Installation & Licensing
Active Member
jsrmid
Message 1 of 11 (1,029 Views)
Install cant find EULA
1029 Views, 10 Replies
09-18-2013 04:26 PM
When installing Autodesk DWG TrueView 2014 on Windows 7 32-bit, I get a message about not finding the EULA. At the point where I click "Install On This Computer" I get a DWG Trueview 2014 window with the message "Can't Find End User License Agreement" my only option is to click ok which closes the install.
I hope someone can help, I've installed this software multiple times and have never ran across this.
Product Support
aaronhai
Message 2 of 11 (1,005 Views)
Re: Install cant find EULA
09-19-2013 03:35 AM in reply to: jsrmid
Hi jsrmid,
Welcome to Autodesk Discussion Group.
In order to eliminate bad installer issue, may I request for a re-download of the DWG TrueView installer?
Thank you.
Aaron Hai
Active Member
jsrmid
Message 3 of 11 (994 Views)
09-19-2013 08:53 AM in reply to: aaronhai
I still receive the same issue. The first time I tried it this morning it allowed me to accept the EULA but the install failed. After I retried the EULA doesnt come up again
TravisNave
Message 4 of 11 (989 Views)
09-19-2013 09:11 AM in reply to: jsrmid
See if you can physically find the EULA file and move it to where it is expected.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
philip.s
Message 5 of 11 (983 Views)
09-19-2013 09:26 AM in reply to: jsrmid
Hi Jorge,
Do you experience the same behavior if you bypass the download manager and utilize a direct DWG TrueView 2014 download link?
Philip Schmelzer
Active Member
jsrmid
Message 6 of 11 (983 Views)
09-19-2013 09:26 AM in reply to: TravisNave
The EULA is in C:\Autodesk\SetupDWGTrueView2014_ENU_32bit\EULA folder, should it be somewhere else? I checked the minimum system requirements and it meets all. I'm running Office 2003, could that be the issue? The EULA is saved as a Word doc
Active Member
jsrmid
Message 7 of 11 (975 Views)
09-19-2013 10:29 AM in reply to: philip.s
I Attempted without the installer and used the option to download with the browser instead, it has the same issue. I'm trying to install the 32 bit version
Active Member
jsrmid
Message 8 of 11 (970 Views)
09-19-2013 10:38 AM in reply to: jsrmid
This happens on DWG Trueview 2011 version as well
TravisNave
Message 9 of 11 (964 Views)
09-19-2013 10:48 AM in reply to: jsrmid
And you are not installing outside of your region or with a foreign OS or language, correct?
Active Member
jsrmid
Message 10 of 11 (963 Views)
09-19-2013 10:50 AM in reply to: jsrmid
I was able to successfully install  the software :smileyvery-happy:
I opened the Setup.ini document and found a line about the EULA.
EULA_PATH=EULA
Changed it to the correct path
EULA_PATH=C:\Autodesk\SetupDWGTrueView2014_ENU_32bit\EULA
Saved the file and the install worked!
Thanks for the help
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
