Installation & Licensing
Install error when running setup file
2 REPLIES 2
thutcherson
311 Views, 2 Replies
I am getting the attached error message with both revit 2014 and CAD 2014. I am trying to install on a new 64 bit computer that is running windows 8. Any thoughts?
I have tried disabling the antivirus software, deleting the files in the temp folder, and downloading the software from a virtual agent at autodesk. Nothing seems to make a difference...
2 REPLIES 2
TravisNave
in reply to: thutcherson
Welcome to the peer forum.
Try disabling UAC as much as possible in Win8.  Enable the Administrator account.  Login as Administrator and install it from there.  See if you get the same error.
Autodesk Forums:
emily.xu
Another suggestion from me is try to empty your temp folder(access by %temp% in your Windows Explorer), then reboot the machine,and try to reinstall.
Hope that helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Administrator Productivity
