Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Installati on Error AutoCAD201 3 - already modified setup.ini file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi there
I am having problems installing AutoCAD on my computer.
I am running Windows 7 Ultimate with .NET Framework 4 client profile and Extended installed version 4.0.30319
I have already modified the setup.ini file by deleting all references to .Net Framework as per this post.
This is the message I received in the installation log
2012/9/24:20:59:24 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/9/24:20:59:24 Home HOME-PC Launch
2012/9/24:20:59:54 Home HOME-PC === Setup ended ===
2012/9/24:20:59:31 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/9/24:20:59:31 Home HOME-PC Launch
2012/9/24:20:59:43 Home HOME-PC PageOpen LaunchDialog
2012/9/24:20:59:44 Home HOME-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/9/24:20:59:56 Home HOME-PC === Setup ended ===
2012/9/24:21:03:04 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/9/24:21:03:04 Home HOME-PC Launch
2012/9/24:21:03:09 Home HOME-PC === Setup ended ===
2012/9/24:21:03:06 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/9/24:21:03:06 Home HOME-PC Launch
2012/9/24:21:03:08 Home HOME-PC PageOpen LaunchDialog
2012/9/24:21:08:57 Home HOME-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/9/24:21:09:05 Home HOME-PC === Setup ended ===
2012/10/4:12:59:44 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:12:59:44 Home HOME-PC Launch
2012/10/4:12:59:50 Home HOME-PC === Setup ended ===
2012/10/4:12:59:45 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:12:59:45 Home HOME-PC Launch
2012/10/4:12:59:50 Home HOME-PC PageOpen LaunchDialog
2012/10/4:13:00:01 Home HOME-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/10/4:13:00:15 Home HOME-PC === Setup ended ===
2012/10/4:14:42:20 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:14:42:20 Home HOME-PC Launch
2012/10/4:14:42:27 Home HOME-PC === Setup ended ===
2012/10/4:14:42:22 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:14:42:22 Home HOME-PC Launch
2012/10/4:14:42:27 Home HOME-PC PageOpen LaunchDialog
2012/10/4:14:42:32 Home HOME-PC PageOpen LicenseDialog
2012/10/4:14:42:42 Home HOME-PC PageOpen ProductInfoDialog
2012/10/4:14:44:49 Home HOME-PC PageOpen ProductSelectionDialog2
2012/10/4:14:45:19 Home HOME-PC PageOpen FullProgressDialog
2012/10/4:14:45:19 Home HOME-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Home\Downloads\AutoCAD_2013_English_Win_6
2012/10/4:14:45:41 Home HOME-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/10/4:14:45:41 Home HOME-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Home\Downloads\AutoCAD_2013_English_Win_6
2012/10/4:14:46:03 Home HOME-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/10/4:14:46:03 Home HOME-PC Installing DirectX Runtime: C:\Users\Home\Downloads\AutoCAD_2013_English_Win_6
2012/10/4:14:49:55 Home HOME-PC Install DirectX Runtime Succeeded
2012/10/4:14:49:55 Home HOME-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:14:50:05 Home HOME-PC Install FaroSDK Succeeded
2012/10/4:14:50:05 Home HOME-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:14:50:30 Home HOME-PC Install Autodesk Material Library 2013 Succeeded
2012/10/4:14:50:30 Home HOME-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:14:50:45 Home HOME-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/10/4:14:50:46 Home HOME-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_E
2012/10/4:14:51:07 Home HOME-PC Install Autodesk Content Service Succeeded
2012/10/4:14:51:07 Home HOME-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:14:51:12 Home HOME-PC Install Autodesk Content Service Language Pack Succeeded
2012/10/4:14:51:13 Home HOME-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_E
2012/10/4:14:51:49 Home HOME-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/10/4:14:51:52 Home HOME-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/10/4:14:52:03 Home HOME-PC Rollback Autodesk Content Service Succeeded
2012/10/4:14:52:18 Home HOME-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/10/4:14:52:41 Home HOME-PC Rollback Autodesk Material Library 2013 Succeeded
2012/10/4:14:52:43 Home HOME-PC Rollback FaroSDK Succeeded
2012/10/4:14:52:44 Home HOME-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/10/4:14:52:45 Home HOME-PC PageOpen InstallCompleteDialog
2012/10/4:14:53:54 Home HOME-PC === Setup ended ===
2012/10/4:14:54:59 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:14:54:59 Home HOME-PC Launch
2012/10/4:14:55:06 Home HOME-PC === Setup ended ===
2012/10/4:14:55:03 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:14:55:03 Home HOME-PC Launch
2012/10/4:14:55:05 Home HOME-PC PageOpen LaunchDialog
2012/10/4:14:55:10 Home HOME-PC PageOpen LicenseDialog
2012/10/4:14:55:10 Home HOME-PC PageOpen ProductSelectionDialog2
2012/10/4:14:55:26 Home HOME-PC === Setup ended ===
2012/10/4:15:00:05 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:15:00:05 Home HOME-PC Launch
2012/10/4:15:00:10 Home HOME-PC === Setup ended ===
2012/10/4:15:00:07 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:15:00:07 Home HOME-PC Launch
2012/10/4:15:00:10 Home HOME-PC PageOpen LaunchDialog
2012/10/4:15:00:11 Home HOME-PC PageOpen LicenseDialog
2012/10/4:15:00:14 Home HOME-PC PageOpen ProductInfoDialog
2012/10/4:15:00:20 Home HOME-PC === Setup ended ===
2012/10/4:15:03:20 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:15:03:20 Home HOME-PC Launch
2012/10/4:15:03:24 Home HOME-PC === Setup ended ===
2012/10/4:15:03:22 Home HOME-PC === Setup started on HOME-PC by Home ===
2012/10/4:15:03:22 Home HOME-PC Launch
2012/10/4:15:03:24 Home HOME-PC PageOpen LaunchDialog
2012/10/4:15:03:28 Home HOME-PC PageOpen LicenseDialog
2012/10/4:15:03:30 Home HOME-PC PageOpen ProductInfoDialog
2012/10/4:15:03:53 Home HOME-PC PageOpen ProductSelectionDialog2
2012/10/4:15:04:08 Home HOME-PC PageOpen FullProgressDialog
2012/10/4:15:04:08 Home HOME-PC Installing DirectX Runtime: C:\Users\Home\Downloads\AutoCAD_2013_English_Win_6
2012/10/4:15:06:04 Home HOME-PC Install DirectX Runtime Succeeded
2012/10/4:15:06:04 Home HOME-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:15:06:15 Home HOME-PC Install FaroSDK Succeeded
2012/10/4:15:06:15 Home HOME-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:15:06:33 Home HOME-PC Install Autodesk Material Library 2013 Succeeded
2012/10/4:15:06:33 Home HOME-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:15:06:47 Home HOME-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/10/4:15:06:47 Home HOME-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_E
2012/10/4:15:07:02 Home HOME-PC Install Autodesk Content Service Succeeded
2012/10/4:15:07:02 Home HOME-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Home\Downloads\AutoCAD_
2012/10/4:15:07:07 Home HOME-PC Install Autodesk Content Service Language Pack Succeeded
2012/10/4:15:07:08 Home HOME-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Users\Home\Downloads\AutoCAD_2013_E
2012/10/4:15:11:38 Home HOME-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/10/4:15:11:43 Home HOME-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/10/4:15:11:58 Home HOME-PC Rollback Autodesk Content Service Succeeded
2012/10/4:15:12:27 Home HOME-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/10/4:15:13:03 Home HOME-PC Rollback Autodesk Material Library 2013 Succeeded
2012/10/4:15:13:05 Home HOME-PC Rollback FaroSDK Succeeded
2012/10/4:15:13:05 Home HOME-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Any help would be much appreciated.
Regards
Re: Installati on Error AutoCAD201 3 - already modified setup.ini file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The 1603 error is a general Windows error-code that implies failed installation.
To isolate this issue, please check on the following :
- If you are running Network install, please try to turn off silent installations and observe where the installer fails. This may give an indication of which resource the permissions are lacking in.
- Please ensure that you have full permissions to your machine and to the location where the deployment exists while you are installing from the deployment.
- Please ensure anti-virus software and firewalls are disabled (to ascertain if these hinder the installation).
- Please ensure that the installing user has Local Administrative group membership and that no restrictions are imposed to required users account. Note that Local Administrative privileges are required for installation.
- Do not relocate the My Documents folder off of the Local System and do not use Roaming Profiles.
- Ensure simple and short pathname used on source and target machine.
- Clear Windows Temp and User Temp folders.
- Re-install .NET framework (from DVD or download from Microsoft)
