
    2012/10/4:14:42:32 Home HOME-PC PageOpen LicenseDialog
    2012/10/4:14:42:42 Home HOME-PC PageOpen ProductInfoDialog
    2012/10/4:14:44:49 Home HOME-PC PageOpen ProductSelectionDialog2
    2012/10/4:14:45:19 Home HOME-PC PageOpen FullProgressDialog
    2012/10/4:14:45:19 Home HOME-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
    2012/10/4:14:45:41 Home HOME-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
    2012/10/4:14:45:41 Home HOME-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
    2012/10/4:14:46:03 Home HOME-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
    2012/10/4:14:46:03 Home HOME-PC Installing DirectX Runtime: C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
    2012/10/4:14:49:55 Home HOME-PC Install DirectX Runtime Succeeded
    2012/10/4:14:49:55 Home HOME-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:14:50:05 Home HOME-PC Install FaroSDK Succeeded
    2012/10/4:14:50:05 Home HOME-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:14:50:30 Home HOME-PC Install Autodesk Material Library 2013 Succeeded
    2012/10/4:14:50:30 Home HOME-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:14:50:45 Home HOME-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
    2012/10/4:14:50:46 Home HOME-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:14:51:07 Home HOME-PC Install Autodesk Content Service Succeeded
    2012/10/4:14:51:07 Home HOME-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:14:51:12 Home HOME-PC Install Autodesk Content Service Language Pack Succeeded
    2012/10/4:14:51:13 Home HOME-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Home\AppData\Local\Temp\_AI7791.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:14:51:49 Home HOME-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
    2012/10/4:14:51:52 Home HOME-PC Rollback Autodesk Content Service Language Pack Succeeded
    2012/10/4:14:52:03 Home HOME-PC Rollback Autodesk Content Service Succeeded
    2012/10/4:14:52:18 Home HOME-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
    2012/10/4:14:52:41 Home HOME-PC Rollback Autodesk Material Library 2013 Succeeded
    2012/10/4:14:52:43 Home HOME-PC Rollback FaroSDK Succeeded
    2012/10/4:14:52:44 Home HOME-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    2012/10/4:14:52:45 Home HOME-PC PageOpen InstallCompleteDialog
    2012/10/4:14:53:54 Home HOME-PC === Setup ended ===
    2012/10/4:14:54:59 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:14:54:59 Home HOME-PC Launch
    2012/10/4:14:55:06 Home HOME-PC === Setup ended ===
    2012/10/4:14:55:03 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:14:55:03 Home HOME-PC Launch
    2012/10/4:14:55:05 Home HOME-PC PageOpen LaunchDialog
    2012/10/4:14:55:10 Home HOME-PC PageOpen LicenseDialog
    2012/10/4:14:55:10 Home HOME-PC PageOpen ProductSelectionDialog2
    2012/10/4:14:55:26 Home HOME-PC === Setup ended ===
    2012/10/4:15:00:05 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:15:00:05 Home HOME-PC Launch
    2012/10/4:15:00:10 Home HOME-PC === Setup ended ===
    2012/10/4:15:00:07 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:15:00:07 Home HOME-PC Launch
    2012/10/4:15:00:10 Home HOME-PC PageOpen LaunchDialog
    2012/10/4:15:00:11 Home HOME-PC PageOpen LicenseDialog
    2012/10/4:15:00:14 Home HOME-PC PageOpen ProductInfoDialog
    2012/10/4:15:00:20 Home HOME-PC === Setup ended ===
    2012/10/4:15:03:20 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:15:03:20 Home HOME-PC Launch
    2012/10/4:15:03:24 Home HOME-PC === Setup ended ===
    2012/10/4:15:03:22 Home HOME-PC === Setup started on HOME-PC by Home ===
    2012/10/4:15:03:22 Home HOME-PC Launch
    2012/10/4:15:03:24 Home HOME-PC PageOpen LaunchDialog
    2012/10/4:15:03:28 Home HOME-PC PageOpen LicenseDialog
    2012/10/4:15:03:30 Home HOME-PC PageOpen ProductInfoDialog
    2012/10/4:15:03:53 Home HOME-PC PageOpen ProductSelectionDialog2
    2012/10/4:15:04:08 Home HOME-PC PageOpen FullProgressDialog
    2012/10/4:15:04:08 Home HOME-PC Installing DirectX Runtime: C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
    2012/10/4:15:06:04 Home HOME-PC Install DirectX Runtime Succeeded
    2012/10/4:15:06:04 Home HOME-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:15:06:15 Home HOME-PC Install FaroSDK Succeeded
    2012/10/4:15:06:15 Home HOME-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:15:06:33 Home HOME-PC Install Autodesk Material Library 2013 Succeeded
    2012/10/4:15:06:33 Home HOME-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:15:06:47 Home HOME-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
    2012/10/4:15:06:47 Home HOME-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:15:07:02 Home HOME-PC Install Autodesk Content Service Succeeded
    2012/10/4:15:07:02 Home HOME-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:15:07:07 Home HOME-PC Install Autodesk Content Service Language Pack Succeeded
    2012/10/4:15:07:08 Home HOME-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Home\AppData\Local\Temp\_AIB481.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/10/4:15:11:38 Home HOME-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
    2012/10/4:15:11:43 Home HOME-PC Rollback Autodesk Content Service Language Pack Succeeded
    2012/10/4:15:11:58 Home HOME-PC Rollback Autodesk Content Service Succeeded
    2012/10/4:15:12:27 Home HOME-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
    2012/10/4:15:13:03 Home HOME-PC Rollback Autodesk Material Library 2013 Succeeded
    2012/10/4:15:13:05 Home HOME-PC Rollback FaroSDK Succeeded
    2012/10/4:15:13:05 Home HOME-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    Any help would be much appreciated.
    Regards
    Please use plain text.
    Product Support
    aaronhai
    Re: Installation Error AutoCAD2013 - already modified setup.ini file
    10-04-2012 01:45 AM in reply to: kevin.vp.truong
    The 1603 error is a general Windows error-code that implies failed installation.
    To isolate this issue, please check on the following :
    - If you are running Network install, please try to turn off silent installations and observe where the installer fails. This may give an indication of which resource the permissions are lacking in.
    - Please ensure that you have full permissions to your machine and to the location where the deployment exists while you are installing from the deployment.
    - Please ensure anti-virus software and firewalls are disabled (to ascertain if these hinder the installation).
    - Please ensure that the installing user has Local Administrative group membership and that no restrictions are imposed to required users account. Note that Local Administrative privileges are required for installation.
    - Do not relocate the My Documents folder off of the Local System and do not use Roaming Profiles.
    - Ensure simple and short pathname used on source and target machine.
    - Clear Windows Temp and User Temp folders.
    - Re-install .NET framework (from DVD or download from Microsoft)
    Aaron Hai
    AutodeskCare | Product Support
    TW | PI | YT | BLOG
    If my reply was helpful, please Kudo or Accept as Solution. :smileyhappy:
